Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. May 5, 2009 at 5:08 AM
    #121
    misc
    misc [OP] Well-Known Member
    Good to have you new guys. Glad we could help...
  2. May 5, 2009 at 8:58 AM
    #122
    kohan25
    kohan25 Active Member
    06 TACOMA SR5 4X4 TRD Speedway Blue
    lebra tonneau cover, avs bugshield, firefighter goober lights, custom stereo/scanner install
    Mine conveniently went out about a month ago right after the warranty expired. Thanks to finding this thread I got around to fixing it yesterday and am working again. My solder joint also did not look bad either but I very gently pried it with an exacto knife and it was broken. Thanks forum.
  3. May 7, 2009 at 2:58 PM
    #123
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    The last time I checked the dealer wants over $330 for the part(s) as described which consist of: circuit card, display board and wire harness.....
  4. May 8, 2009 at 2:46 PM
    #124
    gtg258y
    gtg258y New Member
    Anchorage, Alaska
    07 Prerunner TRD Offroad
    One of my chips broke off so I soldered it. I'm not very experienced with soldering so it is not the most high quality job. I'm not sure how hot it got before, but now they get about 160 degrees fahrenheit (had a thermocouple available nearby :)). Should the 510 chip be getting that hot? I can't even touch it!
  5. May 8, 2009 at 3:08 PM
    #125
    frozen_taco
    frozen_taco Well-Known Member
    Fairbanks AK
    05 Off rd. trd acc. cab with modddds
    flowmaster 50 series delta flow dual exhaust, grillgraft mesh, BHLM, VIPER 2 way auto start, Alpine 10" type R subwoofer, Custom made sub enclosure in back, aries tube steps, K&N, 20% tint, debadged, 20"X9 panther realm rims, Nitto 420 tires, blacked out tails, visors, PIAA headlights, bug guard,
    I cant believe this worked for me had to have been the shittiest solder job but it works now :D
  6. May 16, 2009 at 8:00 PM
    #126
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I just did the fix. Worked great, but I had the door open when I unhooked the two harnesses. Dome light went out when I unplugged the map lights. Fixed the compass/term, but now I don't have any map or dome lights. Did I blow a fuse? Wich one would it be?
  7. May 22, 2009 at 1:58 PM
    #127
    06WHITETRD
    06WHITETRD Gotta Love my Taco!!!!
    So Cal
    06 Toyota Tacoma OFF-ROAD
    Tinted windows, window visors, XDI True Flow intake, White Devil Emblem, sport white grill, stubbie 6' antenna, TRD license plate frame,TRD Exhaust, weathertech floor front & rear, LED map/dome & license plate lights,Black Grille,T-Rex eyebrows,black Skid Plate,Lower bumper cover,Black emblems,white TRD Emblem,lamin-x yellow,Slotted & Cross Drilled rotors,Redline shocks(hood),HID 6k,more to come
    check the fuse box. maybe you did.
  8. May 22, 2009 at 1:59 PM
    #128
    06WHITETRD
    So Cal
    I just solder my compass/temperature and it works great. wow.. one off the 510 was crack so that was the reason it didnt work in the first place.. thank you ppl I have it working again..
  9. May 22, 2009 at 3:32 PM
    #129
    Tool
    Tool Who Inspires You?
    Riverside, CA
    07 PreRunner TRD Sport
    TRD SuperCharger 6in ProComp Lift, DTLT Headers, JBA Exhaust, Pioneer Appradio 4, Coverking seat covers, 2 10in Rockford Fosgate subs, Rockford Fosgate Amp, N-fabs, 6000k HID LED Taillights
    WOOHOO it worked =) thanks a lot
  10. May 23, 2009 at 3:42 PM
    #130
    justindwhite
    justindwhite Member
    tulsa ok
    06 tacoma trd 4x4
    Im glad i found this tip you saved me some time. It fixed the problem. thanks
  11. May 25, 2009 at 3:21 PM
    #131
    bernie32
    bernie32 New Member
    BC, canada
    TRD
    :eek:You ....my friend......saved me a bundle. THANK YOU!!!!! It worked. My fuse or resistor completely fell off and if I didn't know what I was looking for it would have been lost. I soldered it back on and covered it with silicone. Thanks again!
  12. May 30, 2009 at 9:28 PM
    #132
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    hey guys... My just quit working the other day.
    I am wondering if I want to tackle this or use my 7 yr 100K mile warranty I bought from Troy..
    I can't remember if there is a deductable or not???
  13. May 31, 2009 at 11:28 AM
    #133
    bernie32
    bernie32 New Member
    BC, canada
    TRD
    I tried that they told me it wasn't covered. I asked if this was a common issue and the service person said "No, not really".......only to find out they have 13 on back order. I mentioned it to a buddy of mine who just picked up his Taco in Oregon with 40,000miles......he didn't even know it came with a compass because it never worked when he got it. That one is now fixed too. Most of the truck is made local or in Canada, that module is made in Mexico which is why Toyota here says they won't cover it. Probably more service BS to get me to walk away and deal with it myself. Mt rims started peeling paint..........."Sorry, not covered over 100,000kms or 60,000miles." I have now bought 3 toyotas and LOVE them but I will NEVER get screwed again on the extended warranty stuff.
  14. May 31, 2009 at 5:19 PM
    #134
    Uneek
    Uneek New Member
    '05 DC SB PreRunner
    Thank you for the write up. I finally had some time to look into the problem today.
    Mine went out a few months ago on my 2005 but came back on for a few seconds week after that and been out since. I bought mine early August 2005.
    The soldering points looked fine, until I looked closer. It had a small fracture across the soldering. Like many, I plugged the board back in and pushed on the 510 resistors and it lit up. It appeared to be the 510 resistor furthest from the LCD and the side furthest from the button. I went ahead and soldered all four points on both resistors. FWIW, mine also had the burnt corner on the LCD display.
    For the clips that come off of the console and gets stuck in the metal bracing in the truck, I reached in and placed a finger over the clip and pinched it out with my other hand. I read on TN a few people had the clip fall into the headliner. There's a little hook like tab on the clip down the center. I bent the tab with a needle nose pliers just in case if I ever need to pull the console down again, so it'll stay with the console rather than the truck.
    Thank you again! :)
  15. Jun 4, 2009 at 10:26 AM
    #135
    Joeyvalley
    Joeyvalley New Member
    I did this this morning, took about 15 minutes and now it works again. I had to purchase the solder kit (17.00) and the torx kit (6.00) from Home Depot. The only other thing I would suggest is to use a magnifying glass because those resistors are so tiny and I couldn't make out where it had come apart but I took Secret Squirrell's advice and I soldered all of them just to be safe.
    2007 Pre Runner Sport Double Cab
  16. Jun 4, 2009 at 10:54 AM
    #136
    misc
    Glad to hear it worked for you guys. Hang out a while :D
  17. Jun 9, 2009 at 10:35 PM
    #137
    joew94th
    joew94th Member
    Cameron Park, CA
    06 PreRunner TRD offroad
    SecretSquirel,
    To borrow one of my kids euphemisms, YOU ROCK!
    The problem and fix was precisely as described.
    Thanks!
    -Joe
  18. Jun 10, 2009 at 2:32 PM
    #138
    nevaren
    nevaren New Member
    Maryland
    05 TRD OFF ROAD Debadged
    Flow master precats, cat, and dual exhaust
    Stumbled across this thread today.
    20 min of work and $900 saved.
    Thanks a ton,
    you guys ROCK!
  19. Jun 10, 2009 at 2:35 PM
    #139
    misc
    Welcome to TW, guys. This thread is just the tip of the knowledge iceberg... hang out a while :)
  20. Jun 13, 2009 at 1:21 PM
    #140
    tacomachic
    tacomachic Member
    Utah
    2006 DC Off-Road in sexy Super White
    It worked!! So easy a girl can do it! :) Thanks for the fix... I was dreading the stealership bill for that one....
