Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Nov 9, 2013 at 5:19 PM
    #1541
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I agree with Partzguy. Very fast turnaround and their replacement is 1,000 times better than the original. Toyota replaced my original with the new and improved unit and it turns out to be worse than original units.
  2. Nov 9, 2013 at 5:45 PM
    #1542
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    I can also vouch for silicon method. After my attempts failed, I sent it to the and it came back better than new. I believe they also warranty their work for 3 years iirc.
  3. Nov 11, 2013 at 8:13 PM
    #1543
    Tacomaman2008
    Tacomaman2008 Member
    Framingham, MA
    08 Dbl Cab Stock
    Just wanted to say thank you for this fix!
    This happened to my '08 Tacoma (w/ 80k miles) about 3 weeks ago. I just followed the instructions, spent 5mins with a Soldering iron ( 510 were visibly lifted off the PCB) and bam! It's working again :)
  4. Nov 11, 2013 at 8:25 PM
    #1544
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    tired re-soldering both 510's, after a day it went out again.. rechecked and solder is still their... maybe i need to check for burn on bottom of board?
  5. Nov 12, 2013 at 3:03 AM
    #1545
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    It is possible one of the 510's has a crack in it. They are rather fragile.
  6. Nov 12, 2013 at 3:10 AM
    #1546
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Or the pad lifted from the trace. You may want to run solder down the trace to beef it up.
    Oh, and silver solder FTW
  7. Nov 15, 2013 at 9:56 AM
    #1547
    FinallyGotMyTaco
    FinallyGotMyTaco New Member
    Sean
    Colorado
    06 Black SR5 TRD-Off Road
    Stock, for now!
    Just bought a used 06 Taco and the overhead wasn't working. Found this thread and figured I'd give it a try. The solder on the 510 resistor was broken, but even after soldering both side three times, it's still not working. Any thoughts, besides the board being bad?
  8. Nov 15, 2013 at 10:35 AM
    #1548
    RichieW13
    RichieW13 Well-Known Member
    Richie
    Thousand Oaks, CA
    2008 PreRunner Sport
    Somebody else mentioned in this thread that most likely it is a soldering problem. Unless you are an expert solderer and are 100% confident you have a good solder, the answer is that you probably don't.
    I have repaired mine three times. I thought it was good each time, but after some amount of time (ranging from hours to months), something went bad and my solder detached.
    My compass/thermometer is currently not working, and it sucks.
  9. Nov 16, 2013 at 3:37 AM
    #1549
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    I took my 06 to the Dealer in Tennessee and got the entire unit replaced since it wasn't working when I bought the truck.
    No questions, and they replaced the unit in about an hour or so at no cost. Now I will see how long it keeps working!
  10. Nov 16, 2013 at 12:42 PM
    #1550
    Misterk40
    Misterk40 Member
    South Dakota
    06 PreRunner
    I'm no expert and I soldered mine. Still working a week later. Did you solder both ends of both 510s? Check out these guys. http://www.siliconmethod.com/. I haven't needed them yet, but a couple other members gave them good marks. Costs nothing but a few minutes to check their site.
  11. Nov 26, 2013 at 4:42 AM
    #1551
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Silver Solder for the win. I've said it before, but the high temps the back of that board reaches against the roof is bad for the joints and the silver solder has a higher melting point.
    Over a year on my repair on a black taco and North Carolina summer.
  12. Nov 26, 2013 at 7:06 AM
    #1552
    jediwebdude
    jediwebdude Well-Known Member
    Frisco, TX
    2019 TRD Pro Tacoma
    This is broken in the used Taco I just bought. Used that to my advantage to get the price down even more. Think I'll order one of the eBay ones as I fear my soldering ability will be inadequate.
  13. Nov 26, 2013 at 10:30 AM
    #1553
    RichieW13
    Richie
    Thousand Oaks, CA
  14. Nov 26, 2013 at 8:00 PM
    #1554
    BryansTacoma08
    BryansTacoma08 Well-Known Member
    Bryan
    Beaufort South Carolina
    2008 DCSB Speedway Blue
    I have also used silicon method and they did a great job and with a fast turnaround. Would def go back if I had a problem
  15. Dec 8, 2013 at 2:56 PM
    #1555
    crusader1
    crusader1 Well-Known Member
    Al
    SC Upstate
    06 PreRunner TRD#1/'73 Datsun 240Z Orig. Ownr
    None yet...just warmin' up
    THANKS, Amigo! I just read the entire procedure to my wife, who is busily preparing dinner...she listened with rapt attention to every detail :) You have made my day, leaving me itching to dive into the overhead panel, tomorrow. I will post results ASAP, and lift a beer to you for the priceless (well, about $1K at least) directions :p
  16. Dec 9, 2013 at 10:02 AM
    #1556
    RichieW13
    Richie
    Thousand Oaks, CA
  17. Dec 10, 2013 at 11:44 AM
    #1557
    toyohtadude
    toyohtadude Well-Known Member
    Eric
    Austin, TX
    2017 4x4 Tundra SR5 CrewMax
    Bone stock
    Search is my friend and the results on this site never let me down... yet another dead-on fix for the truck. I just took it out after getting back from lunch and found this thread. Popped the display out and there it is.... Bad 510 showing... Thanks for the fix everyone. This site just rocks!
  18. Dec 10, 2013 at 4:22 PM
    #1558
    toyohtadude
    Eric
    Austin, TX
    Bone stock
    Done and works fine. It took longer for the soldering iron to warm up and cool off than it did to repair and put it back in the truck. Awesome!! Thanks!!
  19. Dec 12, 2013 at 4:05 PM
    #1559
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
    @RichieW13,
    As long as it worked for a while, it is perfectly repairable again. If you want to send it my way, we can get it repaired (correctly). Or, follow my DIY guide here.
    Either way, don't hate the truck...hate on the ebay scammers who can't solder their way out of a paper bag.:rolleyes:
    Siliconmethod Display repairs
  20. Dec 13, 2013 at 3:49 AM
    #1560
    crusader1
    Al
    SC Upstate
    misc,
    Thanks for the excellent link containing detailed info on repair of the Accessory Panel Circuit Board. I've had no problem following directions, up to a point. Now, I'm trying to separate the green circuit board from its gray cover, so I can gain access to the backside where all the circuits lie.
    Working slowly and carefully to avoid any sort of damage, I feel the white cannon plug needs to separate from the gray housing to allow lifting and removal of the board. It latches in some manner to the housing, and I have been unable to discover the method of release.
    The eight (8) wires from that plug wrap tightly around one end of the gray housing before attaching to a terminal on the edge of the CB. They must be freed to allow that end of the CB to lift and slide from its mounted position.
    The other end of the CB is held down under the selector switch, which is fixed. I can see easily the topside of both "510" resistors, if that's what they are, but cannot see or access the working side to effect the fix, without removal of the Circuit Board (CB).
    The question is: How do I remove the White Harness Plug from the grey housing? Once accomplished, the attached wires can be lifted from their tightly-pressed routing, freeing up that end of the CB.
    Looks simple, but is tricky and a bit frustrating
