Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Jun 16, 2009 at 8:00 PM
    #141
    sinker
    sinker New Member
    PreRunner SR5
    My 05 went out almost 6 months ago I checked the fuses a couple of times and finally just forgot about until I came across this thread.
    I have not done the soldering yet but just pressing on the 510s with the power on brought this gadget back to life! Amazing! Any tips on soldering for a first timer?
  2. Jun 17, 2009 at 2:23 AM
    #142
    JKD
    JKD Well-Known Member
    I don't have a Tacoma yet, but I've read this thread with interest, and I have a question and a comment.
    First, does the display glow green/blue, or is it a backlit LCD (like a common wristwatch)? If the digits glow, it is probably a vacuum fluorescent display, which works similar to a picture tube or plasma screen. The display is contained within a glass envelope. The 'burnt corner' would be the 'getter', a material used to achieve a higher vacuum by chemically combining with residual gasses in the vacuum envelope when heated during manufacture. Such a getter is normal.
    Second, an idea about why the solder is a problem--I wouldn't be surprised if RoHS was the culprit. Trying to eliminate lead from a lot of consumer goods. Lead based solders are much more tolerant of abuse than lead-free solder.
  3. Jun 17, 2009 at 2:27 AM
    #143
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    If I knew how To Solder... I could jsut hang out at the dealership wait for the Temp guage problems to roll in and offer to fix it for $10 a pop.. ill be rollin in the Big $$$ in no time
  4. Jun 17, 2009 at 3:56 AM
    #144
    misc
    misc [OP] Well-Known Member
    Just get the iron hot and try to work a bead across the sections... Good luck man.
  5. Jun 17, 2009 at 6:51 PM
    #145
    sinker
    sinker New Member
    PreRunner SR5
    Thanks man! I am going to need it.
  6. Jul 5, 2009 at 3:25 PM
    #146
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    I just completed this repair after the wife told me the display was out. One of the resistors was completely off of the board and laying in the smoked lens. The other one was only held in on one end.
    I can't believe they just fall right out...
    Marc M
  7. Jul 6, 2009 at 12:34 PM
    #147
    token2k6
    token2k6 Member
    Houston, TX
    06 PreRunner SR5
    K&N Air Filter Steelcraft Taillight Guards
    Yup, I have this problem now!! Its been super hot, like 20 days over 100 degrees here in Houston, which has been causing all kinds of havoc on vehicles. I noticed mine out last week, pressed the button and it came on. However, it quickly went off again! Waited the next day, it didn't light up at start, pushed the button, it came on and then immediately went off. Now 3 days later, hasn't come on at all.
    Gonna try this fix tonight after the dealer basically laughed when i asked if the could just re-solder it (they said, "nah, we'll just replace it, runs about $1000 with the parts and labor) If it works, I will be sooooo happy.
    I'm really beginning to lose respect for my Tacoma, I suffer from the silencer-pad / leaf spring squeaking and now this of using cheap "Made In Mexico" parts really makes me question why I sprung for the "superior" Toyota brand over something else...(but maybe I shouldn't be saying this here! I really do love the truck though...)
  8. Jul 6, 2009 at 4:50 PM
    #148
    traderdell
    traderdell Member
    I have an 09 and the temp and direction are so dim they can oly be seen at night. Is there a fix for that?
  9. Jul 6, 2009 at 4:51 PM
    #149
    misc
    You're gonna have to use your warranty on that one. 1st I've heard of that...
  10. Jul 6, 2009 at 6:07 PM
    #150
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Yeah, that would be a good one... we should check with toku58. He changed out the led's in the speedo cluster - It looks very cool - I'm sure he knows how. Now all we need to do is to send him a temp panel :) (if he doesn't already have one).
  11. Jul 6, 2009 at 6:10 PM
    #151
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Johnecon2001 did this to my rig and its been glorious ever since! Great write up!
  12. Jul 9, 2009 at 9:31 AM
    #152
    911Targa
    911Targa Member
    Phoenix
    TRD Sport Pre Runner V6
    Worked like a charm , thanks
  13. Jul 9, 2009 at 6:53 PM
    #153
    glbgroup
    glbgroup New Member
    Tacoma
    Thanks to those who posted the fix. Mine went out a couple of days ago, 7/7/09, local dealer says I'm outside the 3yr/36k warranty: you guys saved me. After removing the single center screw inside my sunglass compartment, I should have pulled backwards, on the front of the overhead ceiling console, the side closest to the windshield, this contains the shallow-hook which easily drops down, then the other end, nearest the dome light, with its three massive hooks would've dropped easily. Other than that, a little solder on one of the 510 resistors and I'm operational.
  14. Jul 10, 2009 at 8:15 AM
    #154
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    here you go
    http://www.youtube.com/watch?v=BLfXXRfRIzY
  15. Jul 10, 2009 at 1:08 PM
    #155
    Danman
    Danman New Member
    Portland, OR
    06 Tacoma DC TRD Sport
    Thanks for posting this! I had the same problem and now it is working again. When it went out the other day, I knew I'd have to make a visit here and look for a solution. Sure enough, there it was...and easy too.
    After I soldered the first resistor, I noticed the burn mark on the display and I thought that I'd gotten the soldering iron too close to it. Glad to see that others have seen the same burn mark and that it wasn't due to my carelessness.
    Thanks again. This forum has saved me big $$ again.
  16. Jul 11, 2009 at 4:44 PM
    #156
    SueTBug
    SueTBug New Member
    Texas
    06 PreRunner
    Thanks a million for the write-up and the pics. My dealership told me it would cost $1000 to replace the entire console. Thanks to your write up it only cost me $15 to buy a battery operated soldering iron. I was able to make the repairs myself!!!
  17. Jul 27, 2009 at 10:03 AM
    #157
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Funny, mine just went out the other day and I knew exactly what it was... Thanks for the writeup, great find!
  18. Jul 27, 2009 at 3:11 PM
    #158
    Inspector Clouseau
    Inspector Clouseau New Member
    4x4 off road
    Thanks for the excellent information and photos. One of the 510 resistors had a broken solder joint.
    I have a 2007 Tacoma. That's been the only thing that's gone wrong at 58,000+ miles.
    Thanks again.
    Inspector Clouseau
  19. Jul 28, 2009 at 7:52 PM
    #159
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Fixed mine tonight. I didn't see any broken solder joints but like others, I decided to go ahead and solder the 510 resistors. Put it back together and it worked!
    Just a little game but those who fixed their console, post your temp reading. Haha..
    Mine was 94 (this is at 8 pm tonight...yeah that's Houston weather).
  20. Jul 30, 2009 at 8:54 AM
    #160
    Mountainwolf
    Mountainwolf Well-Known Member
    N.GA mountains
    05 TRD OffRoad & 17 TRD Pro
    Just did the fix this week. Thanks for the write up. My observations:
    1. These resistors are smaller than they look in the pics on this thread. Soldering such a small seam was kinda challenging for a first timer like myself. Looks ugly, but it worked.
    2. If you do the soldering & plug the unit back it & nothing comes on... hit the button. Mine was turned off & I thought the fix didn't work for me until I hit it.
    3. Do it for under $10. Go to Radio Shack & buy their Soldering kit. It contains the soldering pen, clamp, tool, and some solder. Their kit is made for electronic repairs. This kit costs $7.99
    4.** VIP** Most importantly people: Do not rely on this temp gauge for road conditions. The gauge typically reads warmer than actual temp. Last year, my gauge read 38 deg. F when I hit black ice... several 360's and over 10K in damage later... here I am to warn you.
