Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Sep 8, 2014 at 5:43 PM
    #1661
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
    Redo it after I fixed mine it broke again. Redid it and worked again. When you redo it add a little more sodder to all the connections
  2. Sep 9, 2014 at 8:06 PM
    #1662
    Taco Mark86
    Taco Mark86 Well-Known Member
    Mark
    NC
    09 DCSB with some mods
    Magnaflow, Fox RR/ Camburg UCA up front, Bilsten 5100 and some kind of AAL/ leaf pack in the back?, Light bar w/ Hella, and an air freshener
    Re-did the "510"s and it works again, one of them looks like shit though. I understand the concept of heating the metal then melting the solder on but its such a small metal surface to heat for that connection. Maybe I just suck at it.:rolleyes:
  3. Sep 13, 2014 at 2:33 PM
    #1663
    GIJohnnyB
    GIJohnnyB Well-Known Member
    Johnny
    Colorado Springs, CO
    08 SR5 Sport 4x4
    Great thread! Fixed mine.
  4. Sep 14, 2014 at 8:09 AM
    #1664
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I wonder if using some thermal paste and a small heatsink would stop the issue from happening again.
  5. Sep 14, 2014 at 9:49 AM
    #1665
    Jsully
    Jsully New Member
    Arizona
    07 SR5
    I will be trying the paste.
  6. Sep 14, 2014 at 10:16 AM
    #1666
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Using the radial type resistors would take care of the issue of heat as they are larger in heat capacity than the SMD resistors from the factory. A healthy glob of solder along each side does aid in cooling too.
  7. Sep 18, 2014 at 5:00 PM
    #1667
    BlueTaco
    BlueTaco Well-Known Member
    Long Beach, CA
    08 Tacoma Speedwayblue
    Woohoo! Just pulled my truck out of 3 year storage and mine wasnt working. Never soldered in my life but fixed it!
  8. Sep 25, 2014 at 12:21 PM
    #1668
    WhyNotFab
    WhyNotFab Well-Known Member
    Ricky
    Florida
    '08 TRD Off Road
    Noticed mine wasn't workong the other day but couldn't remember how long it had been broken.. Googled & found this topic on the forums, even a video on YouTube.. Bought a $5 solder iron & some solder, spent 5 minutes removing console & circuit board, then soldering & it works again! Awesome tip!
  9. Sep 30, 2014 at 10:12 AM
    #1669
    Zachary Levi
    Zachary Levi Member
    Levi
    Virginia
    TRD Off Road, SR5, 6 speed
    brush guard w/ wrap around, bed extender
    my display doesn't work as well, would there by anything else that would cause the temp/comps to not work? just asking before i start taking things apart
  10. Sep 30, 2014 at 3:24 PM
    #1670
    45longcolt
    DFW Area
    2020 Off Road
    Most likely both resistors need a bead of solder along each side.
  11. Oct 4, 2014 at 5:25 PM
    #1671
    replica9000
    2019 T4R ORP
    Attempted to re-solder mine today. No luck. It's been over 10 years since I've soldered anything though. Seemed like I was getting the old stuff to melt, but it would just harden without making a connection. I ended up sacrificing an old RAM stick for one of the ceramic chips to keep pressure on the two 510 resistors. I'll see how long this 'fix' lasts.
  12. Oct 4, 2014 at 5:33 PM
    #1672
    Coop42
    Coop42 Active Member
    Don
    Long Island
    2016 TRD off road
    Pulled mine down to fix it. Unfortunately, one of my "510"s is gone. Off to silicon method it went.
  13. Oct 5, 2014 at 10:49 PM
    #1673
    PilotDen
    PilotDen Member
    Long Beach, CA
    95 Pickup
    If you can't find the right resistor to replace a "510" 51 ohm resistor, grab a 1/4 w 47 ohm resister at radio shack and solder it in. See my photos on p 68-69 here. Repair good and going on two years now.
    Shamal likes this.
  14. Oct 6, 2014 at 7:55 PM
    #1674
    Blue Hooligan
    Blue Hooligan Well-Known Member
    Winnipeg
    2017 Black Tacoma TRD Sport
    Just did both of mine, what a pain in the ass.
    One resistor was completely detached, I guess I was lucky to find it. It was pretty tricky getting it to stay in one place to solder the first side, but I managed to hold it with a piece of rubber left over from my leaf spring gasket and a clamp.
    Those things are so tiny, soldering job ended up looking like shit but it was solid and effective.
  15. Oct 15, 2014 at 3:56 AM
    #1675
    Sarah
    Sarah Member
    Sarah
    Blue Tacoma trd sport and 1984 black land cruiser
    Thank you very much for this info!! My 2008 tacoma just did this. I'm going to try to fix it
    Thanks again:)
  16. Oct 15, 2014 at 8:41 AM
    #1676
    oldstick
    oldstick Medicare Member
    GA
    Gonna add one more vote that the right way to permanently fix this resistor problem is to remove the two surface mount 510s, cleaning off all the old solder and replace with two of the standard axial style ones. The ones with wires on each end. This will get the resistors up and off of the board plus they probably will have a higher rated heat/power disipation limit. The Radio Shack 47 Ohm ones mentioned previously do.
    I believe that the member on here offering to fix these for a nominal charge is doing exactly that and his is very reasonable price for someone like me that is not experienced with soldering.
    In my case, a friend who is a master level electronics technician fixed mine after I had gone through the quick fix twice. He even replaced the 2 510s with 3 x 75 ohm resistors (yielding the same 25 Ohms as 2 x 50). So that splits the total current three ways for even greater margin.
  17. Oct 15, 2014 at 1:14 PM
    #1677
    Sawspatch
    Sawspatch Active Member
    San Diego
    "11 pre runner SR5 4-cyl.
    I fixed the one I have with this tip. Thanks!!! When I was looking for a bad solder I could see a bad connection. So I soldered the 510 resistor anyway. So , even it if seems fine, hit it with the soldering gun anyway. Thanks so much!
  18. Oct 15, 2014 at 8:22 PM
    #1678
    dvd0020
    dvd0020 Well-Known Member
    Dave
    Colorado Springs
    08 Off Road Double Cab
    TRD supercharger, 4.88 Nitro gears, Doug Thorley long tube headers, aFe stage II intake, Pro Comp 6" DB lift (Icon Coilovers, Alcan 6" Springs, Bilstein RCD rears), NST lightweight pulleys, Morimoto mini projector retrofit for Spyder headlights, Cobra CB, 4' Fire stick, Pioneer AVIC-U310BT head unit, 2 10" alpine S, CBI Moab 2.0 front bumper, Smittybilt XRC8 winch, NFAB tire carrier, custom Colorado pinstripes
    Just did the fix for the second time on mine after (had some practice with soldering the second time). Worked for a day, then went out again. I know I have a good solder joint. Not sure why it went out for good... again...
    Can the resistors go bad or something?
  19. Oct 16, 2014 at 4:49 AM
    #1679
    oldstick
    GA
    I believe they can after a while. Pretty sure one of mine was bad because we couldn't get a good Ohm reading through it and it was darker looking on the outside. From what many others have said above, the 510s are very marginal heat capacity for the amount of current being put through them with this circuit design. Evidenced by many folks reporting they get VERY hot.
    Sounds to me like best case, for almost everyone reusing the original 510s, is the solder joints come loose again and again. I know mine did at least twice with me and I also found evidence the previous owner might had taken the display out at least once.
  20. Oct 16, 2014 at 9:20 AM
    #1680
    Sarah
    Sarah Member
    Sarah
    I have a couple of 47 ohm and 52 ohm
    I guess I should use the 47's?
