Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Nov 12, 2014 at 9:40 AM
    #1701
    timify
    timify Member
    I fixed my temp/compass in 20 minutes...resistor was not connected to circuit board. Easy fix. Thanks
  2. Nov 14, 2014 at 4:19 PM
    #1702
    QM1SWMAC
    QM1SWMAC New Member
    Indiana
    2007 Tacoma TRD 4x4
    Hand Grips, bed cover
    This fix worked like a dream, in less than 10 minutes, I was able to repair this as described. Thank you :)
  3. Nov 15, 2014 at 2:06 PM
    #1703
    chop
    chop Well-Known Member
    byron
    British Columbia
    08 Tacoma 4x4 dclb TRD Sport 4.0L
    3"lift , arb front bumper,ome 886 coils, icon xrt leafs goodyear duratraxs firestone air bags
    my resistor (510) was missing all together ? i could only find 56 ohm 1/4 watt resister,
    will this be ok it seems to work
  4. Nov 15, 2014 at 2:51 PM
    #1704
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    That's close enough, the added resistance will cause a little more wattage pull but the resistor itself can radiate better than the SMD's do so I bet you will be OK.
  5. Nov 16, 2014 at 7:44 AM
    #1705
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Gona test unit before i put the solder iron to it, we shall see how this goes.
  6. Nov 16, 2014 at 7:01 PM
    #1706
    youngcd200
    youngcd200 Member
    Cole
    Sevierville, TN
    Red 08 4wd TRD sport
    Just fixed this issue, today. Took a little longer than expected because I accidentally melted one of the 510s off the board as I was adding solder to the other. :mad: Eventually got it back on. Its fugly but it's working! Thanks for the info!
  7. Nov 16, 2014 at 7:49 PM
    #1707
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    Which size resistors do I need to replace the 510 resistors? One of two melted on my overhead compass/temp gauge
  8. Nov 22, 2014 at 12:26 PM
    #1708
    ArmyRetired
    ArmyRetired Member
    2in Lift
    Please....post where I can order these resisters....mine came off completely and is gone.
  9. Nov 22, 2014 at 5:38 PM
    #1709
    wtjl240
    wtjl240 Well-Known Member
    Jeff
    Spring Hill, TN
    Mine went out 3 days after I bought my truck. My dad and I soldered the 510's back and tested but it still didn't work. I thought 'Oh well, it's already broken so no big deal'. Plugged everything back up and realized my dumbass never pushed the button. Turned it on and it worked! Thanks for the great write up.
  10. Nov 29, 2014 at 8:47 PM
    #1710
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Quick question for you guys, mine is out but if I hold the button it will come back on for a little bit and then the screen will go black again. Think the fix will work for me?
  11. Nov 29, 2014 at 9:48 PM
    #1711
    45longcolt
    DFW Area
    2020 Off Road
    More than likely, Yes. When you hold the button you are flexing the PCB the resistors or on. That makes them contact the solder pad and it works then. Do the fix.
  12. Nov 30, 2014 at 5:15 AM
    #1712
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    This is exactly what mine did before it went out.
  13. Nov 30, 2014 at 11:06 AM
    #1713
    tacomakid96
    Phil
    Out n' about
    Ok thanks guys I'll hit it right now
  14. Nov 30, 2014 at 11:06 AM
    #1714
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Same here
  15. Nov 30, 2014 at 11:40 AM
    #1715
    tacomakid96
    Phil
    Out n' about
    Ok I only have a large solder tip and I burnt the front side of the board a little bit.. I plugged it in and it works again, but the 510 gets a little hot if I hold my finger on it. Should I worry or just put everything back together?
  16. Nov 30, 2014 at 11:52 AM
    #1716
    replica9000
    2019 T4R ORP
    Eventually it may fail again. It's happened to several people. The resistors get very hot. When I was testing mine, I was putting pressure on one of the resistors with a retractable pen. The heat was enough to melt the pen.
  17. Nov 30, 2014 at 2:17 PM
    #1717
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Last weekend we bought our son a 06 & the compass/temp wasnt working. Today I took it apart & sure enough 510 was about standing straight up. I pushed it back down to tested it & it worked so I soldered it & all is good now thanks to this write up.
  18. Dec 3, 2014 at 11:06 AM
    #1718
    Sg5845
    Sg5845 Well-Known Member
    Atlanta, GA
    2008 Tacoma TRD OffRoad Edition
    Getting ready to sell the 2008 Taco and overhead compass wasn't working. Saved me big money! I know this is an old thread so here are a couple of up close pics of the broken resistor in case you are looking for them!
  19. Dec 7, 2014 at 9:58 AM
    #1719
    rockstardoug
    rockstardoug Member
    knoxville
    21 TRD
    Thanks for the info. Spent $20 at radio shack for soldering iron and solder. Fixed in 20 minutes! Thanks
  20. Dec 11, 2014 at 11:53 AM
    #1720
    walkman71
    walkman71 Active Member
    Aaron
    Las Vegas
    08 PreRunner TRD OffRoad
    Pulled the console off checked both 510 resistors. Cracked at the solder joint. Hit it with more solder. Re-Installed everything and BAMM, works like brand NEW. Check youtube for helpful videos if necessary.
    https://www.youtube.com/watch?v=OGZ07QGwYCY
    Shamal likes this.
