Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Dec 17, 2014 at 4:24 PM
    #1721
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
    A reminder to the folks about to resolder the surface mount resistors:
    1.) make sure the solder doesn't bridge, especially to the through-hole next to one of the resistors. (the small, round copper areas). This is a board-destroying short.
    2.) I strongly recommend you follow my DIY guide here. If you don't, your repair is going to fail again at some point in the not-so-distant future. The old resistors are oxidized and won't re-mount well.
    3.) solder quickly; Heat from the iron may be damaging other components nearby. Press the clean, tinned iron to the junction of the board and resistor and immediately feed solder. You should get a nice shiny fill.
    -greg
    Hellmutt and Shamal like this.
  2. Dec 21, 2014 at 3:55 PM
    #1722
    AZM9
    AZM9 Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    Worked perfectly and now it works again. Thanks for the post.
  3. Dec 27, 2014 at 7:13 PM
    #1723
    MikeLima
    MikeLima New Member
    Dealer wanted $900+to repair, so I checked it out myself (non-technical). My board looked like an ADHD first grader missing a few doses of adderall had soldered those 510's. It was bad with visible burn marks to the wafer and LCD;bad enough to have doubted this would work... For 15 min of work, works like a charm. Couldn't be happier with outcome. Thanks a million!
    Thanks for pulling me out of lurking...
    -ML
  4. Dec 27, 2014 at 7:17 PM
    #1724
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Isn't a new part only $200 if that?
  5. Dec 28, 2014 at 8:31 AM
    #1725
    Siliconmethod
    Greg
    MO
    Replica9000: yep, the new display is less than $200 (I sell them for $159 if a unit sent in to us is not repairable)....I'm guessing (hoping) that the $900 dealership part includes the entire overhead console.
    Of course, the whole shebang still isn't worth $900...and the dealership should know better than to upsell.
  6. Dec 28, 2014 at 9:28 AM
    #1726
    replica9000
    2019 T4R ORP
    When I was looking for sport headlights, the parts guy at the dealer said they charge $100 more per headlight on top of Toyota's MSRP. Luckily I found a local member selling his cheap.
  7. Dec 31, 2014 at 12:01 AM
    #1727
    andlours
    andlours Well-Known Member
    Andy
    Denver, CO
    09 TRD Offroad
    I've always seen this thread and just kinda hoped this problem would never happen to me. My temp/compass started fading and then eventually went out. Bought a 10 dollar soldering iron and went to town tonight on fixing it. Super easy mod. Just takes a steady hand and a close eye. Thanks for all the great info guys.
  8. Dec 31, 2014 at 12:06 AM
    #1728
    refugee
    refugee Member
    Allan
    Missouri
    08 TRD, Off-Road, Access, 4X4, 4.0L
    I used the info in this thread to fix the thermo/compass on my 2008. I t worked for a couple weeks and then gave out again. So I redid the repair and its been working again for a couple of weeks. Thanks for the info!!
  9. Dec 31, 2014 at 1:20 PM
    #1729
    MikeLima
    MikeLima New Member
    Yes, dealership pricing for the entire board/console. When I laughed and said I'd let it stay dark, upon checking out, he discreetly suggested I check the Internet for solutions. Seems to have worked out.
  10. Jan 13, 2015 at 12:14 PM
    #1730
    oldstick
    oldstick Medicare Member
    GA
    +1 on the above. Do the permanent fix as Siliconmethod suggests above using standard twin wire resistors. Or find a good electronics repair person to solder them in for you, like I did. The original 510 type get WAY too hot due to their tiny size.
    Otherwise they will fail again and again.
  11. Jan 24, 2015 at 8:01 AM
    #1731
    Va Bowhunter
    Va Bowhunter Well-Known Member
    Shawn
    VA
    05 Tacoma TRD
    ABS winch bumper, 8,500 smitty built winch
    i just called our local Toyota dealer and ask about a new display.
    they said that it had to be ordered and would cost $145.00.
    i thought i would try the search on here to see if anyone else had the same problem.
    the search brought me to this thread.
    within a few minutes i had my display working like new!!!!
    you guys are great. Thank you very much!!!
  12. Jan 24, 2015 at 4:04 PM
    #1732
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  13. Mar 9, 2015 at 1:46 PM
    #1733
    Mickey2015
    Mickey2015 Member
    Tacoma TRO/SR5
    I USE YOUR INSTRUCTIONS MISC AND NOW MY COMPAS TEMP GAGE WORKS THANKS
  14. Mar 16, 2015 at 9:54 AM
    #1734
    03hdfatboy
    03hdfatboy First Gen 4Runner Driver
    Arizona
    Stock Taco
    Nice post. Gonna try it. Thank you
  15. Mar 16, 2015 at 10:33 AM
    #1735
    03hdfatboy
    Arizona
    Stock Taco
    Worked like a champ. Took longer to find my solder than To fix it. Thanks again
  16. Mar 28, 2015 at 6:23 PM
    #1736
    Jsully
    Jsully New Member
    Arizona
    07 SR5
    Thanks for the simple explanation. Took me 20 minutes and a touch of solder.
    2007 SR5 crew cab 4x4
  17. Mar 31, 2015 at 5:44 PM
    #1737
    Sherpa
    Sherpa Active Member
    Jim
    Livonia, MI
    05 TRD OffRoad
    Continental Cap, Yak basket, bull bar, Toytec Ultimate lift & BFG T/A KO's
    Did the quick fix on my 05 and it worked. Hope to get 10 years this time too. If not it looks like the twin wire works best and I will try that next.
  18. Apr 18, 2015 at 1:12 PM
    #1738
    CanuckPT
    CanuckPT Member
    Damon
    West Chestefield, NH
    2006 Tacoma Sport
    ARE Cap with Yakima Rack Sno Way Plow Curtiss Speed Cast Sander
    This is my 2nd time doing this repair. Just had my frame & leaf springs replaced & my compass/thermometer had just puked out again prior to me taking it in. The offered to replace it for only $250 (I told them they offered to do it for $800 the last time a 3 or 4 years ago!). In any case, I'm patting myself on the back for fixing it once again!!
  19. Apr 21, 2015 at 7:18 AM
    #1739
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Same here. Just took a few trys to figure out they best technique. What worked for me was a drop of solder at each connect point on the board then lay the resistor on top, heat each end while applying a little pressure to the resistor to keep it in place while the solder liquifies and re-solidifies. Just did it last night so we'll see how long it lasts.
    Saved that Amazon link (from MJonAgs32) a few posts back for future reference. Note the price is down to $109 from $138 that was mentioned a few months ago.
    http://www.amazon.com/dp/B00BUSOKBQ/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=30U3K6KZ30H8D&coliid=I22502E4HF2OW7
  20. Apr 25, 2015 at 2:51 PM
    #1740
    SIKWAY7
    SIKWAY7 Active Member
    mark
    washington
    Tacoma Sport 09
    k&n air ram/filter- trd catback exhaust- trd quick shift- bilstein 5100- cb mod-flashlight mod-hella 500 lights- -trd skid plate-trd shift knob-igge black seat covers-dynamat floor,doors and back wall-etc.
    Well, gave it a shot. FRICKEN HELL'YA!!! Worked for me. THX$$$!!!
    CanuckPT likes this.
