Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Jul 14, 2015 at 2:29 PM
    #1761
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    The pics aren't working for me , if someone could help me view them it would be helpful.
  2. Jul 14, 2015 at 4:50 PM
    #1762
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    After 9 years mine is starting to crap out. I have to tap it for it to come back on.
  3. Jul 14, 2015 at 6:46 PM
    #1763
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I just added some more solder to the area where it had burned out. I used the kind to repair eyeglasses and electrical boards with. It has been working for the past year with no problems. Beats paying money for the dealership to do the same thing.
  4. Jul 15, 2015 at 12:33 PM
    #1764
    06tacodude
    06tacodude Well-Known Member
    IG: @go_nesw
    Morgan Hill, CA
    06 TRD Sport 4x4
    Icon Stage 4, TC UCA, K&N filter, SG-II, Relentless Fabrication bumpers, RCI Sliders and tank skid, BajaDesigns LED, URDMAF, 4.56 Yukon Gears, Rear ARB locker, ARB dual air compressor, RLD cap, Prinsu cab rack, FNWheels Six Shooter.
    I did this fix 4yrs ago; now doing it again. I looked at the bad solder and saw heat stress. So after doing the fix, I plugged it into the truck harness and powered it on. The two 51Ohm (510) resistors operate very hot to the touch. Anyone else observe this? This is most likely the cause of these solders breaking; especially during the heat of the summer.
    If these solders burn off again, I'll be looking into the same 51 Ohm but higher current rating; unless it is a bad circuit design.
  5. Jul 15, 2015 at 12:36 PM
    #1765
    Jocoma
    Jocoma Well-Known Member
    Jo-mama
    Olympia,WA
    08 Prerunner SR5 Rugged Trail
    Home made satochi trd grill BFG AT 265 75 16 Dipped badges TRD stub antenna More to follow : spindle lift,Halo lights, Kicker sound sytem ,Slotted rotors TRD Seat covers When the cash starts flowing
    Dude this saved me money Thank you!
    This was actually the only thing wrong with my truck when I 1st bought it.
  6. Jul 15, 2015 at 12:39 PM
    #1766
    06tacodude
    IG: @go_nesw
    Morgan Hill, CA
    06 TRD Sport 4x4
    This is what I am planning next time around. Are those 1/4Watt or 1/2Watt resistors? Do you know if they were running hot similar to the 510SMD component?
  7. Jul 15, 2015 at 1:22 PM
    #1767
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
  8. Jul 22, 2015 at 7:47 AM
    #1768
    dcballer07
    dcballer07 New Member
    2006 Speedway Blue Tacoma 4WD TRD Offroad DCSB
    Rough Country 3" Suspension Lift 18" Black Havok 103 wheels 33" Atturo Trailblade M/T Tires Blacked Out Grill Blacked Out Rear Bumper Tinted Front & Side Windows
    I completed the fix last night. Compass and Temp is now back online. So glad I did the research!
    btw, I am new on this forum. I will get pics and specs of my truck up soon.
  9. Jul 31, 2015 at 9:54 AM
    #1769
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    Worked great, took all of 10 minutes to complete. I went ahead and just replaced the resistor with a new one. Too easy.
    CanuckPT likes this.
  10. Aug 1, 2015 at 8:31 PM
    #1770
    reynoldsrr63
    reynoldsrr63 New Member
    Sweet Home, OR
    2008 Dark Blue Tacoma TRD Sport
    Well I've seen how to fix this issue, I have a little bigger problem. One of my 510 resistors isn't lose it's gone. So where might I find one?
  11. Aug 7, 2015 at 10:36 PM
    #1771
    TRDTACOMA453
    TRDTACOMA453 Member
    08 TRD OFFROAD Access Cab
    3" Lift, 285-75-16 Yokohama Geolander Mt's on Ivan Stewart TRD Wheels
    I found out about this fix a couple of years ago and went ahead and tried it. I soldered the 510 resistors and my temp/compass came back for a few days but disappeared. I went in there again and cleaned up the resistors/board and soldered them. Again, it worked for a couple of days and went again. Not sure whats going on but I'm going to live without, as I am not paying for a dealership replacement.
    Anybody fix it for good?
  12. Aug 9, 2015 at 7:32 PM
    #1772
    whiteshoes07
    whiteshoes07 Active Member
    2007 Tacoma Access Cab.
    Mine has been fixed for over a month and no issues. And its been over 100 degrees for over 2 weeks straight
  13. Aug 10, 2015 at 11:57 AM
    #1773
    06tacodude
    IG: @go_nesw
    Morgan Hill, CA
    06 TRD Sport 4x4
    Check out Post#1745. That's what I did the second time my compass stopped working.
    I ditched those 510(1/4W) SMT components and picked up some 51 ohm 1/2Watt PTH resistors. The 510 components were running really hot which was breaking the solder joints ... the 1/2W replacements was able to handle the circuit current better and not get as hot.
    I did the fix on 7/24 and drove through and parked under 97F weather and so far so good.
  14. Aug 19, 2015 at 6:29 AM
    #1774
    Mikeinga
    Mikeinga Member
    White, Georgia
    08 Prerunner TRD offroad
    JVC stereo,
    My 08 went out a few weeks ago, my resistor wasn't sticking up or anything but the solder was thin to nonexistent on one side. Dabbed a bit of solder and works like a charm. Thank you for this fix y'all.
  15. Aug 19, 2015 at 9:43 PM
    #1775
    s brake
    s brake Well-Known Member
    2005 Double cab short bed TRD
    Just did this and it worked great. My soldering skills suck big time but it did the job. Just need to calibrate the compass now, my thermometer is off by quite a few degrees but I don't think there's anything I can do about it.
  16. Aug 26, 2015 at 2:25 PM
    #1776
    shitgoose06
    shitgoose06 Well-Known Member
    Goose
    Aspen CO
    2008 Tacoma TRD
    885 coilovers Bilsine 5100's "50 Cree LED light bar Rago Fabrication 50" curved light bar mounts 33" Goodyear Wrangler duratrac Tepui kukenam tent Thule Podium roof rack, 58" bars Thule Traverse 480, 58" bars Yakima crash pad Snug top Topper w/ rails Custom built sleeper and lockable bed storage Pelfrey built hybrid bumper 20" Black Oak LED combo light bar w/ amber covers 2 Black Oak LED work pods 3 watt amber bulbs
    Just did this fix, took 15 min. Easiest fix by far, amazing forum!!! Saves you a expensive fix through Toyota and takes little to no effort.
  17. Aug 26, 2015 at 2:44 PM
    #1777
    GoldenGeek
    GoldenGeek Well-Known Member
    Brandon
    Oro Valley, AZ
    I got my overhead compass repaired after trying and failing myself. I thought mine was totally fried, but they repaired it to factory spec!
    $17 + shipping (one-way)
    http://modulemaster.com/
  18. Aug 27, 2015 at 11:57 AM
    #1778
    thud1
    thud1 New Member
    Travis
    2008 tacoma double can 6speed
    Mine wasn't working last night then it came on today but I stilled pulled it to try and re solder the 510's and now it's not working when I plug it back in. Any ideas?
  19. Aug 27, 2015 at 12:45 PM
    #1779
    GoldenGeek
    Brandon
    Oro Valley, AZ
    here's the post I made RIGHT before yours..lol
    The price might have gone up but I found their post on eBay, which might be why it was cheaper than it is now on their site ($25 + shipping)
  20. Sep 2, 2015 at 5:18 PM
    #1780
    a.s.
    a.s. Well-Known Member
    Stack
    NY
    Silver '07 DCSB Sport
    KO2s/5100s/Eibachs/TRD
    After 4 years of looking up at a blank screen I finally fixed it using the excellent instructions posted on the first thread.
    Thank you! Thank you! Thank you!
