Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Oct 13, 2016 at 1:55 PM
    #1861
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    but installing new resisters wont keep them from coming unsoldered from the heat would it? I think one might need a more heat resistant solder or some such. eh?
  2. Oct 13, 2016 at 2:33 PM
    #1862
    ickthus
    ickthus Well-Known Member
    DAVID
    MOBILE,AL
    OC
    2.75BL5100'S/UNDERCOVER
    using a different resister seems to be helping
    bluezzy[QUOTED] likes this.
  3. Oct 14, 2016 at 10:00 AM
    #1863
    just2wd
    just2wd Well-Known Member
    Dan
    California
    07 PreRunner TRD Off Road
    sub'd . going to try this. had mine fixed a few years back by my dads friend but it seems to have stopped working again. BTW the images in OP are not visible
  4. Oct 14, 2016 at 1:27 PM
    #1864
    jasonm
    jasonm Member
    Virginia
    07 TRD Sport
    Truxx Leveling Kit, 285 70 R17 MTR's, K&N Intake, Throttle Body Spacer, Pioneer Touchscreen Media Player.
    what happened to the images attached to this post?
  5. Oct 17, 2016 at 8:06 PM
    #1865
    007dawg
    007dawg New Member
    Kirk
    Fort Worth, TX
    2005 PreRunner Double Cab, TRD OffRoad
    So I really didn't want to dig through 94-pages of this thread, but I did dig around a bit before posting. My issue is a bit different.
    A few years ago, I repaired the solder joint and all has worked fine, until one day the unit just failed to display - again. I can cycle the button to change from F to C repeatedly, and the direction / temp will display temporarily ... until it then fades back to being off again. Is anyone else having this specific problem?
    Thanks in advance?
  6. Oct 23, 2016 at 7:36 AM
    #1866
    oldstick
    oldstick Medicare Member
    GA
    It could be a different issue, but just as likely the same one. It seems to be very common to have repeat occurrences until the resistors are actually replaced with ones that don't get as hot. The micro-size packaging of the original resistors don't have very much volume or surface area to allow dissipation of the heat.
  7. Oct 23, 2016 at 7:42 AM
    #1867
    oldstick
    GA
    The heat is generated internally to the resistors with current flowing through. The ones recommended for replacement are stouter, for better heat handling plus they have wire leads which raises the resistor at least a few millimeters above where the solder joints are. So less heat gets to solder joint area.
  8. Oct 23, 2016 at 8:14 AM
    #1868
    bluezzy
    Monty
    Eugene, Oregon
    Oh sure, I was having trouble understanding how just the heat from the sun was doing the damage... make all the sense in the world now, thanks... ;)
  9. Oct 23, 2016 at 8:16 AM
    #1869
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Also using a better solder seems to help. The consensus is the lead-free solder is garbage.
  10. Oct 26, 2016 at 5:16 AM
    #1870
    oldstick
    GA
    Yep, one shortcoming with the "PC" lead free solder, from what I've read, is a tendency to chemically develop very tiny "whiskers" over time. This is a real problem in today's circuits with thousands of micro sized components crammed onto a single board. Only takes one of these to reach over and touch the next component then you have a short. Think of how much electronic wizardry is packed inside your phone.
    bluezzy likes this.
  11. Nov 8, 2016 at 12:07 AM
    #1871
    TacoGrizz
    TacoGrizz Tacos, Bikes N Beers.. nuff said
    Montana
    Black 2006 DCSB Tacoma TRD OFF ROAD
    Suspension: All Pro Off Road Sport Kit w/Bilstein 6100 series front and back w/ an AAL Icon UCA's SCS Wheels RockBlokz mud flaps Leer canopy (used) MGM grey, it doesn't match but still looks good Thats all the visible stuff. Lots of other little goodies in the bed and interior.
    My temp gauge was not working as well so I figured what the heck. Followed this step by step went out and bought a small soldering tool and with zero soldering experience I dabbed on a bit of solder and put it back together. Voila!!!! Thanks for the info!
    TruckGuy916, bluezzy and Fitz235 like this.
  12. Dec 7, 2016 at 2:10 PM
    #1872
    Plumbgod
    Plumbgod Member
    05 toy Tacoma
    Rear air bag lift, front over the coil lift
    Thank you. I did this & it went perfectly. I did have to tin both ends of the resistor as the floating the solder would not take. BTW my resistor fell completely out. Lucky I recovered it.
    Now to find the vibration in the front end. Seems to be after the 2" lift & goes away when I put it in 4h. Some one mentioned a diff bearing.
  13. Dec 14, 2016 at 2:27 PM
    #1873
    Red09Tacoma
    Red09Tacoma Member
    Mass
    2009 Tacoma
    I re-floated the two 510's and still nothing. I must be missing something.
  14. Dec 14, 2016 at 3:24 PM
    #1874
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    It's possible the resistors themselves are bad
  15. Dec 20, 2016 at 4:58 PM
    #1875
    agolden23
    agolden23 Member
    Anthony
    2006 Tacoma TRD Access Cab, 6 Speed, Stock
    2016 TRD Pro Wheels and Tires, Otherwise Stock
    Did this fix today, great info!!
  16. Dec 28, 2016 at 5:33 AM
    #1876
    g r e e n
    g r e e n Member
    Fixed my problem. If you see three dashes instead of temp and compass works good check wiring to temp sensor. In my case one wire was almost torn off. After soldering it back all I can see outside temp.
  17. Dec 28, 2016 at 8:29 PM
    #1877
    just2wd
    Dan
    California
    Just finished this fix. thanks OP!
  18. Dec 28, 2016 at 9:12 PM
    #1878
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    so is this compass / temp display worth having? I have a 2nd gen and it came with no display. So i was searching and found the gentrex mirror with dimming, compass and temp. Was wondering if that would be a way to go instead of the display. thoughts / opinions?
  19. Dec 30, 2016 at 10:41 PM
    #1879
    Caveman999
    Caveman999 New Member
    Cave
    2012 double cab 2005 access cab 96 extended cab and a 2001 extended cab that kind oif lives here
    just tires and a couple of small lifts
    Sounds cool any links ?
  20. Jan 7, 2017 at 9:33 AM
    #1880
    cory2121
    cory2121 New Member
    My 2009 Tacoma does not have the sunglass holder. How do I remove the overhead console?
