Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Jun 18, 2017 at 2:57 PM
    #1941
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    There is a video on YouTube.search removing compass tacoma. It clearly shows the clips.
  2. Jun 18, 2017 at 3:57 PM
    #1942
    motorhead1257
    motorhead1257 Well-Known Member
    Les
    WNC
    Casper
    None yet
    Thanks guys, I went there and then ran out real quick and did it. However, when I was trying to solder the Dang thing in on the edges 1 of them slipped loose cause I was shaking really bad and knocked off the board completely. So, I had a piece of chopstick I used to hold it steady in place and had my hand resting on the counter top in the kitchen with my hand pressing against the Microwave to steady my hand then just touched the soldering iron to it a couple of times and said to myself, "heck with it, it will work or it won't. Hahaha, it worked just fine. Thanks again, for making my day. So, if anyone had to deal with this, don't sweet it, I don't think you can mess up too awfully bad after what I did to it before it got soldered in place, LOL.
  3. Jun 23, 2017 at 3:07 PM
    #1943
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Every summer mine goes out and it always need to be resoldered. Then it's fine for the rest of the year. Starting to think the resistors themselves should be replaced. I've done this fix 3 times now but haven't done it again yet. Figured since I have to do it again I'll just replace the resistors but can't find any that style. Anyone have info on where to find them?
  4. Jul 11, 2017 at 7:59 PM
    #1944
    bra
    bra Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Just thank you guys for that it works!!
  5. Jul 12, 2017 at 4:24 AM
    #1945
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Radio shack
  6. Jul 12, 2017 at 4:55 PM
    #1946
    Fiend13
    Chad
    Ain't got none. All of ours shut down. I got it fixed though. Thanks for the tip anyway!
  7. Jul 12, 2017 at 5:07 PM
    #1947
    802yotoclmbr
    802yotoclmbr Member
    Eric
    Upton, ma
    09 TRD Off Rd
    3" OME, AEM brute force, AJT design shift knob, shorty atena, atx crawl wheels, cooper discover stt pro's
    Mine went out about 4 years ago after removing the circuit board the breaks were very easy to see. I simply gave it a quick solder and has been great ever since
  8. Jul 13, 2017 at 4:00 PM
    #1948
    Bluebaron7
    Bluebaron7 Well-Known Member
    Augusta, GA
    2009 Tacoma Double Cab TRD Off-Road(Sold)/2024 4Runner ORP
    3 Inch Lift, Leaf spring pack, SPC UCA's, Bilsteins 5100's, AFE CAI, ECGS Needle Bearing, CVJ Axles, Under seat Infinity Sub & 4 channel amp, softtopper, decked system, prinsu roof rack, Kenwood deck & Infinity speakers all around with door matting, taco sauce only sticker, steering wheel leather wrap and dash cam.
    Thank you OP or whomever posted this fix! All I did was go to Harbor freight and pick up a soldering iron and some solder and follow the simple instructions and it is working again.
  9. Jul 13, 2017 at 7:25 PM
    #1949
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I have soldered mine a few times now, I get about a month and it stops working again. Pain in the ass, I solder it imo well but it never lasts. You can only hold the iron there until the solder melts then gets sucked into the connection. That's how soldering works as far as I know!
  10. Jul 13, 2017 at 7:37 PM
    #1950
    roadking1
    n.j.
    Send it away to get fixed. Less than $20.00 and be done with it
  11. Jul 14, 2017 at 3:30 AM
    #1951
    Northern Taco
    Not from Canada.
  12. Jul 24, 2017 at 7:37 PM
    #1952
    Shoot2live4286
    Shoot2live4286 Well-Known Member
    Tim
    2009 v6 trd sport tacoma 4x4
    Cold air intake
    I have a unique situation with my second gen on the overhead, every time I start my truck or if I'm driving for a bit, it always turns off by itself. Still works, just an annoying little issue. Any suggestions what it could be?
  13. Jul 24, 2017 at 8:28 PM
    #1953
    roadking1
    n.j.
    Mine did that for a few months and then stopped working completely. I sent it to the repair service on eBay and it is good to go.
  14. Sep 14, 2017 at 1:06 PM
    #1954
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Just finished doing this repair 2 minutes ago. Did it once before a few years back. It's even easier than I remember it being the first time. If you know how to solder, this repair, including de and re assembly is about a 15 minute job.
    Props to OP. I love my temp/compass gauge.
  15. Sep 14, 2017 at 3:06 PM
    #1955
    Northern Taco
    I solder mine and it doesn't last a month.
  16. Sep 15, 2017 at 9:34 AM
    #1956
    el_smurfo
    el_smurfo Well-Known Member
    Try getting some bigger leaded resistors and bend the leads to fit on the SMT pads. As long as they fit and are the same value, it will work and the leaded parts have more surface area to dissipate heat so they won't desolder themselves.
  17. Sep 15, 2017 at 10:23 AM
    #1957
    Hairy Taco
    North of Hell
    08 TRD
    Maybe try using flux, if you are not.
  18. Sep 15, 2017 at 11:52 AM
    #1958
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I re soldered mine and in a few months it failed again so I did it again using a stronger solder and also I found out that it builds up extreme heat of its own besides the sun beating down on it so now I just turn it on when I want to know the temp outside then turn it back off so it dont happen again.
  19. Sep 15, 2017 at 11:56 AM
    #1959
    bluezzy
    Monty
    Eugene, Oregon
    mine did that too just before it went out completely and had to be resoldered.
  20. Sep 15, 2017 at 1:38 PM
    #1960
    Northern Taco
    I thought it was flux core solder, but I also have flux I can try.
