Overhead Console....clips missing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kenobe, May 13, 2012.
  1. May 13, 2012 at 11:33 AM
    Kenobe
    Kenobe [OP] Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    Ok, showing my newbness here. I removed my ceiling console to install a garage door opener switch and now it will only stay in place from the one screw. There are two tabs that connect into the roof that appear to slide in, but aren't holding the console any more. I think maybe two metal clips were attached to this and fell out somehow? They must be up in the roof if that's the case cuz I don't see any laying around my truck.
    Anyone know what these clips look like? Can I just get them at the dealer?
    Thanks
    IA DIY likes this.
  2. May 13, 2012 at 11:43 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    The original clips were metal and attach to the peg that pushes up into the metal of the roof. The replacements you order from the dealer will be a yellow plastic. I have a pack of them in my garage at home. I'll try to find the part number when I get back.
  3. May 13, 2012 at 11:50 AM
    Kenobe
    Ken
    09 Tacoma TRD Sport
    Ah, figured. Thanks. I'll stop by the dealer tomorrow.
  4. May 13, 2012 at 2:12 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Tap on the metal where the clips fit they probably are stuck in the frame work they fall off when you take the panel down.
    IA DIY likes this.
  5. May 13, 2012 at 2:18 PM
    TerryS
    TerryS Well-Known Member
    Terry
    Cape Cod, Mass.
    '24 Celestial Silver DCLB SR5
    OEM cast aluminum running boards & tonneau cover.
    ^^^ This. The couple of times I've had my console out, the clips fell off, but I found them in the framework just below and behind the slot they ordinarily fit into.
    IA DIY likes this.
  6. May 23, 2012 at 11:13 AM
    Kenobe
    Ken
    09 Tacoma TRD Sport
    Finally took 2 minutes to search up above, sure enough both clips were in the headliner.:facepalm:
    That kinda blows those things launch out like that when removing the console. Oh well, I also have two spares in case I truly lose them later - $3 at the dealer.
    IA DIY likes this.
  7. May 23, 2012 at 12:08 PM
    Maticuno
    2011 Suburban 2500
    Great that you were able to find them AND get some spares from the dealer. Those clips are used in a few other places in the truck, including holding the radio panel into the dash.
  8. May 23, 2012 at 12:13 PM
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    did you happen to get a part #? i have one missing in my overhead console and in my radio. those thing pop off when you take it apart and fall down inside the truck
  9. May 26, 2012 at 9:41 AM
    Kenobe
    Ken
    09 Tacoma TRD Sport
    90084-46017
    BassAckwards and Sweets123 like this.
  10. Aug 3, 2021 at 3:41 PM
    TexasF1re
    TexasF1re Member
    Chris`
    El Paso, TX
    New to Taco Ownership
    hello...mine are missing now...anyone have a pair for sale? or can guide to the place i need to be to get them.
  11. Aug 3, 2021 at 3:45 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    The part number is listed in the post above yours, they are $0.90 each on the internet, probably about $1.50 from your local dealer
  12. Mar 12, 2025 at 9:09 AM
    IA DIY
    IA DIY Well-Known Member
    Iowa
    2008 DCLB 4x4
    Haha! So glad I found this. My loose overhead console was driving me crazy. Fished around in the headliner and found both clips!!
