Overhead Console with temp/compass display - 05-08
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by iamsuperbleeder, Mar 20, 2013.
  1. Mar 20, 2013 at 5:41 PM
    iamsuperbleeder
    iamsuperbleeder [OP] Licensed Lunatic
    Travis
    Lake City, Florida
    06 DC Prerunner Taco - SOLD -
    TRD E-locker rear axle swap, Cherrybomb Extreme muffler, custom made CAI, 2.5" spacer lift up front and AAL's in the rear, Sport model seat swap, Pioneer X940BT, Kicker shallow 10" and 12" behind the back seat
    Have here a complete console out of a 2005 that I repaired the display in. Had the common resistor solder issue; I resoldered (and added some solder to) it and it works like a champ now.
    The ONLY issue with it is on the driver's side one of the pins that the map light pivots on to turn on and off is broken off, however it still works perfectly fine. The only thing it causes to happen is the light cover pushes into to the console a litter further when turning the driver's side map light on and off. Could probably be fixed with a tiny screw or super gluing a new pin of some sort on, but it works how it is so I wasn't going to bother.
    Has a few VERY minor light scuffs on it, but you would have to look hard for them; the camera didn't even pick them up (never see any of them once it's bolted up to the roof).
    Comes with bulbs still in it, metal spring clips still installed, and even the single mounting screw :)
    $OLD
  2. Mar 20, 2013 at 6:08 PM
    Tacomayco
    Tacomayco Tacomayco
    Michael
    Az
    06 4x4
    K&N Intake, Flowmaster Thunder Exhaust, Jet MAF Sensor, Back Cats Delete, 5100 Blisteins, Moto Metal on 33" Muds, Debadged
    U will also need to buy the temp sensor. :)
  3. Mar 20, 2013 at 6:12 PM
    n0fry
    n0fry Member
    DFW, TX
    06 Tacoma Access Cab 5lug SR5
    None... yet
    Ah okay, lemme ask my local shops, will have to reconsider lol.
  4. Mar 20, 2013 at 6:39 PM
    iamsuperbleeder
    Travis
    Lake City, Florida
    I can probably get a temp sensor and the pigtail for the sensor too if needed, for maybe an extra $15. I have sources ;)
  5. Mar 20, 2013 at 6:55 PM
    iamsuperbleeder
    Travis
    Lake City, Florida
  6. Mar 21, 2013 at 2:51 PM
    iamsuperbleeder
    Travis
    Lake City, Florida
    Bump, still have it.
    For the same price, I'm now including a temp sensor as well as the plug with some wire on it; going to need it if you're trying to retrofit it into a truck without the temp display (maybe not the plug in some cases, but if your truck isn't pre-wired for it you're going to need it).
  7. Mar 21, 2013 at 6:04 PM
    Eastern
    Eastern Member
    Clarence
    Nova Scotia, Canada
    2011 Tacoma, 4X2 4 cyl
    Hi there, do you still have the overhead console with the temperature display ? I have a 2012 truck. Do you know if it will fit ?
    Thanks...
  8. Mar 21, 2013 at 6:36 PM
    Chatt x
    Chatt x Active Member
    Chattanooga, TN
    07 swb Xrunner
    Not stock
    Pm sent sir!
  9. Mar 21, 2013 at 7:18 PM
    iamsuperbleeder
    Travis
    Lake City, Florida
    09+ are different (the plugs on them are different from what I understand); this one is off an 05, so it'll only work with 05-08
  10. Mar 22, 2013 at 4:18 PM
    iamsuperbleeder
    Travis
    Lake City, Florida
    Sold!
    Thanks Chatt, it'll be on it's way to you tomorrow!
  11. Mar 23, 2013 at 6:09 PM
    Chatt x
    Chattanooga, TN
    07 swb Xrunner
    Not stock
    Thank you sir for having one! Stealership wanted an arm plus a kidney!
