Overhead Console with Temp/Compass Display 2005 - 2008 - TAN/BEIGE
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Tunngavik, May 26, 2012.
  1. May 26, 2012 at 9:29 PM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2010 Access Cab SR5 4x4 5 speed 2.7l
    Fog lights with OEM switch - Heated mirrors with OEM style switch - Cab sound deadening - Lighted 4x4 switch - URD short shifter - Rear backup camera - 2012 rear view mirror (compass, outdoor temperature and backup video mirror) - Heated seats - 2014 Tacoma stereo install - Bluetooth with OEM steering wheel controls, Access roll-up tonneau cover
    SOLD - NO LONGER AVAILABLE!
    Overhead console with temperature and compass display plus the ambient temperature temperature sensor (not pictured) that fits in at the front of the truck. Works with 2005 - 2008 trucks and with the sensor will work with the 2009 - 2011 trucks.
    This is tan/beige in colour. Note, I had the plastic around the temp/compass display painted tan to match the rest of the console. Should be plug and play for all 2005 - 2008 trucks and will work with the 2009 - 2011 trucks with the included sensor (have to run 2 wires from the console to the front of the truck through the firewall port).
    $150 shipped anywhere in North America.
  2. May 27, 2012 at 12:12 PM
    Tunngavik
    Alberta, Canada
  3. May 28, 2012 at 7:08 AM
    Tunngavik
    Alberta, Canada
  4. May 28, 2012 at 7:33 AM
    BIGchar33597
    BIGchar33597 Well-Known Member
    char
    Sumter Co. Florida
    2008 Tundra 5.7 4x4
  5. May 28, 2012 at 7:37 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Nice good deal a lot of people want these
  6. May 28, 2012 at 7:39 AM
    Tunngavik
    Alberta, Canada
    Something must be wrong with your computer - the pics are there.
    Is anyone else having problems?
  7. May 28, 2012 at 7:44 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Pics are up, wish I had the money. GLWS
  8. May 28, 2012 at 11:46 AM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    Just an FYI - the ambient sensor at the front of the truck is used on all
    (05 to present) Tacoma's with the temperature console.
    Most 6 lug wheel Tacoma's are pre wired for the front sensor.
    The difference between the 05-08 and 09 to present consoles are in the respective consoles wiring schematic itself and they cannot be interchanged.
    ie, a console out of an 06 will not work properly in a 2010 or vice vesa.
  9. May 28, 2012 at 11:55 AM
    Tunngavik
    Alberta, Canada
    Check out this thread http://tinyurl.com/8y4p9fo - specifically post #10 where the OP states that running two wires to a 2005-2008 ambient sensor at the front of the truck will work and post #33 where one says he got it to work with the above setup.
    My setup for sale will not work as a plug and play for 2009 - 2011 Tacomas - you have to run 2 wires through the firewall to the ambient temp sensor supplied with my console.
    It will work as plug and play for a 2005 - 2008 Tacoma.
  10. May 28, 2012 at 6:16 PM
    puma1
    puma1 Active Member
    Michael
    Dallas
    08 Tacoma SR5 Pre Runner
    Has anyone painted one of these....I need a grey one.Thanks.
  11. May 28, 2012 at 7:16 PM
    Sideways
    Maryland
    05 TRD dbl cab
    Puma, the factory consoles are grey.
    Tunn, KevinVa never did the re wire and ended up buying and installing an 09 console. (post#24)
    The author of post #33 joined in April of 2010, currently has a total post count of 2 with nothing posted since 2010
  12. May 29, 2012 at 9:26 AM
    Tunngavik
    Alberta, Canada
  13. May 29, 2012 at 4:20 PM
    BCTacoma
    BCTacoma Well-Known Member
    Port Hardy, BC
    06 SR5 Tacoma
    Toytec ULK, OME Dakars, Bilstein Shocks, Extended Brake Lines, 285/75/16 Duratracs, Pro Comp Steel wheels, Relentless Fab Front Bumper/Sliders
    where in Saskatchewan are you ? so i wouldnt need to add an out side temp sensor with this. my truck is a 2006 sr5.
  14. May 29, 2012 at 4:30 PM
    Tunngavik
    Alberta, Canada
    This would work with your truck no problem as the wiring and connector is exactly the same.
    Work in Moose Jaw, live just east to Regina.
  15. May 30, 2012 at 7:43 AM
    Tunngavik
    Alberta, Canada
  16. Jun 4, 2012 at 8:32 AM
    Tunngavik
    Alberta, Canada
  17. Jun 5, 2012 at 9:56 AM
    Tunngavik
    Alberta, Canada
