Overhead console
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ddstacoma14, May 24, 2014.
  1. May 24, 2014 at 10:30 AM
    Ddstacoma14
    Ddstacoma14 [OP] New Member
    New toyota owner. Can the overhead console be installed in the 2014 model. The information I see elsewhere suggests good to 2008....
  2. May 24, 2014 at 10:32 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    what truck do you have?
  3. May 24, 2014 at 5:46 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I don't know for sure, but if I had to guess I would say no. These trucks are "pre-wired", therefore many trucks will have the temperature sensor even if you don't have the display, you'll have the wiring even if you don't have the console, ect. Your problem will be that this year never had the overhead console, therefore the wiring ect will not be there and most likely the mounting points either. My 2006 had tabs where the Phillips head screws fastened the console to the underside of the roof, I'll bet that it's not there in 2014.
  4. May 24, 2014 at 7:56 PM
    Ddstacoma14
    I have the 2014 double cab base sr5. I have a factory towing package with a radio upgrade to accommodate the backup camera. I am installing heated towing mirrors with turn signal. Plug and play except heat. Have to add the control circuit for the heat. It has the overhead console already with 2 lights and 2 holders for sunglasses.
  5. Jul 9, 2014 at 10:54 PM
    SicKnd
    SicKnd Well-Known Member
    HTX
    pork chop taco w/ cheese
    some
    o/h consoles for an 05-08 will not work on later year models. theres a plug and it gets power, but the wiring was changed up after 08 and you only get a blank line
