Overhead Console?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Qwanto, Jun 23, 2020.
  1. Jun 23, 2020 at 2:40 AM
    Qwanto
    Qwanto [OP] New Member
    2005 TRD OR Access Cab
    I tried doing a search and nothing comes up. Does anyone have the procedure for pulling down the overhead console? 2005 Off Road.
    I just don't want to have any surprises or break any clips when using my trim tool.
    If you know of a 12V hot spot, colors of the hot wire and ground that would be great!
    I'm looking for 12V to tap into for my Radar Detector hanging below the RV mirror.
    Thanks
  2. Jun 23, 2020 at 6:17 AM
    DG92071
    DG92071 Well-Known Member
    There is 1 phillips screw that needs to be removed from under the eyeglass storage compartment. There are 2 clips in the front of the overhead console. Remove the screw and pull the front straight down keeping the overhead console level with the ground/truck. 1 of the tabs that holds the clip broke on mine fully knowing how to remove it. The quantity of plastic that retains the clip is minimal at best.
    I don't recall the wiring colors.
  3. Jun 23, 2020 at 1:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Jun 24, 2020 at 12:58 AM
    Qwanto
    Thank you!
    TnShooter likes this.
