Overhead Console
Discussion in '2nd Gen. Tacomas (2005-2015)' started by warchi81, May 24, 2008.
  1. May 24, 2008 at 6:18 PM
    warchi81
    warchi81 [OP] Active Member
    Is this possible? Has anyone swapped out an SR 5 overhead console and put in a TRD over head console with compass and temperature in a 08 double cab.
  2. May 24, 2008 at 7:54 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    Good luck finding one that you don't have to trade your first born child for. But, yes they are interchangable, and you'd only need to get the temp/compass gauge part...but therin lies the problem.
  3. May 24, 2008 at 9:14 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    I looked at doing this but the overhead compass/temp display unit retails new for about a $1000.00 :eek: even with my discount it is a little rich for my taste. I did not look real hard but I did not see the wire harness or a connector for the temp sensor in the center grill area so I don't know if it would be even possible without some wire harness work. I think I going the direction of a rear view mirror unit with a compass/temp built in it.
  4. May 25, 2008 at 12:52 AM
    redtoytaco
    redtoytaco Well-Known Member
    So Cal
    06 PreRunner Dcab LB SR5
    I have done it. The connectors are all there you just need to buy the ambient temp sensor. IIRC it cost me $20 for the sensor and $58 for the overhead console. I got lucky on the console but wrecking yard is good place to start.
  5. Jun 29, 2008 at 12:36 PM
    Synapse
    Synapse Well-Known Member
    Birmingham
    2008 Tacoma
    If you have a pic could you post it.
  6. Jun 29, 2008 at 12:50 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  7. Jun 29, 2008 at 5:29 PM
    Frankie_G
    Frankie_G Well-Known Member
    Frankie
    West Seattle, Wa
    I was looking at that same bluetooth set. Let me know how it works out and maybe a DIY cause im really interested in installing it and getting it
  8. Jun 30, 2008 at 7:25 PM
    redtoytaco
    So Cal
    Synapse, sorry I do not have any pic to post. The connectors are easy to find. For the console it is right there when you remove the existing overhead console it is hard to miss. For the thermistor/sensor it is tape on the support bar near where the horn is at the front between the grill and the radiator.
  9. Jul 1, 2008 at 7:04 PM
    warchi81
    Whats the trick to removing the over head center console? Any tips?
  10. Jul 1, 2008 at 10:21 PM
    redtoytaco
    So Cal
    You need to unscrew one screw inside the sunglasses holder. There are two other retaining clips that will pop out when you pull the console down. The clips may come off and fall inside the head liner just an fyi.
  11. Sep 22, 2008 at 9:48 PM
    mxracer16
    mxracer16 Well-Known Member
    2006 trd
    stock stock stock
    58 frikin $'s man, im glade i didnt pull the trigger on one for $600 and i thought that was a deal from about 1000
  12. Sep 25, 2008 at 11:33 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'll reiterate, pull straight down on the front of the overhead console. Do not pull towards the back at any point. I sheared the plastic tabs right off of mine. I'll use self tapping screws to reinstall mine.
  13. Sep 26, 2008 at 9:27 AM
    sabian
    sabian Active Member
    northern michigan
    SR5 tacoma
    Where did you get the Gentex mirror and what was the cost?
  14. Sep 26, 2008 at 3:06 PM
    Asgard
  15. Sep 26, 2008 at 3:14 PM
    Asgard
    Here are some pics of my bluetooth device :
