Overhead display
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yotaman.98, Jan 22, 2021.
  1. Jan 22, 2021 at 7:28 PM
    Yotaman.98
    Yotaman.98 [OP] New Member
    2009 Toyota Tacoma TDR Offroad
    My overhead temp display is working but does not show the right temperature. Thoughts on how I can fix this issue
    YotaProject likes this.
  2. Jan 22, 2021 at 7:41 PM
    YotaProject
    YotaProject Well-Known Member
    Adrian
    Charleston SC
    Fox Lifted 2007 Taco With Mods Here & There
    Have the same issue, just re-soldered the 510 chip after it failed for the second time. Now it randomly fluctuates between incorrect temps. compass works perfect though.
  3. Jan 22, 2021 at 7:48 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check for a corroded connector/wire at the outside temp sensor (should be on the radiator support in front of the A/C condenser) Might be simple as that.
  4. Jan 22, 2021 at 7:57 PM
    YotaProject
    Adrian
    Charleston SC
    Also if you do need to check or replace your external temp sensor it sits right behind the grille.
    Dm93 likes this.
  5. Jan 22, 2021 at 8:02 PM
    Yotaman.98
    I have replaced the external temperature sensor but I didn’t check the plug for corrosion
