Overhead Panel Calamity
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Antangil, Jun 29, 2018.
  1. Aug 11, 2018 at 8:40 AM
    #41
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    Why is everyone pulling the panel off to change the light bulbs?
  2. Aug 11, 2018 at 1:38 PM
    #42
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    The panel takes only 15 sec to remove and you can unplug it to work on and you won't crack your light cover trying to remove it..to change the bulbs or add a switch like i did in post #31
  3. Aug 11, 2018 at 1:55 PM
    #43
    Wengel21
    Wengel21 Well-Known Member
    Ben
    SoCal
    2017 DC LB TRD OR
    I don’t know it’s pretty easy to swap out the bulbs and not break anything. Just have to disconnect the battery for safety. Wrap duct tape around the bulb and pull. And place the new bulb in and put the cover back on.
    But I’m glad everything worked out for the OP in the end
  4. Mar 26, 2019 at 5:24 PM
    #44
    Rrowdy
    Rrowdy Well-Known Member
    Phil
    Yavapai County Arizona
    Super White 2017 Tacoma DCSB SR 3.5L Auto
    It just seems strange the circuit board fried before the fuse blew. Isn’t there a 7.5 amp fuse protecting that circuit?
