Overhead rattle driving me crazy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ashgh, Mar 15, 2022.
  1. Mar 15, 2022 at 8:42 AM
    Ashgh
    Ashgh [OP] Well-Known Member
    Ashkan
    2021 Tacoma TRD Off-road
    I’ve been trying to fix the rattle coming from the headliner where the map lights are but have not been successful. I tried pulling it out and taping down the wires but it still makes a buzzing noise when I drive. Anyone have any success fixing theirs?
  2. Mar 15, 2022 at 9:10 AM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
  3. Mar 15, 2022 at 9:13 AM
    Ashgh
    Ashkan
    Sometimes I just want a little bit of piece and quiet
    SandyTaco4x4 and Montana_Actual like this.
  4. Mar 15, 2022 at 9:14 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Did not know that was a known issue for ratting on the '21. Glad mine doesn't do that, but I have had to deal with a whole slew of other rattles that were equally as annoying.
    You sure it's from the overhead console? Do you have a sunroof?
  5. Mar 15, 2022 at 9:15 AM
    Ashgh
    Ashkan
    100% if it push my hand on it or pull it a certain way while I drive it stops.
  6. Mar 15, 2022 at 9:15 AM
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
    Get inside a German car…smooth sailing
  7. Mar 15, 2022 at 9:17 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Remove it completely and see if the issue stops then. Then see if you can make the console rattle while off the truck. Figure out what is rattling and stop it.. it's usually not hard to stop a rattle once you pinpoint it.
  8. Mar 15, 2022 at 9:21 AM
    dezert.taco
    Nate
    Northern Nevada
    2018 Tacoma
    In all honestly mine does it too. The overhead console is relatively the same from 16-current aside from the differences found between models (OR, Sport, etc), the way it attaches I should say is relatively the same. Dirt roads, rough roads etc all contribute to things getting loose. Mine started rattling near day one... I was ticked about it at first but got over it eventually. I still at times press against mine to so it shuts up for awhile.
    You can try some fleece wire loom tape around the clips that hold the console in place.
  9. Mar 15, 2022 at 9:22 AM
    Ashgh
    Ashkan
    I’ll give it a try. It’s weird because it’s almost like it’s rattling against the headliner because when I push up on it it will stop. But it doesn’t really make sense because the headliner is soft.
  10. Mar 15, 2022 at 9:23 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    If you pull the panel down and drive around do you still hear the rattle?
  11. Mar 15, 2022 at 9:24 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    The headliner is lined, but the console is held in with 4 red push clips into metal (it feels violent but just pull straight down on it to remove it). If something is rattling there, you'll know pretty quick once you get it out of the vehicle.
    Ashgh[OP] likes this.
  12. Mar 15, 2022 at 9:29 AM
    dezert.taco
    Nate
    Northern Nevada
    2018 Tacoma
    Guy already said if he pushes against it, it goes away. Most likely the tolerances around the clips. Several other threads on this floating around.
    Captqc[QUOTED] likes this.
  13. Mar 15, 2022 at 12:42 PM
    TonyG2
    TonyG2 Active Member
    2020 Tacoma SX
    I had them tape and felt everything at dealership, still buzzed. I pulled it down and randomly(lol) crammed a microfiber cloth in there, that made it to where it barely buzzes. But it still does some. What really bothers me is that when the radio is on and the two sounds are combined it sounds like the radio has static, which it does not.
  14. Mar 15, 2022 at 12:49 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Pull it.
    Ink clips with grease.
    Replace gently and pull again.
    Shim with 3m tape where grease masks didn’t transfer.
    Replace.
    Repeat in 3-5 years.
    mootiger49 and Ashgh[OP] like this.
  15. Mar 15, 2023 at 5:07 PM
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
    Alright, mine started this rattle yesterday. Any more tips?
  16. Mar 15, 2023 at 5:16 PM
    Ashgh
    Ashkan
    Yeah. I realized a while ago that it stops rattling if I pull the black console slightly (like I’m about to pull the whole thing off). What I did was fold a couple of 3x5 note cards into a small square, colored it black with sharpie, and tucked it into a corner of the console. It sticks out very slightly but the black blends in with the headliner so you can’t even tell. Since then zero rattling.
  17. Mar 15, 2023 at 5:20 PM
    Ashgh
    Ashkan
    Picture for reference
    jdjones likes this.
  18. Mar 15, 2023 at 5:41 PM
    jdjones
    I think I’ll pop that console out this weekend and explore. Pushing and pulling the console didn’t stop it. I’m thinking there’s a loose harness up there or something.
  19. Mar 15, 2023 at 6:27 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Let me guess ... better during the day when warm (well, AZ has warm days currently at least) but more noticeable at night when colder. Push one corner to stop it, squeaking frequency high enough to drive you nuts.
    That was beyond annoying on my new until dealer looked at it, concluded "bad rear view mirror". Then modified it to "one of the mounting bolts for the mirror needs to be torqued down. It is still there a tiny bit and may go back and have them look again, but playing with that rear mount screw has improved the situation.
  20. Mar 15, 2023 at 8:12 PM
    Red2021SR5
    Red2021SR5 New Member
    My 2021 did the same thing, I removed the console and it was the headliner vibrating against the roof of the cab.
    I fixed it by placing 3M double sided tape between headliner and roof.
