Overhead temperature gauge stuck / incorrect
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MountainEarth, Jun 4, 2011.
  1. Jun 4, 2011 at 2:59 PM
    MountainEarth
    MountainEarth [OP] Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    So twice now over the last year, the overhead outdoor temperature console has been at the wrong temp almost like it was stuck from the previous drive. Today it was 75 and the gauge read 47 nearly the entire day as I was driving short trips around town. I finally calibrated the compass in a parking lot hoping that would help, and turned the truck & the console itself off repeatedly.
    Then all of a sudden, all by itself, it started counting up slowly to arrive ta 63 and stuck for a few minutes. Then it quickly read the right temp at 75.
    Anybody seen this? Would this be a problem with the probe or the console? Does it require a longer drive to set up & read corectly? That shouldn't be it because usually it's right on.
    I can't find the probe either. I know it's somewhere around the front bumper, but I sure don't see it. Anybody have a pic? Want to see if it's maybe loose or caked with mud or something.
  2. Jun 4, 2011 at 3:13 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I have noticed that mine takes perhaps, ten minutes or so before it displays the correct temp. Drive it into the garage in 50 degree temps, shut it off, come back the following afternoon when it's 80 outside and hotter inside the garage and it still says 50 degrees. It has some sort of time delay on it.
    How short are your trips? It seems like yours is taking a long time to react, but some delay is normal for sure.
  3. Jun 4, 2011 at 4:26 PM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    ogdog likes this.
  4. Jun 4, 2011 at 9:51 PM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    What you describe is sort of what was happening. The night before it was 47 when I shut her off. Got up this morning and it was in the 60s but remained at 47. Would guess most of my trips throughout the day were less than 10 minutes though .. was involved in a community litter cleanup, so was driving around and checking on crews ... all short trips. But many short trips over several hours. Guess it must need a solid 10 minutes or more. So maybe it is a time delay. Thanks for the info.
  5. Jun 4, 2011 at 9:58 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Just for everyone's info, the temperature "probe" used is a thermistor, whereas the thermometer circuit sends a DC signal and reads a temperature based on the resistance (ohms) on the load, and any variance on the resistance can have a dramatic effect on the temperature reading, so naturally the logic is going to have some sort of delay to keep you from getting completely ridiculous readings all the time.
  6. Jun 4, 2011 at 10:02 PM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    Interesting.
  7. Jun 4, 2011 at 10:06 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :puke: sometimes I feel the need to do this with information.
  8. Jun 4, 2011 at 10:07 PM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    LOL hey man fine by me. Appreciate the knowledge.
