Overheated '05. Failed leak down. Next steps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dk_crew, Jun 21, 2024.
  1. Sep 12, 2024 at 11:38 AM
    #41
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Even though I was told 90 day parts and labor over the phone, the fine print in the contract said no labor warranty on used engines, transmissions, or something else… That said, they are making noises about taking care of it although I’m not sure if they will come all the way through in the end. I’m hoping that they do the right thing.
    SR-71A likes this.
  2. Sep 12, 2024 at 12:39 PM
    #42
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Maybe offer them half labor. That should cover their cost of labor. Even initially offer 1/3 labor.
    Zebinator likes this.
  3. Sep 12, 2024 at 3:04 PM
    #43
    dk_crew
    dk_crew [OP] Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I think HG if you can be sure it's that and nothing else more catastrophic happened -- it's not clear to me how someone would know without a big teardown?
    I got my truck back today with the new (used) engine. I drove it 28 miles home and it was fine. I'm going to try to put a bunch more on tomorrow and, if good, drive back to CO on Saturday and Sunday ... nice and slow. My only issue at the moment is the driveshaft needs some work. I'm going to try to get that done tomorrow or continue using front wheel drive and address it in CO.
    Zebinator[QUOTED] likes this.
  4. Sep 12, 2024 at 3:51 PM
    #44
    Zebinator
    Norcal
    My STRONG recommendation is to get a OBD-II bluetooth doodad or a scanmate and watch your oil temp as you drive from this point forward. I know I will!
    dk_crew[QUOTED][OP] likes this.
  5. Sep 13, 2024 at 4:52 AM
    #45
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    yes I have one and so far I primarily watch the coolant temp but need to fool with it and see what other key data points I should watch. thanks for the tip. crossing fingers.
    Knudsen likes this.
  6. Sep 16, 2024 at 10:59 AM
    #46
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I made it. I had about 80 miles before leaving town and drove the 1000 miles straight. Nice and slow. It took about 20 hours. The truck did great. I was worried in the cap rock area - Lubbock > Amarillo and into Raton as the outside temps were at 99 and I was basically on a slow incline. Temps just stayed in the 194-199 range - I was recording the entire time using the ODB-II with bluetooth connected to my phone glued onto the temps. It would creep up if I stopped and immediately drop back down once I started driving / moving again. The 2 big mountain passes were no problem at all. The outside temps were way down by then and I just tried keeping the RPMs low creeping up and over the passes. I spent the day yesterday re-wiring up the winch, compressor and lockers, fogs and other loose ends. All in all it was a great trip and this truck should get to enjoy the mountains around here for the foreseeable future. Maybe one Moab trip before the slopes open.
    Knudsen, Zebinator and Pwakchop like this.
  7. Sep 25, 2024 at 5:54 PM
    #47
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    finally got to stretch the legs of the truck with the new engine. and found my camp spot for next weekend.
  8. Oct 12, 2024 at 11:28 AM
    #48
    Zebinator
    Norcal
    My shop did the right thing and bit the bullet. They did a head gasket job including resurfacing and got her all buttoned up. Drove 750 miles and no coolant consumption I could detect and no other issues. Phew! Once I get it home will do a thorough clean and decide what’s next.
    deanosaurus and Knudsen like this.
  9. Oct 12, 2024 at 12:10 PM
    #49
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    phew! that is great to hear!
  10. Oct 13, 2024 at 6:20 AM
    #50
    Zebinator
    Norcal
    Thanks! Glad to see you up and running too!
    I am still kind of shocked salvage engines get no testing before they get sold. Seems like a leak down test would be an easy thing to do. If I ever go down this road again I’d be asking more questions.
  11. Oct 27, 2024 at 10:31 AM
    #51
    Blown383
    Blown383 Well-Known Member
    I am currently having the same issues and have pulled my motor. Did you ever tear down the old motor to see what happened?
    -B
  12. Oct 27, 2024 at 7:34 PM
    #52
    Zebinator
    Norcal
    I didn't as my engine was so f'ed it wouldn't crank. The second engine they did a leak-down test and saw coolant in the cylinders.
  13. Oct 28, 2024 at 6:20 AM
    #53
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Neither did we. The yard we got the salvage from wanted ours intact as the sore so we couldn't tear into it. Our leak down test was in the red across the 3 PS cylinders and and the coolant was flowing straight through the engine out the exhaust. So far so good on the 131k engine. I'm probably 1800 miles in at this point. Temps hover in that 185-195 range and I'm obsessed with watching the coolant levels.
  14. Oct 28, 2024 at 3:42 PM
    #54
    Zebinator
    Norcal
    EXACTLY!
    :popcorn:
