Overheating after buying 02 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by DoubleCab3.4, Sep 15, 2025 at 11:14 AM.
  1. Sep 15, 2025 at 6:27 PM
    MGMDesertTaco
    1. air still in the system
    2. system needs to be flushed
    3. needs a new thermostat
    I would flush the entire system and replace the thermostat. Then burp it, top it off and take it for a spin. Less than $100 for all that.
    Kwikvette likes this.
  2. Sep 15, 2025 at 8:58 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    180k truck is due for a timing belt and other 30k mile interval scheduled maintenance. Can you confirm that was done?
    30k mile maintenance incudes plugs (NGK BKR5EKB-11 or Denso 3194 K15TR11) front/rear diffs, transmission flush, tcase (75-90 in diffs/tcase) brake fluid flush, coolant flush (Toyota coolant is red, okay to use green or red but make sure the system is properly flushed because they don’t react well together), new thermostat, do the water pump at the same time you do the timing belt- use Toyota/Japanese parts- Denso, Aisin, Mitsubishi, NGK https://www.ebay.com/itm/317029638806?_skw=tacoma+timing+belt+kit&itmmeta=01K589T66MBHG8EK8TQZN36XDR&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1eDaLr0Dmi8Dn5z7XIt%2FMkfuBBUaP3VW%2FfWIWQ9E5tCQvfEb0IxQoK9F57iSVvFbIsZ8M4N7fxnli8Jk0vxOKX+vcuGo7IXH2Emjp18RSH5WrjSm8tff0WgW2AePKQ%2FuHt--BXoGVPd79m0+bzO698MID+ngprKST6xrMoJu%2FQpFQimIpp8VgAfCW+EkoP8D3jSIPv8Ub3IGD6w96AecArrzKxRYvz1D85kq1Ka53rogA0RBmcoULIZhOMdkEORsAl7VFB+dDDUTqxyS0WuK7xQ4lCwd9rqcVZp%2FlOuUEC0nQ%3D%3D%7Ctkp%3ABk9SR7zj6ImqZg&keyword=tacoma+timing+belt+kit&sacat=0&relatedSearch=true
    Is it possible the seller dumped the truck before doing this work?
    Good way to learn the truck, lots of write-ups, and if it hasn’t been done, it will need to be.
    Toughest part is the crank pulley bolt, need a 250lb torque wrench
    https://m.youtube.com/watch?v=vHC46ypHxWc
    https://m.youtube.com/watch?v=mErd7xoBS9I
    Assess if this is over your head.
  3. Sep 15, 2025 at 9:29 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    100% sorry to say OP
  4. Sep 15, 2025 at 9:58 PM
    MGMDesertTaco
    Just looking at the photo the truck appears to be in really good shape. All vehicles require maintenance overtime. Do the repairs and drive it another 180k.
  5. Sep 15, 2025 at 10:11 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    To isolate airflow, does the temp go down if you are coasting from a higher speed? Or go down and hold steady once you get up to speed, like 40-45mph - that's more airflow than the cooling fan can pull.
    O'Reilly will let you borrow a radiator pressure test kit (basically you can buy, use for a few days and then return for a 100% refund). This will check if you have any head gasket leaks.
    But first, I'm with everybody else, it's the thermostat. Buy a new one and start there. Buy a genuine Toyota. If you go aftermarket buy the type that "fail open". Most(?) cheaper aftermarket ones will "fail closed" - i.e. when they go bad they close and overheat your engine.
    Your truck looks great!
  6. Sep 16, 2025 at 2:15 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Start simple clean the radiator fins (exterior). Also if the coolant is getting to 230 the motor oil is getting too hot (230 +).
  7. Sep 16, 2025 at 5:33 AM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Unfortunately it’s not going to be something simple because that’s why it was for sale. Did it not have the overheating during test drive?
