Overheating after new thermostat, water pump, and fan clutch
Discussion in 'Southern California' started by Oreo Cat, Jul 23, 2020.
  1. Jul 24, 2020 at 8:55 AM
    Oreo Cat
    Oreo Cat [OP] Worst Member
    Coeur d’Alene, Idaho
    Green/blue mix now but not yellow
  2. Jul 24, 2020 at 9:00 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    In terms of tracking down where the leak is coming from (if its not the overflow which I suspect) you'd would have to wash the whole engine bay down, let it dry, and then monitor for leaks. Preferably without driving around, but it may not get hot enough just idling unfortunately
  3. Jul 24, 2020 at 9:09 AM
    Oreo Cat
    suck some air near the tail pipe, so I assume the gasket isn’t blown.
  4. Jul 24, 2020 at 9:12 AM
    Oreo Cat
    Probably will start with a cap, then do the water pump, fan clutch and thermostat when I get some time
  5. Jul 24, 2020 at 9:52 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Barrow a coolant leak tester from autozone or similar. Pump up the system and see if the pressure goes down and look for leaks. If it doesn't then sound like the previous post about cap and recovery system. Just a thought. :notsure:
    SR-71A likes this.
  6. Jul 24, 2020 at 10:49 AM
    Oreo Cat
    That’s the one That goes in the spark plug hole right?
  7. Jul 24, 2020 at 10:55 AM
    20tacoma17
    2017 DCLB Sport AT
    No, it goes in place of radiator cap. It has a pump and guage on it to pressurize coolant system. You pump it up and look for leaks and see if pressure drops. Similar to this
  8. Jul 24, 2020 at 11:16 AM
    Oreo Cat
    But does test the actual head gasket or just for leaks
  9. Jul 24, 2020 at 11:33 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    It tests the cooling system as a whole by pressuring it. If you have a leak, you will see an out-of-spec pressure drop on the gauge and either a drip/weep/leak outside the block, or nothing. If you have a pressure drop and no visible drips, then you need to chase inside the block using a leakdown tester and stethoscope.
    suaveflooder, SR-71A and 20tacoma17 like this.
  10. Jul 24, 2020 at 4:44 PM
    Oreo Cat
    Toyota says Water pump and thermostat, would y’all recommend oem replacements or autozone?
  11. Jul 24, 2020 at 4:48 PM
    20tacoma17
    2017 DCLB Sport AT
    Did you have Toyota check it over? Nothing wrong with Autozone. Many of their items have lifetime warranty.
    Oreo Cat[QUOTED][OP] likes this.
  12. Jul 24, 2020 at 4:50 PM
    Oreo Cat
    Yeah Toyota went over. Water pump and thermostat. They want 1200+ for that so I’ll be doing it in the driveway
    20tacoma17[QUOTED] likes this.
  13. Jul 24, 2020 at 4:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Pay the $ and get the Toyota parts
    Lord Helmet, whatstcp, SR-71A and 2 others like this.
  14. Jul 24, 2020 at 4:56 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Get oem. Have had bad headgaskets 3 times. Get one of those funnels that lets you fill it up and check for air coming out of the radiator fill hole.
    System is sucking air in from somewhere and not lwtting the cooland circulate and makes it throw it back up.
    Thermostat would make it overheat at idle. Replace waterpump and fan clutch from Rockauto. They sell the Aisin pump. Get thermostat from dealer.
    Oreo Cat[OP] likes this.
  15. Jul 24, 2020 at 6:40 PM
    #35
    Oreo Cat
    Sounds like a plan
  16. Jul 24, 2020 at 11:49 PM
    #36
    bursthead
    bursthead Well-Known Member
    2019 Tacoma TRD Pro
    Looks like the head gasket. Watch your coolant reservoir for bubbles. It looks like it might have overflow and hit the fan. Get a scan gauge and always watch your temps. If it’s not misfiring yet just monitor and save your money for the head gasket or swap.
  17. Jul 24, 2020 at 11:54 PM
    #37
    Oreo Cat
    Did the test kit and took it to Toyota, they wanted me get new water pump and thermostat. Tech also said a fan clutch wouldn’t hurt either. So doing those 3 things when I get some extra $
  18. Jul 25, 2020 at 9:00 AM
    #38
    bursthead
    2019 Tacoma TRD Pro
    If you are trying to save money. Use a scan gauge and monitor your temps. You’ll be able to tell if the thermostat is opening or closed. But I would be very weary your vehicle is an 06. They had issues with the head gasket leaking on the o5- and part of the year for the 06 before the head gasket was revised.
    my last taco was an 05 and I went through this whole mess with it. My car would push coolant out of the radiator slowly. The only time it would over heat was on long trips or if I was in the mountains and pushing the engine. I would just keep popping the cap every few days top off the coolant on the radiator and watch the overflow tank.
    I changed pretty much everything, short of the engine trying to figure this out. And I used the block test and got a blue/green result.
    SR-71A likes this.
  19. Jul 25, 2020 at 9:08 AM
    #39
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Buy the AISIN water Pump. Like 70 bucks. I did aisin water pump, aisin fan clutxh, Toyota thermostat all for like 200 bucks and did it all myself.
  20. Jul 26, 2020 at 5:52 PM
    #40
    ellocodetroit
    ellocodetroit Well-Known Member
    Louie
    Alhambra, So Cal
    2008 PreRunner DCLB Eaton Truetrac 4.11
    Bilstein 6112/5160, Icon RXT Stage 3, Cooper ST Maxx, MF-1050 OBA. 348,000 Miles. Coupe battery tie down, Homertaco Grille, Weathertech Floorliners, Front shocks @1.94", ARE camper shell, TRD skid plate.
    I recently had the same issue too. One of my pulleys was screaming and I think the radiator cap failed and was not keeping the cooling system pressurized which allowed the coolant to boilover at a lower temperature. I have a scangauge and the highest temp was 220F. I replaced the water pump, thermostat, fan clutch, hoses, pulleys, tensioner, belt, drain and refill the coolant, and radiator cap. It took me all day on Friday. 10 hours total. Rockauto had the best prices, use the forum 5% discount code. Norwalk Toyota had the best price on the 50/50 pink coolant, ask for the online price. I'm at 326k, so I'm hoping this is the last time I do this as I make the push to 500k. The tensioner is a PITA.
    I still need to get the engine bay cleaned, I just did a simple wipe down.
    If you need a fan clutch, I have an extra Aisin one. Somehow I purchased two of them. I'll let it go for 90% of Rockautos price if you need it.
