Overheating after new thermostat, water pump, and fan clutch
Discussion in 'Southern California' started by Oreo Cat, Jul 23, 2020.
  1. Mar 4, 2022 at 11:19 AM
    #61
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    OP, what year is your Taco? Have read 05-06 V6 Tacos had higher rate of HG issues, as well as cracked frames behind driverside motor mount.
  2. Mar 4, 2022 at 11:37 AM
    #62
    Oreo Cat
    Oreo Cat [OP] Worst Member
    Coeur d’Alene, Idaho
    It’s an 06, engine was replaced with a 2015 engine because it ended up being head gasket, frame also had to be repaired on driver side because of the failure you mentioned
  3. Mar 4, 2022 at 12:03 PM
    #63
    Chuy
    Lakeside, CA
    Silver Taco
    Glad your’s is fixed. As noted above, despite the headaches you went through, you may have come ahead with that low mileage 2015 engine.
    Oreo Cat[OP] likes this.
