Overheating and Loss of Power
Discussion in '1st Gen. Tacomas (1995-2004)' started by batcat420, Jul 22, 2016.
  1. Jul 22, 2016 at 11:04 AM
    batcat420
    batcat420 [OP] I'm a Blue Ribbon man.
    Scott
    Atlanta
    2022 Lunar Rock SR5 Trail Edition
    2000 Tacoma PreRunner, 2.7L
    About three months ago, the truck ran hot on a trip to from Atlanta to Alabama. I added some 50/50 coolant and it was fine until two days ago. It overheated in a bad way on my way home from work, which is about 15 miles and a fair amount of traffic. I stopped to let it cool down and I added more coolant to the reservoir (not the radiator) and tried to make it home. It died once and barely made it the final mile or so. Very little power and lots of valve/cylinder noise. Once home I checked the reservoir and it seemed like the coolant I added didn't make its way into the system.
    I took it around the block the yesterday and the issues remain. Idle is fine, but once I hit the gas there is no torque. It will get up to speed, although I didn't go past 45mph or so. There is a CEL that I've yet to read. There seems to be a slow drip from the radiator, so perhaps it's cracked. It also feels like there's some sort of exhaust leak but I'd need help to confirm that. Any ideas would be greatly appreciated!
  2. Jul 22, 2016 at 11:38 AM
    eon_blue
    Azusa, CA
    Definitely get that code pulled, take it down to AutoZone or O'reillys and they'll read it for free. Post it up here and that should definitely help narrow it down.
    How does your coolant look? It's not milky or brown is it? No particles floating in it or at the bottom of the reservoir?
  3. Jul 24, 2016 at 9:18 AM
    batcat420
    Scott
    Atlanta
    Code is P0115.
  4. Jul 24, 2016 at 9:22 AM
    eon_blue
    Azusa, CA
    Check out this webpage:
    http://www.obd-codes.com/p0115
    Sounds like your Engine/Coolant Temperature sensor needs to be replaced.
  5. Jul 24, 2016 at 2:20 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I wouldn't go replacing any sensors just yet, the sensor sure cant work correctly if there is no water filling up the system so first refill coolant to proper levels after replacing that radiator and then see if the cel code returns, I bet it wont.
    our rads are famous for leaking around the top shell at the seams
  6. Jul 25, 2016 at 6:31 AM
    batcat420
    Scott
    Atlanta
    You mean like this?
  7. Jul 26, 2016 at 5:26 PM
    keakar
    karl
    louisiana
    yep, often all you see is a wet radiator because the seam opens up and the fan sucks it into the fins so you don't often see water actually peeing out anywhere
  8. Jul 27, 2016 at 3:02 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Have you checked the engine oil yet?
  9. Jul 28, 2016 at 6:20 AM
    micalbertl
    micalbertl Well-Known Member
    1996 Tacoma Sr5 Xtra Cab
    the only reason the "water" doesn't evaporate inside the system is because its pressurized. if there is a leak it will instantly evaporate so you wont really see anything like keakar said. get yourself a shiny new radiator:thumbsup:. also checking oil doesn't hurt, but I think you will be happy with what you find.
    the fact there is coolant left on the grill shows how bad it must be
  10. Jul 28, 2016 at 10:20 AM
    Brake Weight
    Evaporated coolant will leave a powdery substance where it evaporates from.
  11. Aug 15, 2016 at 7:27 AM
    batcat420
    Scott
    Atlanta
    Update: Replaced the radiator and thermostat. Still running hot but there is no longer a loss of power. Something else strange; the "low oil" light comes on once I start driving but there is plenty of oil. Haven't done a compression test yet. There was no oil in the coolant that I drained from the old radiator.
  12. Aug 18, 2016 at 2:10 AM
    Brake Weight
    The coolant will likely contaminate the oil. It gets hot enough to turn to steam but being kept under pressure keeps it a liquid and not a gas.
  13. Aug 18, 2016 at 3:15 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    It's not a "low oil" light. It's a "low oil pressure" light. That could be a problem with the oil pump or worn engine parts (bearings) if you're not low on oil. Could be a bad oil pressure switch also, or the wire is disconnected or loose on the switch. I believe disconnecting the wire will cause the oil light to come on.
    Also, did you put a new radiator cap on?
