Overheating at low RPM - thoughts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, Jul 6, 2020.
  1. Jul 6, 2020 at 8:05 AM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    Symptoms:
    - Truck overheats at low RPM (stopped in traffic). Will do it at any outside temperature (20F-90F).
    - Temperatures immediately drop to normal upon elevating engine RPMs - even in neutral.
    - Thermostat has been recently replaced as part of diagnosing this issue.
    I'm thinking fan clutch? Any thoughts before I replace that?
    Update:
    So I did some more investigation into the issue today. Sat in a parking lot with the truck idling for about 7 mins before it began to overheat. Fan was spinning the entire time. As soon as I drove away, engine temps dropped to normal within 30 seconds.
    Thoughts?
  2. Jul 6, 2020 at 8:06 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I would look at airflow through the radiator and coolant flow through the radiator.
  3. Jul 6, 2020 at 8:07 AM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    Either lack of air flow (ie fan problem) or possible issue with water pump/ coolant flow.
    Lester Lugnut and TnShooter like this.
  4. Jul 6, 2020 at 12:54 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Have you done a hydrocarbon or combustion leak test?
    PzTank and 12TRDTacoma like this.
  5. Jul 6, 2020 at 4:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Before you replaced the thermostat was the cooling system low on Coolant?
    Had the Cooling System ever been opened, and Coolant replaced?
    There could be air in the system. The Tacoma is known to trap air most of the time.
    Air in the cooling system can cause the symptoms you describe.
    I’d also look into the fan clutch. As this too can cause the same symptoms.
    And I’m honestly leaning towards this, since you say it is ok at higher speeds.
    At higher speeds the wind “cools” the radiator.
    Also check the condition of radiator for damage.
    If you have a digital infrared thermometer you can check the radiator for hot spots.
    A thermal camera works a lot better, but most guys don’t have access to one. And they are a
    expensive.
    BassAckwards likes this.
  6. Jul 6, 2020 at 4:07 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Fan clutch for sure. Check resistance of fan when the engine is starting to get hot, over 200. Should be good resistance
  7. Jul 6, 2020 at 4:15 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    I'm willing to bet the fan doesn't spin, my Grand Marquis had the same issue. But does it overheat simply idling? If it doesn't then that deepens the mystery.
  8. Jul 7, 2020 at 12:10 PM
    Mxpatriot
    Thoughts?
  9. Jul 7, 2020 at 12:13 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Still sounds like a fan issue, it can be spinning but still not working well enough to keep the engine cool. I had this issue when I had e-fans installed...they just didn't push enough air at idle or slow temps. Once you get up to speed, the outside air coming through the grill is bringing your temp back down to normal.
  10. Jul 7, 2020 at 12:16 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Turn off the truck after it has gotten up to temperature and attempt to spin the fan. If there is resistance that is good. Move on to the next item.
    Radiator could potentially be partially clogged, impeding airflow until it sees some airflow via incoming wind and higher fan RPMs. If there is any doubt that the radiator could be the issue, replace and reinspect.
    If you have access to a scanner you need to check to see what reported ECT temps are at prior to replacement of any obvious bad items.
    Additionally, check to see if there is coolant loss at the overflow reservoir. If there is, that is a considerable red flag and at that point you may want to consider doing a cylinder leakage test. How many miles do you have on it?
    BassAckwards and TnShooter like this.
  11. Jul 7, 2020 at 12:21 PM
    TXSTICK
    TXSTICK Active Member
    Chuck
    Tucson AZ
    2014 PreRunner TRD Sport Quad Cab 4.0
    Get a flash light and check for debris between the ac condenser and radiator. Could be partly blocked with a plastic bag or other things, also you might be surprised at how much stuff will come out if you reverse blow (with compressor) air thru the radiator and AC condenser. They pick up a lot of small crap. But best thought is fan clutch.
    P.S. also radiator cap may not be holding the correct pressure.
    Tacoma-toy likes this.
  12. Jul 7, 2020 at 1:42 PM
    anthony250f
    Anthony
    San Diego, CA
    you actually have to check the resistance. stop the truck and grab the fan with your hand, should have resistance
  13. Jul 23, 2020 at 12:35 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I’m having the same problem, but how much fan resistance is normal? I can spin the fan with one finger by resting it on there
    I am also losing coolant - 2006 225k miles
  14. Jul 23, 2020 at 12:54 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Check for leaking head gasket.
    Jeremy M., Tullie D and PzTank like this.
  15. Jul 23, 2020 at 12:58 PM
    Oreo Cat
    Last thing I need is to replace that
  16. Aug 5, 2020 at 3:20 PM
    Mxpatriot
    Following up - it was the fan clutch. Easy $60 fix.
  17. Aug 5, 2020 at 3:24 PM
    Oreo Cat
    Gives me hope. just bought a thermostat, fan clutch, and water pump today
  18. Aug 5, 2020 at 3:32 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    4.0?
    What’s the build date?
    If 12/05 or before, it’s a 4.0, and it’s overheating = head gaskets*
    *Confirm w a qualified mechanic.
  19. Aug 5, 2020 at 3:37 PM
    Muddinfun
    Muddinfun Well-Known Member
    Fan tests
    1. Some people stick their hand in the fan while it's running and see if they can easily stop the fan.
    2. Some people stick a rolled up newspaper in the fan to see if they can easily stop it.
    3. Some people shut the engine off and see if the fan continues to spin after the engine stops.
    If you slice your fingers off, it's not my fault.
  20. Aug 5, 2020 at 8:44 PM
    Oreo Cat
    How am I supposed to know the date of when the engine was made
