Overheating at low RPM - thoughts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, Jul 6, 2020.
  1. Aug 5, 2020 at 8:49 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Do the fan test above (with the newspaper and don’t go crazy on thickness). If you are losing coolant, you should probably use a dye and see where it’s going. If you can’t see it, it’s probably the head gasket.
  2. Aug 6, 2020 at 3:22 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Build date for the truck should be on the VIN sticker on the inside of your driver’s side door.
    Assuming it’s the original motor.
    If not, I think there’s a tag on the engine. Someone might be able to provide info.
    Good luck!
    Oreo Cat[QUOTED] likes this.
