Overheating at STOP please help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TruthInLies313, Jul 31, 2014.
  1. Jul 31, 2014 at 6:11 AM
    TruthInLies313
    TruthInLies313 [OP] Well-Known Member
    Blaine
    Texas
    05 V6 TRD Sport DC
    Tinted, 5701 Viper Alarm Electric Start, 6 Inch Fabtech Lift, 17'' XD Hoss Rims, K&N 77 Series Intake, BHLM, Black Emblems, Color Matched Dash rings, 2 JL 10's, Pioneer Double Din Head Unit
    2005 V6.
    My truck is overheating when I am at a stop. When I start driving it will regulate and go back to normal. Engine coolant hasn't been replaced in awhile. Could this cause it too? Thinking it could be fan, but it is running. Please help guys, i don't want to be screwed by a shop.
  2. Jul 31, 2014 at 6:17 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Does turning on the heater bring temps back down? You're sure the fan is coming on at idle?
  3. Jul 31, 2014 at 6:17 AM
    Outsider
    Outsider Well-Known Member
    Nick
    West Virginia
    2021 DCSB Tacoma Off-road Cement AT
    I wanted an MT.
    I had a ford ranger do the same thing...had the water pump replaced, that was not the problem...it was the thermostat...IDK if that is the case on a Tacoma, but it wouldn't hurt to try...mine was getting stuck in the closed position and the hot liquid wasn't able to get cooled.
  4. Jul 31, 2014 at 6:18 AM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    Positive the fan comes, haven't tried turning the heater on...will do
  5. Jul 31, 2014 at 6:23 AM
    Toyanvil
    Toyanvil Well-Known Member
    It sounds like your fan clutch is going bad.
  6. Jul 31, 2014 at 6:28 AM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    where can i find this? any way to test?
  7. Jul 31, 2014 at 7:20 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Sounds like the thermostat to me. Stuck partially closed? Higher RPM = increased coolant flow from the pump....
    I'd change the stat and flush/change the cooling system. Not too hard too do and not too expensive - and you said the freeze is older.
    Also, my engine light came on a couple times - code reader said eng temp.. Check for last stored code??
  8. Jul 31, 2014 at 7:37 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Check the water level.
  9. Jul 31, 2014 at 7:44 AM
    Revelations
    2014 MGM DCSB
    Easy way to tell if your thermostat is stuck shut: http://www.ehow.com/how_7683_tell-cars-thermostat.html
    Warm up the car but don't let it overheat--don't let the temperature gauge go into the red.
    2
    Turn off the engine.
    3
    Open the hood.
    4
    Find the upper radiator hose. It's black, is made of rubber and is about 2 inches in diameter, with metal clamps on either end. The upper hose goes into the top of the radiator.
    5
    Locate the lower radiator hose. It looks similar to the upper hose except that it attaches to the bottom part of the radiator.
    6
    Touch each hose very carefully (they can be extremely hot). If the temperature gauge is indicating that the engine is warmed up but one hose is hot and the other is cold, the thermostat is probably stuck closed, and the coolant isn't circulating through the radiator.
    7
    Have the thermostat replaced if this is the case.
  10. Jul 31, 2014 at 7:47 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    hey Blaine off topic but go and get your expert marksman ribbon with oak leaf cluster.
    rifle for ribbon and revolver for oak leaf. easy peasy to get (if you have aim of course!)
    talk to SP's sign up for it
  11. Jul 31, 2014 at 8:00 AM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2024 Tacoma TRD Off Road
  12. Jul 31, 2014 at 8:08 AM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    At a shop now. Gonna get fluid replaced. Then see what happens. They think it could be thermostat. God I hope I don't have any other issue. I'm tired of dishing money out.
  13. Jul 31, 2014 at 8:08 AM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    I would if I was staying in! Lol separating 29 sept
  14. Jul 31, 2014 at 8:28 AM
    Canufixit
    New England
    Also, When you stop the vehicle and the temp goes up. Put it in neutral and rev the engine to see if the temp goes down??
  15. Aug 1, 2014 at 4:31 AM
    Outsider
    Nick
    West Virginia
    I wanted an MT.
    if it is the thermostat...they are easily replaced and you can do it yourself.
  16. Aug 1, 2014 at 7:01 AM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    They flushed it and it isn't overheating now....im so confused
  17. Aug 1, 2014 at 7:58 AM
    Canufixit
    New England
    Well, there could have been some blockage in the radiator and the fan could not move enough air to cool the radiator - but the movement of air when driving added enough airflow to give enough cooling ??? That's why I asked if, when hot and at an idle, rev it up for a minute to see if the temp went up (partially closed thermostat or rad plugged?) or down (Pump going bad/ belt slipping ...
  18. Aug 1, 2014 at 9:34 AM
    gonathan85
    gonathan85 Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Here are my methods of diagnosing an overheating truck or agricultural equipment. Above All: CAUTION - when up to operating temperature, coolant in cooling system is HOT. Don't open a cap or remove a hose when engine is hot and coolant system is at operating temperature.
    1. Check Coolant Level & Look for Leaks
    2. Check Fan Belt / Fan / Fan Clutch (Make Sure Fan is engaging)
    3. Clean Radiator/Coolers (ALL surface area, not just easiest to access) (Use Caution to not bend the radiator vanes)
    4. Check Radiator Cap (if bad, won't hold pressure in coolant system)
    5. Check Thermostat
    6. When vehicle overheats, using infrared thermometer, check surface temperature of radiator in multiple locations. Look for drastic temperature differences - shows possibility of a plugged portion of the radiator core & result circulation issues.
    7. Check Water Pump (If Bearing/Seal is going out, and pump has a weep hole, a slow leak will be present here) (Also possible for impeller to be broken or spinning no shaft resulting in reduced coolant flow)
  19. Aug 20, 2014 at 11:45 PM
    coolbreeze
    coolbreeze New Member
    the OC
    2005 Tacoma 4x4
    I'm having the same problem. Will overheat at low rpm (about 1100rpm or less). I've changed the thermostat and coolant before, but seems to only happen on very hot days or long road trips. Any advice is greatly appreciated.
  20. Aug 21, 2014 at 12:18 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A common cause of this is an air pocket trapped in the system.
    See this page, about half way down the page is a video showing how to burp the system air out.:
    http://www.ericthecarguy.com/faq/what-to-do-when-your-engine-overheats
    Now let’s talk a bit about how to solve an overheating issue.
    The #1 cause of overheating is air in the cooling system. I say this from 20 years of experience as a technician. There are many causes of air getting into the cooling system, and finding the cause will be the key to solving the issue for good.
    What I see most often when it comes to air in the cooling system is an overheat that occurs after the vehicle has had a bunch of work done that involved opening up the cooling system. Some common symptoms include:
    • You or a garage just finished replacing a head gasket, water pump, intake gasket, radiator, heater core, or coolant hose, and now that the work is done, you have an overheat condition.
    • You have a condition where the vehicle starts to overheat, then suddenly drops to normal.
    • You have issues getting consistent heat from the vents.
    • Your idle fluctuates up and down and will not level out.
