Overheating issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coster090, Jun 1, 2016.
  1. Jun 1, 2016 at 11:00 PM
    Coster090
    Coster090 [OP] New Member
    murrieta
    1996 Tacoma 3.4 5 speed
    I recently had the motor rebuilt. And it started overheating. Replaced the thermo and pump did a flush and it is still over heating. I know there is probably a post somewhere on here but it is pretty urgent considering it is my only means of transportation. Any ideas of what the issue could be
  2. Jun 1, 2016 at 11:37 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    air in the system. backwards thermostat. backwards head gaskets. not a 50/50 mix of coolant/water.
  3. Jun 2, 2016 at 2:11 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What caused the Engine to fail in the first place ??
    What shape is the radiator in full of dirt
    Who did the engine ??
  4. Jun 2, 2016 at 3:25 AM
    Coster090
    murrieta
    Thanks for the response.
    Threw 2 valves in number 6 cylinder. Replaced the heads and valves. A Toyota mechanic did the rebuild.
    I'm going to drain the radiator again and look to if the core is clogged up.
  5. Jun 2, 2016 at 6:43 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Make sure the fan is running
  6. Jun 2, 2016 at 6:53 AM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    I did a complete rebuild at 197k miles. I had 3 different t-stats that were causing the truck to run very hot after a rebuild. Went to a Toyota OEM t-stat and it runs much better. Does it overheat when driving or only when idling? If idling, I would check the fan clutch. The radiator may very well be clogged and not allowing sufficient flow.
    Radiator - lower hose - t-stat - water pump - upper hose. It has to be one of those if the Head Gasket is good.
