Overheating, now doesn't start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smoke210dogg, Dec 14, 2020.
  1. Dec 16, 2020 at 9:28 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    As already explained above my post - a big mistake.
  2. Dec 16, 2020 at 9:33 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Any good junk yard could throw another motor in and warranty it for 30 days
    Kolter45 and Smoke210dogg[OP] like this.
  3. Dec 16, 2020 at 9:56 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    To me, the fact that it didn't overheat the second time may indicate an intermittently bad thermostat - assuming the OP verified there was sufficient coolant at the time (verifying the coolant in the radiator, and not just looking at the overflow tank), which wasn't stated.
    OP - the "foam" just looks like that because it's a combination of moisture (coolant or otherwise) and oil - like making mayonnaise. The blobs that look like bigger bubbles are larger drops of oil that are not emulsified into the mix. As others have stated, it's very common when engines don't get hot enough on short trips to evaporate the moisture that condenses. A lot of engines do that - not just Toyotas - so you can't judge a bad head gasket just by looking at the cap like that.
    Smoke210dogg[OP] and LancerRevo like this.
  4. Dec 16, 2020 at 10:40 AM
    Smoke210dogg
    Smoke210dogg [OP] Member
    Priscilla
    San Antonio, TX
    2005 black Toyota Tacoma pre-runner
    Water pump and radiator are okay. Oil is regular color not muddy. I tried to start again and makes a noise and does not want to crank at all. Tried to turn motor by hand but it wont move
  5. Dec 16, 2020 at 10:41 AM
    Smoke210dogg
    Priscilla
    San Antonio, TX
    yeah im looking right now
    Steves104x4[QUOTED] likes this.
  6. Dec 16, 2020 at 10:41 AM
    LancerRevo
    LancerRevo Well-Known Member
    Phillip
    2007 Tacoma Pre Runner V6 4.0
    Maybe the thermostat? Honestly not sure myself from here. Hopefully some others can chime in with some help
  7. Dec 16, 2020 at 10:43 AM
    Smoke210dogg
    Priscilla
    San Antonio, TX
    tried to start by hand but still didnt work. Gonna start looking for replacement motor
  8. Dec 16, 2020 at 10:46 AM
    Smoke210dogg
    Priscilla
    San Antonio, TX
    one dude wanted take the catalyst convertor and clean it out. im dumb but not stupid LOL
  9. Dec 16, 2020 at 11:37 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Good idea. Get one from a 2007-2011 because those will drop right in
  10. Dec 16, 2020 at 11:44 AM
    tak1313
    2013 Base 2WD
    If there is sufficient coolant (actually in the radiator), and there is no indication of coolant in the oil, it MAY simply be a bad starter/solenoid. Remove the plugs and try cranking it as Jimmyh recommended.
    If it cranks and coolant shoots out of any cylinder, you know the starter is good and the engine may have been hydro-locked (which potentially goes way beyond a bad head gasket). If it still doesn't crank, it's a totally unrelated issue with your starting system (such as bad starter/solenoid) that just happened to happen at roughly the same time.
    A few weeks ago, I added some Lubrigard to my trans as preventative maintenance, and the CEL immediately turned on with an O2 heater code. COMPLETELY unrelated, as the pin in the O2 connector was corroded enough to coincidentally disconnect just as I added the Lubrigard.
  11. Dec 16, 2020 at 1:10 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Sounds like you need a new motor and mechanic.
    Jimmyh likes this.
  12. Dec 16, 2020 at 2:55 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Buy a new radiator, too
    Smoke210dogg[OP] likes this.
  13. Dec 16, 2020 at 4:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I see you don't want to go into any details... Not much we can do to assist with no data.
    Good luck with your portable mechanic.
  14. Dec 16, 2020 at 4:43 PM
    Smoke210dogg
    Priscilla
    San Antonio, TX
    Finally found a guy and when he tried to crank it, made a loud noise and still didnt catch. He got underneath and tired to turn the motor by hand and its warped. Everything else looked good for now. Thanks for the help
  15. Dec 16, 2020 at 5:18 PM
    #35
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    ohh yeah . . . somethings warped . . .
    Fastrat and Muddinfun like this.
  16. Dec 16, 2020 at 5:29 PM
    #36
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
  17. Dec 16, 2020 at 6:41 PM
    #37
    Mossyjaws
    Mossyjaws Well-Known Member
    VA
    2015 dclb
    Footprint Gas Pedal
    Nothing worse than a warped engine...
  18. Dec 16, 2020 at 6:56 PM
    #38
    Lester Lugnut
    I interpret this to mean you put a 27mm or whatever socket on the end of the crankshaft bolt and tried turning? If this is not the case, what did you do to "turn the motor by hand"?
  19. Dec 16, 2020 at 7:34 PM
    #39
    Jimmyh
    SC
    2012 Prerunner SR5
    Did you remove the spark plugs as I suggested?
    Do that then try and turn the engine...
    Dm93 likes this.
  20. Dec 16, 2020 at 7:36 PM
    #40
    Smoke210dogg
    Priscilla
    San Antonio, TX
    Yeah I think it was 22mm can't remember but yeah that's how I did it
