Overheating problem HELP!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mikey560, Sep 16, 2012.
  1. Sep 19, 2012 at 5:11 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Consider the cheap and easy before going to the hard and expensive. Considering that the engine was replaced, suspect owner neglect. Get an IR temp gun, check the radiator for cold spots. If there is a blockage in the radiator, there will be a loss of cooling/overheating.
  2. Jul 17, 2018 at 3:54 PM
    kozinator
    kozinator Member
    David
    2003 Tacoma Pre-Runner SR5
    All LED lighting, 31” tires, painted flares, toolbox, 20” LED light bar, aftermarket radio, interior lighting, gun rack, CB Radio and Antenna
    I had this same problem in my 2003 Tacoma at about 185,000 miles. Just changed the waterpump.
  3. Jul 17, 2018 at 4:02 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Holy thread revive Batman
    Wadar likes this.
  4. May 15, 2019 at 11:07 PM
    alasek
    alasek Member
  5. May 15, 2019 at 11:12 PM
    alasek
    alasek Member
    Did you find the problem with your Tacoma about overheating?
    I have a 2000 Tacoma and it has the same problem
    I just did a headgasket on it and before I did it it wasn’t overheating but losing coolant
    Now after the head gasket job it overheats and I tried bleeding, thermostat and still the same
  6. May 15, 2019 at 11:18 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Might need a flush or even new radiator if it won't unplug. No flow, no cooling.
  7. May 17, 2019 at 9:12 PM
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    I would also do a compression test on the cyclinders to make sure you don’t still have a head gasket issue.
  8. Jan 23, 2021 at 3:04 PM
    Toyotaholic1998
    Toyotaholic1998 New Member
    1998 Toyota Tacoma
    2.5 inch old man emu 33x12.50 15x10 -47
    My Tacoma is having the exact same issue I recently did head gaskets.... what did you end up doing to fix it
  9. Jan 23, 2021 at 4:43 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Have you done a radiator flush?
  10. Jan 31, 2021 at 9:42 AM
    Toyotaholic1998
    1998 Toyota Tacoma
    I just had the same issue and realized when my engine was put back together the left head gasket went on the right side and the right head gasket went on the left side. Which blocked 2 coolant passages
