Overheating Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jakernv1027, Jul 18, 2023.
  1. Jul 18, 2023 at 4:21 PM
    jakernv1027
    jakernv1027 [OP] Member
    Jacob
    2013 Black Tacoma TRD Offroad
    Front and rear suspension. Cold air intake. 3” lift
    I have a 2013 Tacoma TRD offroad. Last summer it over heated twice but then stopped and never did it again. It is now overheating more frequently. It only does it when I’m going slow and up hill. Or when I leave it running with the AC running on. However, if I put the heater on it stops the temperature from rising or cools it down.
    I’d imagine it’s one of the following:
    Water pump, Fan Clutch, Thermostat or Needs a coolant flush. But I could be way wrong I’m not all that mechanically inclined.
    Trying to narrow it down before buying all 3 and replacing them.
  2. Jul 18, 2023 at 5:42 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    jakernv1027[OP] likes this.
  3. Jul 18, 2023 at 6:13 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    when was the last time you cleaned your radiator of bug remains and dirt? and what's your coolant look like, no harm in running just water for a few days to start with a flush and decide if you need to do more
  4. Jul 18, 2023 at 6:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Start with the basics, have you checked the coolant level and condition in the radiator (not just the overflow bottle) with the engine cold?
    Is the radiator, A/C condenser, and area between them clean and free from debris?
    Next thing is the fan clutch, with the engine idling hot the fan should be spinning at a moderate speed and moving a moderate amount of air. If the fan is turning slowly with the engine running and/or keeps turning more than about a second after the engine is turned off it's bad.
    Very rare for a water pump to fail in a manner that would cause it to stop pumping or lose pumping efficiency, typically they either leak or the bearings fail.
    Thermostat is possible but if it gets stuck closed you would overheat under all conditions.
    lbregman and b_r_o like this.
  5. Jul 18, 2023 at 8:01 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I'd drain the radiator and block, fill with water, run till hot, then drain both again and refill with fresh coolant.....if it's over heated once before the coolant likely could stand to be replaced at the least anyway.
    Also with the overheating happening when it's sitting still that would really make me want to check that fan clutch.
  6. Jul 18, 2023 at 8:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Light a cigarette and hold it near the grill, see if the smoke is getting sucked through the radiator fairly quickly
  7. Jul 18, 2023 at 9:12 PM
    kidthatsirish
    Or a left over smoke bomb from the fourth of July...
    Oh, and something often forgotten but worth checking is the belt and tensioner.
    GilbertOz likes this.
  8. Jul 19, 2023 at 12:04 PM
    TacoTuesday1
    FL
    I have never dealt with this on a 2G so I can't say specifics, but I can say vague things
    when you get up there in years and miles, if you want to be safe and do preventative maintenance, you can replace the WP.
    but mine still works on an 08 with likely higher miles. I still need to replace it, it's just a pain.
    I assume yours being 13 it's not having HG failures like 05/06.
    temp sensors can fail, but that's more of a German car thing.
    fan clutch? Test it by seeing if it has resistance when you push it. Make sure it spins when running too.
    Tstat? I don't think that's testable. But why not throw one in. They're easy to change, don't really spill coolant during replacement, and are cheap. You could start with that.
    Coolant flush? I mean yeah, they're good to do, but doesn't usually cause overheating. So I'd say if separately it's due, then go ahead and do it.
    Hopefully you're not low on coolant or leaking it.
    Replacing the coolant is good maintenance. And filling it properly will give you the peace of mind of ruling that out of the equation, knowing the system is full and without air pockets.
    any one failure can cause issue. But so can the tstat, being kinda the easiest and cheapest to replace. It's plastic.
    IDK about when hot/engine on, but when cold, you can potentially also spray clean (gently) the condenser off (idk about reaching the radiator) to get insulating dirt off. But that's a minor thing, not a cause of major issue
    I try not to be greedy with the Tacoma and think that just because it works, it should be neglected
    because if you think about it, look at most other vehicles out there, that work in a similar manner
    yours is 2013. it's not 2023. That's 10 years.
    Most other cars are needing to get all of those parts and more by that time.
  9. Jul 19, 2023 at 5:10 PM
    Waasheem
    Waasheem
    2007 xrunner
    Long ago, I was shown a film on testing a thermostat in high school auto shop. They suspended it in a pot of water with a thermometer in the water. Turned on the heat, when the thermometer reached whatever temperature, the thermostat opened. Kinda impractical, you’d have to remove it.
    I use a ir thermometer, engine running. I’ll point it at the block, thermostat housing, and upper radiator hose. When the thermostat housing reaches temperature, the upper radiator hose temperature will go up, then slowly go back down. I also like to read the upper and lower radiator hoses to see how well the radiator is working.
    I use a Raytec mt6. In 2011, all my tools were stolen. The old one worked much better than the new one. It does work but it’s difficult. I wouldn’t recommend getting that one.
  10. Jul 20, 2023 at 1:44 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Basics:
    Change the coolant draining and flushing block via 2 block drains one each side and petcock on radiator.
    Cheap also is a new thermostat that comes with the housing when the coolant is already out.
    Buy a new pressure cap note the rating is stamped on it.
    Go to McGeorge Toyota site online enter your VIN and lowest OEM prices and very fast usually within 3 days.
    Aftermarket coolant can be bought at parts stores in pink specifically Asian with Toyota listed - need 2 gallons of the 50/50 premix but OEM same price.
    TW has help videos of coolant changes if you need one.
    The thermo housing is kinda a bitch to get to the little nuts holding it on and it really helps to own a set of the hose clamp pliers as channel locks don't fit in there.
  11. Jul 20, 2023 at 5:30 PM
    kidthatsirish
    Any word on your truck? I hope you have been able to find an issue or come to some sort of conclusion.
