overheating troubleshooting tips
Discussion in '1st Gen. Tacomas (1995-2004)' started by Clover, Jul 27, 2012.
  1. Jul 27, 2012 at 4:51 PM
    Clover
    Clover [OP] Member
    La
    95 ext cab 2.4. 4wd
    I have a 95 with a 2.4L 4wd that overheated the other day...blew the upper radiator hose. swapped the hose out and got her running again, but i am still getting a higher temp reading than it used to read. this was just at an idle for 5-10 mins. I shut her down before she got too hot. the top hose is hot, bottom hose is cool as can be. if i squeeze the lower hose i can hear water moving around inside. I assume that means that it's the radiator, but i am not certain. My next step is to flush it out, or replace it. any helpful advice on a diagnosis, cheap parts or possible causes? Thanks in advance.
    Clover
    Hammond, LA
  2. Jul 27, 2012 at 5:15 PM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Have you checked the oil by chance? How many miles?
  3. Jul 27, 2012 at 5:16 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    sounds kinda like the thermostat isnt opening?
  4. Jul 27, 2012 at 5:32 PM
    Smokey11
    Smokey11 You Can't Fix Stupid !
    Jeremy
    Anchorage, Ak
    99 ex-cab TRD 2.7L 4X4
    OME 881, 10MM top plate spacer,nitros,wheelers 5 pack, 1.25 Daystar Shackles,265-75-16 Duratracs on 16X8 Pro Comps,leer shell, husky liners, sway bar removed, X-runner badges, tint, auto start, BPV relocate, extended rear brake line.
    ^ This would be my guess.
  5. Jul 28, 2012 at 1:51 PM
    Clover
    Clover [OP] Member
    La
    95 ext cab 2.4. 4wd
    oil level is good, it leaks a little from the rear main so i have to moniter it regularly
    just changed out the thermostat and it still gets hot. i am thinking radiator, water pump, and fan clutch are in need of a replacement, also a compression test is in order. thanks for the quick responses, very much appreciated
  6. Jul 28, 2012 at 1:54 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Does your heater blow hot air when it's up to temp?
  7. Jul 28, 2012 at 2:12 PM
    Clover
    Clover [OP] Member
    La
    95 ext cab 2.4. 4wd
    no hot air from heater 203000 miles
  8. Jul 28, 2012 at 2:14 PM
    Clover
    Clover [OP] Member
    La
    95 ext cab 2.4. 4wd
    i thought that the fact that no hot air coming out at norm idle temp was a bit odd. what is that due to?
  9. Jul 28, 2012 at 3:00 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The heating valve isn't opening or the fluid is not circulating
  10. Jul 28, 2012 at 8:11 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) I hate to tell you, but you have a 17 year old Taco and the radiator is clogged shut. You are not exchanging heat in the air fins that make up the radiator. They are clogged up and not letting water/coolant flow through them. The water may move from top to bottom, but no heat is being exchanged from the coolant/ water. I would replace the radiator first and see if it over heats again.
    You could also be having a failing water pump, if it over heats at idle with a new radiator installed. This should cure your problem.Good Luck.
  11. Jul 31, 2012 at 5:17 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    Was a PreRunner, now it isn't
    this sounds like it and you may have a big air bubble in the system. When you refilled the coolant did you run the engine and run new coolant through the block? You can do this by leaving the top rad hose off the radiator side and when the thermostat opens it will run water out the top hose and into a bucket. It flushes the system, gets all the bubbles out, and verify that the thermo is opening.
