Overheating while ac is on at a stop or slow speed .
Discussion in 'Technical Chat' started by johnnym, Jun 3, 2013.
  1. Jun 3, 2013 at 2:41 PM
    johnnym
    johnnym [OP] Well-Known Member
    john
    NH
    87 4Runner , GMC 2500 , Honda Accord
    So I got a 05 trd offroad 4.0
    Last weekend I was wheeling and it was around 90* outside . I turn on the ac then the temp gauge shot up pretty high . I stopped cranked the heat rolled down the windows and stood outside for 5 minutes . Temp came back down to normal operating temp . Continued the day without using the ac and the truck didn't overheat .
    While normal street driving I can use the ac and it doesn't overheat and the ac is cold like it should be .
    Things I've checked .
    Coolant is full .
    Belt is good
    No leaks
    Ac compressor was replaced when I bought the truck at 40k I now have 100k on it .
    Anyone have any ideas . Or things to check ?
  2. Jun 3, 2013 at 6:59 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    Check the fan clutch. With that many miles it may be on the weak side to cool at low speeds.
  3. Jun 4, 2013 at 6:28 AM
    johnnym
    john
    NH
    Thanks buzz . I'm going to look into that today .
  4. Jun 4, 2013 at 6:37 AM
    lowcountrytj
    lowcountrytj Third Member
    Phillip
    Probably at Work
    2012 DCLB TRD SPORT "BLACKOUT"
    Yeah fan clutch or time for water pump and flush?
  5. Jun 5, 2013 at 7:17 PM
    Mr.Jack
    Mr.Jack Active Member
    Wilmington, NC
    The Black Pearl
    Remote Start, 4 Hella Lights, Brush Guard, Grey Wire
    Honestly sounds like fan clutch to me.i just did mine and it makes a world of difference. You can test it by getting the truck up to operating temp and trying to stop the fan with a rolled up newspaper. If you can slow it to a stop, replace it. 122 $ at advanceauto.
  6. Jun 5, 2013 at 8:13 PM
    johnnym
    john
    NH
    Thanks jack
    I'm putting my money on the fan clutch myself . Ill try the newspaper trick in the morning . Did you need to remove the upper radiator hose to replace the clutch ? I guess I might as well replace my coolant while I'm at it.
  7. Jun 6, 2013 at 3:57 AM
    Mr.Jack
    Wilmington, NC
    The Black Pearl
    No, just disconnect the shroud for more wiggle room. It's easy. I'll only drain fluid and replace when I do the timing belt since it will be in pieces then.
  8. Jun 6, 2013 at 2:41 PM
    johnnym
    john
    NH
    Ya I tried that earlier in the week . Didn't help . I picked up a fan clutch today. Try to get that in this weekend . Thanks though .
