overheating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tanker34d, Jun 11, 2011.
  1. Jun 11, 2011 at 3:54 PM
    tanker34d
    tanker34d [OP] New Member
    TX
    05 PreRunner
    cold air intake
    Radiator keeps backing up into the resevior but temp gauge is normal just changed thermastat didn't help even flushed the cooling system 05 PreRunner 230000 miles
  2. Jun 11, 2011 at 3:57 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Maybe the radiator cap is bad and not keeping the system pressurized? Have you checked your fan clutch?
  3. Jun 17, 2011 at 11:41 AM
    Norcan
    Norcan What we don't have we make.
    Jerry
    Elora, ON Canada
    11 Tacoma Double Cab TRD
    Bakflip F1, BakBox, Sportwing Colour matched door mouldings, Weathertech floor liners, Toyota running boards,Toyota Hood Deflector,Pop N Lock power tailgate lock, Custom Otterbox defender mount for IPhone 4, Blu Logic Large button kit, BonGiovi DPS, fog light on with parking light low beam and high beam mod, TRD Exhaust, Muth heated signal mirrors, Liquid Metal Rhino Wheels in Black!, Redline Elite hoodlifts, EZ down tailgate,
    Sounds like a cyl head gasket. Sorry!!! Have your coolant checked for hydrocarbons. Look into the rad with the truck running. if you see tiny bubbles in the coolant this is your problem. Good luck! I have had this problem with my subaru forester. If you leave it too long the top rad hose will fill with gases and the system will stop flowing.
  4. Jun 17, 2011 at 1:57 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    get the cap pressure tested, or just toss a new one on there.
    if not,then have the system pressure tested. 230k miles is ALOT!! nicely done!
  5. Jun 17, 2011 at 5:06 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    X2 A good shop will have a gas analyzer just get them to sniff the rad. dead give away.
