Overheating
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyochica123, Aug 4, 2016.
  1. Aug 4, 2016 at 9:30 AM
    Toyochica123
    Toyochica123 [OP] New Member
    04 toyota tacoma
    04 toyota tacoma prerunner headache, its overheating put new thermostat changed radiator water pump clutch fan sensors tested for leaks and theres none. If i remove thermostat and run with out it its fine. Put new thermostats various ones and over heats. Im out of ideas does anyone know what else i can do
  2. Aug 4, 2016 at 10:07 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Well if you removed the thermostat and it runs fine, that's your problem. Are you installing it properly?
  3. Aug 4, 2016 at 10:11 AM
    eon_blue
    Azusa, CA
    I've had occassional overheating issues with my 04 as well, only when in 4lo for extended periods of time though. Mine is likely due to my supercharger and the aftermarket electric fans I have.
    Someone recommended I try running a coolant additive called Purple Ice in my coolant, I bought some (like $10) and put it in, it kept me from overheating last time I was out wheeling. It helps to stabilize your coolant operating temperature.
    If your overheating is serious then its not going to fix it, but if it's an occasional thing then this might help. Water Wetter is another brand I've heard good things about
  4. Aug 4, 2016 at 7:49 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Does it overheat just idling? Does it overheat on the freeway? Or both?
  5. Aug 6, 2016 at 11:21 AM
    Toyochica123
    04 toyota tacoma
    A little at idle but as soon as i put on drive it goes up immediately
  6. Aug 6, 2016 at 11:28 AM
    Toyochica123
    04 toyota tacoma
    Yes i installed it properly and still over heats. I bought 4 thermostats tested them with boiling water then put it in. Weird though that with the thermostat on water won't recirculate and with no tbermostat its fine
  7. Aug 6, 2016 at 12:00 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Are you using OEM Toyota parts?
    I'd do a coolant combustion gas test to rule out a blown headgasket.
    Pabloeeto likes this.
  8. Aug 6, 2016 at 12:09 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    how many miles on the ODO?
  9. Aug 6, 2016 at 12:55 PM
    Toyochica123
    04 toyota tacoma
    Did that already im like out of ideas
  10. Aug 7, 2016 at 1:16 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    How hot does it get? Do you have a scanguage or similar? It's over 100 degrees here in Big D and mine will occasionally hit 200. It's typically rock steady at 193. But if you're getting close to 215 220 and climbing that's troubling.
    I doubt this is a major factor but be sure the jiggle valve on the thermostat is in the 6 o'clock position. (Yeah the old jiggle valve debate again.) Some have shown pretty strangely and reliably an increase in temp if it isn't in the 6 posish. Just a theory. But it does belong in the 6 o'clock.
  11. Aug 7, 2016 at 6:02 PM
    cruiserguy
    Elijah
    SEKS
    That's only on the V6 engine, no? On the 4 banger it still goes in with the jiggle valve at 12 o'clock.
  12. Aug 7, 2016 at 9:48 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Hummmm well that I don't know. Sorry man. That's a strange predicament you have there. Everything screams thermostat. I mean, they can't ALL be bad.
    Someone asked if they were Toyota thermostats, maybe try one of you haven't already. :confused:
  13. Dec 12, 2016 at 6:44 AM
    rcannon440
    rcannon440 New Member
    Rob
    My son has a 1998 Tacoma Limited V6 and we have been chasing this same problem for more than a year. With a thermostat installed the truck overheats and the temp gauge pegs out without the thermostat it actually runs to cool. We have also tried different thermostats and checked the position of the jiggle valve. We have replaced the radiator, water pump and fan clutch. I was wondering if there was any resolution to this problem?
  14. Dec 12, 2016 at 12:00 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Correct!!
  15. Dec 12, 2016 at 12:04 PM
    bry838
    oregon
    Gosh thats really strange the whole system has been changed and no resolution. I recently fought an overheating issue. Ended up being a partially restricted rad but you changed that and your thermostat deal is really weird. The hang up has to be with that id imagine???
  16. Dec 12, 2016 at 12:31 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    radiator might be clogged/restricted internally...
  17. Dec 12, 2016 at 12:40 PM
    98tacoma27
    Ben
    Not Beech Creek
    Do you have heat in the cab?
  18. Dec 12, 2016 at 1:23 PM
    cruiserguy
    Elijah
    SEKS
    Lol, I was getting ready to type just that before getting to your post.
  19. Dec 12, 2016 at 2:51 PM
    rcannon440
    Rob
    Yes there is heat in the cab.
  20. Dec 13, 2016 at 6:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    It sounds like you definitely have flow inside the motor. I would suggest burping it. There could be an air pocket under the thermostat which won't let it get to temperature. Park it on a steep incline, steep enough to get the rad opening above the motor (ramps should work). Then run it with out the cap, but be cautious of it splashing.
