Overland Expo West 2018 (Flagstaff, AZ) May
Discussion in 'Arizona' started by SixthSnail, Oct 26, 2015.
  1. Apr 25, 2016 at 11:01 AM
    #681
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yessir. x2. got all my stuff from them.
    perfect. lets do it. I just need to replace my shit. my antenna might be good still tho.
    Lets tune! up in flag? on the way up?
    snowtank[QUOTED] likes this.
  2. Apr 25, 2016 at 11:02 AM
    #682
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Its already all mounted.its on my driver side back above the tail light. I just dont know whats going on with my cb right now. It was working. Then all of a sudden it was locked on channel 9. And now it doesnt turn on. So I think its fried and I need to just get a new unit
  3. Apr 25, 2016 at 11:03 AM
    #683
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Ooh thinking bout it!
    snowtank likes this.
  4. Apr 25, 2016 at 11:03 AM
    #684
    SixthSnail
    SixthSnail [OP] I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Mine is going on the roof rack.
  5. Apr 25, 2016 at 11:05 AM
    #685
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    At least they are super cheap now a days... especially used. I'm relocating my antenna from the roof rack where it hits everything possible to the bed corner. I picked up a bracket for each corner so I can put the CB antenna on one, a lighted whip on the other. I just hope my ant cable is long enough.
  6. Apr 25, 2016 at 11:06 AM
    #686
    snowtank
    Andrew
    Arizona
    Oh I edited as you quoted. Mine Is mounted driver side back corner above tail light 18' of coax reaches all the way up to passenger floor board
  7. Apr 25, 2016 at 11:07 AM
    #687
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    should be if its a standard CB Coax. mine is ran from the center console to the driver side back corner of my bed.
    EDIT: Andrew beat me.. off....
  8. Apr 25, 2016 at 11:07 AM
    #688
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I'm hoping mine reaches from the back left of my rack to my driver footwell with an 18ft cable.
  9. Apr 25, 2016 at 11:09 AM
    #689
    snowtank
    Andrew
    Arizona
    [QUOTE:"SixthSnail, post: 12324192, member: 139599"]I'm hoping mine reaches from the back left of my rack to my driver footwell with an 18ft cable.[/QUOTE]
    Shouldnt be a problem. I still had about 8" to spare.
    Thats what he said :D
  10. Apr 25, 2016 at 11:10 AM
    #690
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Thats what he said :D[/QUOTE]
    Mine has to run from up there, down the rear panels, to the front.
  11. Apr 25, 2016 at 11:11 AM
    #691
    Techoma
    Alta Mesa, AZ
    Did it feel good?
  12. Apr 25, 2016 at 11:11 AM
    #692
    snowtank
    Andrew
    Arizona
    Yeah I dont think you will have a problem
    SixthSnail[OP] likes this.
  13. Apr 25, 2016 at 11:12 AM
    #693
    snowtank
    Andrew
    Arizona
    :anonymous:
  14. Apr 25, 2016 at 11:22 AM
    #694
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    always!
    <3
  15. Apr 25, 2016 at 11:26 AM
    #695
    snowtank
    Andrew
    Arizona
    All this talk im getting more excited to go now! Less than a month boys
    StOrMyThEtAcO likes this.
  16. Apr 25, 2016 at 11:34 AM
    #696
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    My sub list is super long. I don't always hit all of them. I typically update monthly but you have a 3rd gen. If you still had your 2nd gen, id visit more ;)
  17. Apr 25, 2016 at 11:58 AM
    #697
    Techoma
    Alta Mesa, AZ
    LOL
    Just checked my Amazon order records... coax is 12 ft!
  18. Apr 25, 2016 at 12:03 PM
    #698
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I need just the threaded part that goes into the spring and through the mount to the nut/coupler on the underside. Its stripped/crossthreaded so I cant crank down on it to get it tight ont he mount. it wiggles around. cant take it off either. gonna cut it.. so need the threaded portion and maybe even a spring.
  19. Apr 25, 2016 at 12:14 PM
    #699
    snowtank
    Andrew
    Arizona
    LOL
    Just checked my Amazon order records... coax is 12 ft![/QUOTE]
    Yeah. That will be fine for just your cab. But not the rest. Where are you mounting the unit?
  20. Apr 25, 2016 at 12:16 PM
    #700
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    always order your coax too long and trim to fit!
