Overland Expo West 2018 (Flagstaff, AZ) May
Discussion in 'Arizona' started by SixthSnail, Oct 26, 2015.
  1. Apr 25, 2016 at 10:20 PM
    #741
    SixthSnail
    SixthSnail [OP] I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Well those are within 3 months... If any Uniballs need to be replaced that often on street trucks, then something is wrong. Those didn't seem like they had maintenance issues.
  2. Apr 25, 2016 at 10:27 PM
    #742
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    There are hundreds of factors that can lead to premature wear and most people don't understand that. You may see a Uniball in any arm looking like that after a week. The 4Runner Arm is very clearly pitted which would be caused by something getting trapped inside the Uniballs. Something that I try to explain to people all the time is in regards to the use of caps on top on Uniballs. While they do a great job keeping the majority of stuff out, at the same time they also create a situation where it makes it impossible for debris to escape if trapped under the cap which will eventually work its way through the uniball and damage the lining
    The majority of prematurely worn or loose Uniballs we see come from people using an oil based lubricant like WD40 on them which only attracts more dirt and dust and will prematurely deteriorate the Teflon lining inside causing excessive play.
    Milota95 likes this.
  3. Apr 25, 2016 at 10:28 PM
    #743
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Interesting. I've wondered about the caps myself. Wasn't sure if I should have them.
  4. Apr 25, 2016 at 10:29 PM
    #744
    tubbsisland
    Cliff
    Arizona
    Icon uses an FK uniball in their arms, they are not made by Icon. Camburg uses a cheaper Auoura Uniball and I believe TC does as well but I'm not 100% sure on that
  5. Apr 25, 2016 at 10:36 PM
    #745
    tubbsisland
    Cliff
    Arizona
    Pros and cons to them but generally I do not recommend them unless in the most extreme salted road environments. But it's still better even then to simply be diligent about washing them out periodicly and using a healthy does of TriFlow to help keep the Teflon lining in good shape.
    Almost 40k miles on my Camburg kit, on original Heims and Uniballs and all are still in great shape. I do check them frequently.
    All this talk aside, Camburg Arms are stil, my overall preference. Now let's carry on with the overland talk! I'll be heading up on Wednesday Night
    ODNAREM likes this.
  6. Apr 26, 2016 at 4:33 AM
    #746
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Pretty sure TC is a 1" FK ball when I was researching replacing them from mine.
  7. Apr 26, 2016 at 4:54 AM
    #747
    G.T.
    G.T.
    CONUS
    The spares that TC sold me are FK's.
    llibrm and 2ndGenJonny[QUOTED] like this.
  8. Apr 26, 2016 at 4:57 AM
    #748
    2ndGenJonny
    Jon
    Gilbert, AZ
    You paid the 180$ they charge? You can get them for under 50$ a piece from other online sources. :(
  9. Apr 26, 2016 at 5:00 AM
    #749
    G.T.
    G.T.
    CONUS
    I was given a slight discount... :spy:
    2ndGenJonny[QUOTED] likes this.
  10. Apr 26, 2016 at 7:04 AM
    #750
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Got FK's from Camburg when I rebuilt mine as well.
  11. Apr 26, 2016 at 8:26 AM
    #751
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    I have some ball joints I bought from auto zone work great ! :rofl:
    2ndGenJonny likes this.
  12. Apr 26, 2016 at 8:32 AM
    #752
    tubbsisland
    Cliff
    Arizona
    yep I wasnt 100% sure so I confirmed it this morning when I got in. TC uses a spec FK uniball in their arms but a normal WSSX16T will work just fine as well for a replacement. They run $48.
    They use a mix of both, it depends on the application but replacement parts are almost always going to be FK products.
  13. Apr 26, 2016 at 8:41 AM
    #753
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Put me on the list, please.
  14. Apr 26, 2016 at 9:04 AM
    #754
    Milota95
    Qrampage
    B.F.E
    Driven Safely
    You camping out ?
  15. Apr 26, 2016 at 9:08 AM
    #755
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Definitely. Going up Thursday afternoon, leaving Sunday.
    XPOTRON likes this.
  16. Apr 26, 2016 at 9:08 AM
    #756
    Milota95
    Qrampage
    B.F.E
    Driven Safely
    We got a group meeting up Thursday night if you wanna join
    XPOTRON and ODNAREM like this.
  17. Apr 26, 2016 at 9:09 AM
    #757
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Sounds good to me. Let's coordinate before departure.
    Milota95[QUOTED] likes this.
  18. Apr 26, 2016 at 9:10 AM
    #758
    Milota95
    Qrampage
    B.F.E
    Driven Safely
    Awesome ! I'll add you :)
  19. Apr 26, 2016 at 9:31 AM
    #759
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Anybody else taking Stoneman Lake Rd in? Looks like more fun than the highway. Just a dirt road.
    ODNAREM likes this.
  20. Apr 26, 2016 at 11:38 AM
    #760
    2ndGenJonny
    Jon
    Gilbert, AZ
    I live in the east valley and will go up via Payson. It would take me 40 min to get to the 17 in North Phoenix when I can be in Payson in an hour via the Beeline.
    Brian007Taco likes this.
