Overland Rig Leaf Pack Question.
Discussion in 'Off-Roading & Trails' started by Comatose, Aug 13, 2017.
  1. Aug 13, 2017 at 10:57 AM
    Comatose
    Comatose [OP] You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    I realize this belongs in the suspension forum, but I'd rather source here. I'm planning on putting a full bed pack rack and occasionally putting a roof top tent with gear in the bed to camp. I want a new leaf pack that will match my 2.5" front lift but won't sag with the loaded bed. Conversely, I don't want the truck to stink bug when the bed is empty. What has worked you you guys in this realm?
  2. Aug 13, 2017 at 11:03 AM
    Ackrite
    Ackrite Well-Known Member
    SoCal
    1985 Toyota Pickup 4x4 single cab
    You ever consider air bags in the rear?
  3. Aug 13, 2017 at 11:03 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  4. Aug 13, 2017 at 11:05 AM
    Comatose
    Miguel
    San Diego, CA
    I have considered it, but I'm exploring both options. I've been the aal route and getting away from it.
  5. Aug 13, 2017 at 11:25 AM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    Skip AAL and get a full pack of Dakars. I had a set of Dakars with an overload taken out (good deal and pre- RTT) and it started to sag some with a medium height rack and RTT. I added an AAL into my Dakars and it worked well with the weight of RTT and camping gear in the bed. It's ass high with an empty bed now. But I have another rack and RTT in my future.
  6. Aug 13, 2017 at 11:59 AM
    Comatose
    Miguel
    San Diego, CA
    Are the Dakars meant to replace the factory overload?
  7. Aug 13, 2017 at 12:02 PM
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    Dakar leaf pack, if you get overloaded for that(unlikely based off your listed needs), then you can throw an AAL in there.
  8. Aug 13, 2017 at 1:53 PM
    Comatose
    Miguel
    San Diego, CA
    Will the factory bils work with this pack? And if they don't, I'm guessing the nitrochargers will. Do I have to replace the brake lines?
  9. Aug 14, 2017 at 3:52 AM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    There's no leaf pack that won't "stink bug" at least a little bit between loaded and unloaded. Only way to get around that is with air bags.....or link the rear and use adjustable COs and adjust them every time you change the weight in the bed.
    I've got Dakars and I've been pulling my shell on and off for a couple months now and the height in the lift changes a bit between the two even with the 200lb-ish the shell weighs.
    No they will not, Dakars provide too much lift for the stock shocks, especially unloaded. You need to pair the right size shock for those leaf packs.
    Yes, you need extended brake lines if you plan on offroading.
    jbrandt likes this.
  10. Aug 14, 2017 at 10:45 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you have a highly variable weight in the back, your only real option would be airbags.
    The all pro expo pack (full leaf pack) I hear are great, tho I dont speak from personal experience. The dakars are very well respected, too.
    But even if you get deavers or fully custom alcans, you'll either be really stiff when you take the weight out, or it'll sag like a mofo when you put the weight in.
    Airbags are really what you need, but as with everything, there is still likely to be compromise. Airbags might limit your travel, depending on how they are installed, and they require a compressor. But hey, I know you were looking for an excuse to install on-board air...
    Comatose[OP] likes this.
  11. Aug 14, 2017 at 10:47 PM
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    Icon rxt
  12. Aug 18, 2017 at 8:13 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    If you want the best option and have some fab skills or know someone who does, do the 63 swap. It's better than any aftermarket leaf pack available.
    Ackrite likes this.
  13. Aug 18, 2017 at 5:06 PM
    Ackrite
    SoCal
    At least on the pre-Tacoma pickups like mine, they are better than any aftermarket setup. They give a decent lift, travel, and better load capabilities, especially if you get them off 2wd 2500hd's.
    Trident904[QUOTED] likes this.
  14. Aug 25, 2017 at 2:02 PM
    Comatose
    Miguel
    San Diego, CA
    I went with the Dakars and Nitrochargers. Installed them today I love them, they are amazing, easily a good choice. Thanks for the help guys!
    Trident904 likes this.
