Overland set-up total vehicle weight...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by r_ben65, Aug 8, 2023.
  1. Aug 8, 2023 at 10:24 AM
    r_ben65
    r_ben65 [OP] Well-Known Member
    Robert
    2023 TRD Off-Road Lunar Rock
    Exhaust reroute, cargo mat, WeatherTech side window deflectors, glove box and center console organizer. RCI steel skid plates (engine, transmission, transfer-case, catalytic guards, fuel tank and differential), Total Chaos Bed Stiffeners, RCI rocksliders, Power Tray and Switch Pro, Taco Vinyl Pro Grill, Diode Dynamics SS3 amber fog lights. Front Runner load bars, Powerbrake D-Line Disc & Pad kit, Fox 2 inch lift kit with 2.5 coil-over, Taruca Rogue XC awning, Four Wheel Campers Project M.
    Good day TW,
    Here is my question - I'm wanting to do an Overland setup and I started to add up the weight of the equipment/mods that I'm wanting to get and it gets rather high. I see trucks with very similar setup and I'm curious on what their vehicle equipment/mods add up to.
    My vehicle will also double as my daily driver.
    Mods already bought: RCI skid plates (engine, transmission, transfer-case, cata guards, fuel tank, and differential) and Rock Sliders ..........307 lbs
    Soon to buy: RSI Smartcap - 212, iKamper Skycamp 3.0 mini - 125, Taruca USA awning - 62, Prinsu roof rack - 45, CBI Baja front bumper (alum) - 55, CBI high clearance duel swing rear bumper - 200
    *** items may change as I get closer to buying them but I'm sure the weights will be similar.
    Add a full tank of gas plus 10 extra gallons - approx 194, 10 gallons of water - 83.
    So, without even adding my weight, my dog, supplies, etc I've reached a wight of almost 1,100 pounds. Toyota Tacoma payload weight is 1,155.
    What is being done to increase the payload limit? I'm sure an upgraded suspension (upgrade is planned) helps but is that enough? Am I over thinking this? What am I missing?
    Thanks
  2. Aug 8, 2023 at 10:39 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Most people ignore the payload and slap on as much machined pig-iron as their credit cards will allow.
    It's really all up to your ultimate goal. Are you trying to look cool, or do you have an actual purpose in mind? If so, rethink what you really need.
    Weight doesn't just affect payload. It also affects capability, milage, wear and tear, safety, and the occasional ability to use the truck for non-overland truck things.
    I'm probably the very opposite of a minimalist, but the trucks I see today make even me say "damn dude, dial it back a notch."
    CGPickup, slander, PNW15 and 23 others like this.
  3. Aug 8, 2023 at 10:42 AM
    Tttacodan
    Tttacodan Well-Known Member
    Dan
    Mr Lobster is correct, and in the US there isn't much care/enforcement for passenger vehicle GVWR.
    But it is worth the thought exercise of what do really need vs. want.
    PNW15, Phlogiston, scocar and 2 others like this.
  4. Aug 8, 2023 at 10:43 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    You can not increase payload all you can do is beef up your suspension to handle better. Sometimes you can get into trouble at a DOT check if they decide to weigh you or if you get into a serious enough accident where there is a big investigation. If you want a better idea of how much stuff you can haul go weigh your truck with you and your dog with a full tank of fuel then look at your door jamb,it will tell you your GVW.
    Cyberfool, hooliganrick and Junkhead like this.
  5. Aug 8, 2023 at 11:30 AM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    Payload is a function of vehicle frame, suspension components, body mounts, etc.
    If you're loading your truck up so much you're exceeding your payload weight, you better hope there's some other upgrades in their too. Suspension, suspension mounts, upgraded shackles and hangers, etc all contribute to "increasing" your payload weight but ultimately you're still wearing the vehicle faster than it was intended.
    Consider what you actually need and if you need steel skids vs aluminium, etc.
    BRFab, hooliganrick and Junkhead like this.
  6. Aug 8, 2023 at 11:38 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You cannot increase payload. It is what it is and Toyota engineering decides what it is. Can it haul more? sure. Legally? Nope.
  7. Aug 8, 2023 at 12:19 PM
    LkdTaco
    LkdTaco Well-Known Member
    2019 TRD PRO
    I would start out with the two items below, and a full tank of gas. Won’t be long, you will realize you really don’t need to spend thousands of dollars and hundreds of extra pounds in cool kid bolt on gear to “overland”.
    B5960C94-9661-4A5E-9DDD-A2F16D3A9D19.jpg D6E6901D-C020-4D58-8BF8-A2E8FD6E8BB6.jpg
    slander, df41590, PNW15 and 18 others like this.
  8. Aug 8, 2023 at 12:22 PM
    clg
    clg Well-Known Member
    2017 Off-road
    Overlanding weight management 101....buy 14" lodge cast iron pan, hit yourself with it and rethink how necessary heavy things are.
    PNW15, 3GTCMLMTD, TacoManOne and 13 others like this.
  9. Aug 8, 2023 at 12:22 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I’m currently carrying about 650# of constant weight, no issues whatsoever. When I go on trips, I’m over payload, truck drives/brakes just fine.
  10. Aug 8, 2023 at 12:23 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yep!
  11. Aug 8, 2023 at 12:25 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Saw a tacomer bro recently with like a ton of “overlanding” bullshit slapped on, not a single spec of dirt and my favourite he had his extra bright yellow fogs on. It was a beautiful sunny day…
    :der:
  12. Aug 8, 2023 at 12:29 PM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I thought you lived too far away from me to accidentally run across me!?!
  13. Aug 8, 2023 at 12:30 PM
    LkdTaco
    2019 TRD PRO
    Gotta run those yellow fogs. Especially when the suns out!
  14. Aug 8, 2023 at 12:33 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :rofl:
    Fucked up thing is, it’s not a rare sight in my neck of the woods.
    hiPSI and TacoPacific like this.
  15. Aug 8, 2023 at 12:34 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :D
    hiPSI and MR E30[QUOTED] like this.
  16. Aug 8, 2023 at 12:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    So I’m curious. Since when camping/off roading/wheeling became “over landing”?
    I haven’t used that term once.
    G2.M6, 3GTCMLMTD, hiPSI and 6 others like this.
  17. Aug 8, 2023 at 12:55 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    "Instagram"
  18. Aug 8, 2023 at 12:59 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    That might explain it.:)
    I don’t have instagram and have zero desire creating an account.
  19. Aug 8, 2023 at 1:01 PM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    I also do not have Instagram or facebook or any other form of SM. Im quite content with my "social life"
  20. Aug 8, 2023 at 1:14 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    If you call it overlanding instead of camping you can charge double for the same shit you buy for camping at half the price. Same theory as Starbucks calling a large coffee a venti and adding $2 to the price.
    Phlogiston, GilbertOz, hiPSI and 3 others like this.
