Overland Shopping List
Discussion in '3rd Gen. Tacomas (2016-2023)' started by I_squared_r, Oct 10, 2020.
  1. Oct 10, 2020 at 7:53 AM
    I_squared_r
    I_squared_r [OP] Well-Known Member
    NYC/Colombia
    2020 Black Tacoma OR DCSB 4x4
    I recently bought a 2020 Tacoma OR DCSB AT for towing my boat to the lake, mountain bike trips in the northeast, and road trips. I'm planning a trip next year to drive from NYC to Colorado/Utah and I will be going with a female friend who is visiting from brazil. I am doing research and I will only buy the necessities. Please take a look at my shopping list below and let me know if i'm missing something or you have suggestion how I can save money.
    Update: Build is nearly done. I definitely could've spent a lot less, but it's ok for me.
    $1100 Tepui Kukenam 3 (used)
    Kore4x4 Bed Rack (used)
    2x Thule Sidearm XT (used):thumbsup:
    $20 walmart camp chairs
    $47 6ft folding table
    $27 Walmart 5gallon water containers x2
    $80 kelty double sleeping bag ($100 off!):thumbsup:
    $119 mudguards & bed lighting kit
    $44 Estwing 16 in Campers Axe
    $100 2x Nitecore NU25 360 lumen Headlamps
    Coffee Percolator
    $20 Bond LH015 Mini D Shovel
    $59 walmart mainstays 2 inch gel infused memory
    $35 walmart rechargeable lantern
    $349 bilstein 5100 shocks (black friday) :thumbsup:
    $63 daystar air bag cradles
    $138 firestone air bags (Open box ebay) :headbang:
    $582 iceco jp40 fridge + slide (black friday) :D
    $331 Du-ha tote + slide (black friday) :thumbsup:
    $80 Seaflo 33-series washdown pump kit (Amazon warehouse deals):thumbsup:
    +$95 sold OEM struts
    +$125 sold OEM grill
    $90 alignment
    $317 Viair 10003 Medium Duty OBA System :thumbsup:
    Viair Air Relocation Kit
    Viair Mounting Bracket
    $45 Firestone 9074 Pneumatic Switch
    $6 Ancor 12 awg black 25ft (used wikibuy credits on walmart)
    $28 2x Seachoice 12801 Switch
    12v marine socket
    $12.49 5”x8” 1/8” thk 6061 ALU Sheet
    $45.47 Ancor 10gauge 25ft
    Blue Sea Systems 5045 4-way Fuse Block
    100ft ¼” Wire Loom
    $160 Tacogarage TRD Grill
    $0 Propane Camping Stove
    $21 Rainpal RBD020 Flush Port Kit x2
    $12 Double USB Socket
    $14 90 degree 1/2" npt to 1/2" hose barb fittings x2
    $3742.90
    I bought a Rockpals 500W but I had to send it back. The only things remaining on my wish list is a Jackery 500, tailgate electric lock, and a cheap solar panel.
  2. Oct 10, 2020 at 8:22 AM
    PNWTacoAdventures
    PNWTacoAdventures Well-Known Member
    Washington
    2020 Super White Tacoma TRD OffRoad
    Guess I'll have to start with #2 first. Really the only tonneau covers you can run with full access to the bed are retractable. There are several out there that lock, but I would also do the tailgate electronic lock as well. #1 You should be able to, but you might want to measure to ensure. You can also see if you can get bike attachments for the rack.
    Anything that is visible to someone who really wants it bad enough, they will get it.
    I_squared_r[OP] likes this.
  3. Oct 10, 2020 at 8:26 AM
    I_squared_r
    NYC/Colombia
    This is exactly what i'm thinking about the bikes. The girl and I will have $5000 in bikes so i'm thinking to take the wheels off and keep them in the cab. I have to measure to see if they will fit. I think the only other things of value would be my grill and cooler so I can find some way to lock them with my kryptonite chain and bicycle locks. I'm a little opposed to buying a tonneau because it will up my budget a lot. I'm already close to $5000 with tax and installation
    VeeSix likes this.
  4. Oct 10, 2020 at 8:33 AM
    SouthtownTaco
    SouthtownTaco Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    Yeah this is a fun project to plan out! Personally I'd encourage you to go with better tires than the Wranglers - I've enjoyed the improvements of KO2s over the Wranglers for example. I also like having the security of a tonneau that also allows me to have a bed rack over it withe he tent there, instead of over the roof. Having a RTT over the bed help gas milage and it's nicer to get in and out of, setup, etc. KBVoodoo's rack over tonneau is an excellent combo. FWIW
  5. Oct 10, 2020 at 8:34 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You sure you need to swap the tires out? If you just plan to truck camp. The stock tires are fine.
    Malvolio, rlx02 and I_squared_r[OP] like this.
  6. Oct 10, 2020 at 9:06 AM
    Anthony.b1989
    Anthony.b1989 Well-Known Member
    Anthony
    Cement 2020 TRD Off-road
    Currently stock
    Some higher end tri folds have an extra fold give full bed access. Only drawback would be you lose your rear view.
  7. Oct 10, 2020 at 9:47 AM
    SamOfSteel
    SamOfSteel Well-Known Member
    Sam
    Cement 2018 Tacoma TRD OR
  8. Oct 10, 2020 at 6:10 PM
    PNWTacoAdventures
    Washington
    welcome to owning a Tacoma. There is one thing for sure - you’ll spend cash like mad on mods.
    Freeheelbillie likes this.
  9. Oct 10, 2020 at 7:47 PM
    Matty_nw
    Matty_nw Active Member
    2020 cement tacoma DCSB TRD OR
    If you don’t have one yet, then a good bumps and bruises first aid kit for the truck and a smaller one for the trails. Learn how to apply a splint in case of an accident on the trails and the basics on stopping a large cut from bleeding. Prepare for worse case scenarios especially if it’s only you two out on the trails. It’s something easily overlooked, but you’ll be glad to do a little research ahead of time if the unfortunately event happens!
  10. Oct 12, 2020 at 7:20 AM
    I_squared_r
    NYC/Colombia
    I edited the shopping list in the 1st post. Less lift. Less aggressive tires. Different jumper pack according to @SamOfSteel suggested video. Buy some camp gear from walmart. All in all $1000 cheaper. Bilstein 5100's, front setting on 4, 1.5" AAL in the rear. Anyone have experience how this will ride compared to stock? The most load i'd have is a RTT, gear, and my 19ft boat with 250lb tongue weight.
  11. Oct 12, 2020 at 7:52 AM
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    Fellow cyclist here - it ain't the chain, it's the lock. Lock picking is a big hobby now. If you want to get really scared and depressed, check out all the videos on Youtube where people pick your exact lock (whatever lock that may happen to be) in about 10 seconds. If there are two of you, just don't leave the bikes unattended. If you're leaving the bikes locked up (LOL) while you go off hiking all day, there's a pretty decent chance they won't be there. I would disassemble them to whatever size allowed putting them inside the truck.
  12. Oct 12, 2020 at 8:05 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    No need to spend all that cash to sleep on top of the truck (great for IG I guess). Buy a decent ground tent/air mattress and regular camping gear. Put a topper on the truck for securing your stuff and weatherproof area. Nothing else needed. I drove a 2 WD (limited slip) ford explorer all over Utah when my buddy was a Ranger at Dead Horse Point just outside of Moab. Some of the climbs were insane but aired down I didn't spin a tire on the rock. Tires and 4WD are only needed if running some of the more technical trails, which I wouldn't in a new 40K rig. If you want to run the trails I'd rent a jeep or buggy and have fun without tearing up your daily driver.
  13. Oct 12, 2020 at 8:08 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  14. Oct 12, 2020 at 8:20 AM
    VeeSix
    Tennessee, USA
    2011 Tacoma 4x4
    Although this guy wants to travel, I'm convinced it's not a travel hobby, it's a vehicle customization hobby. Real travelers are out there in old Silverados and T100's, buying used tires and drinking rum on the beach.
  15. Oct 12, 2020 at 8:32 AM
    I_squared_r
    NYC/Colombia
    I don't post anything on IG and I still like the idea of a RTT lol if it doesn't work out then it will be a lesson learned and I will sell it. But I think that you have good reasoning on not beating up my 40k truck. I googled side-by-side rentals in moab and they start at $320 for the day. So I could do the scenic easy trails in my truck and rent a side-by-side for the more intense stuff. I think the most practical setup would be the 5100's raising the front 1.5", 1" AAL in the rear, and stock tires.
    DavesTaco68 and VeeSix like this.
  16. Oct 12, 2020 at 8:32 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Do yourself a favor and don’t get your camping gear from Walmart. It’s literally disposable gear good for a few trips and then it falls apart, goes in the trash, and you’re buying all over again.
    REI garage sales are a great place to score cheap quality gear. It’s all the stuff that’s been returned and is heavily discounted. If you’re not too picky you can get fully setup for a few hundred bucks and it’s all much higher quality than the Walmart crap.
  17. Oct 12, 2020 at 8:40 AM
    VeeSix
    Tennessee, USA
    2011 Tacoma 4x4
    A 1.5/1" lift and stock tires will take you around the world. More aggressive tires in the 32" range will do a lot of pretty tough off road stuff too. I have always run 235/85/16's with great success. Buy quality tires.
  18. Oct 12, 2020 at 8:43 AM
    I_squared_r
    NYC/Colombia
    This made me think of a guy whose rode a 90cc honda scooter all the way to argentina lol a lot of people over gear everything when we don't need much. I like to compare it to "tacticool" of the gun world.
    EDIT: Just thought of it.. There was another guy years ago, that was going to ride a ducati multistrada around the world. He didn't make it far until he sold it and bought a cheap POS and finished his trip with that.
    vicali, Boghog1 and VeeSix[QUOTED] like this.
  19. Oct 12, 2020 at 8:45 AM
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    You're better off spending the money from the lift-kit on 2 full-size spare wheels/tires, tools, a quality jack, and some spare parts.
    Boghog1, VeeSix and Tacoma091919 like this.
  20. Oct 12, 2020 at 8:45 AM
    Tacoma091919
    Tim
    2019 OR DCLB
    There is plenty to see from your truck without causing damage. Arches, Canyonlands, Dead Horse Point (state park), or about 2 hour drive into the mountains with lots of non technical trails that are fine in stock configuration. I wouldn't own a rooftop tent because then you are locked in to staying at camp once you set it up. With a regular tent you can set-up camp before dark then go drive around and explore more, but you do you. Yes rent a side by side, $350/day is cheap compared to trying more technical trails w/out a good spotter and tearing your bumpers off and smashing your rocker panels. Bring warm clothes, it can get cold AF in the high desert at night. Bring a black light for finding scorpions at night. Watch out for black widow spiders ;). Lots of great mountain biking and solitude.
