Overland Tailor Tuning in Arizona!
Discussion in 'Arizona' started by AZC Edge, Jun 9, 2021.
  1. Aug 20, 2021 at 11:33 AM
    #41
    AZC Edge
    AZC Edge [OP] AZ OTT Tuner
    Eddie
    Arizona
    2020 TRD OR 4x4 DCSB MGM
    Tacoma build stuff Kings all around with adjustable reservoirs SKU: KIN25001-119A-EXT KIN25001-121A-EXT Pakrax sliders https://pakrax.com/products/pakrax-16-current-tacoma-sliders Pakrax tailgate panel https://pakrax.com/collections/toyota-tacoma/products/pakrax-05-current-tacoma-tailgate-panel?variant=30310492569705 Body armor pro series front bumper https://www.bodyarmor4x4.com/product/toyota-tacoma-pro-series-front-bumper/ Westcott roof rack https://westcottdesigns.net/product/toyota-tacoma-3rd-gen-modular-roof-rack/ SPC UCAs https://www.4wheelparts.com/p/specialty-products-upper-control-arm-set-25470/_/R-FCMW-25470 Ironman 4x4 full skids https://ironman4x4america.com/heavy-duty-skid-plate-kit-suited-for-2005-toyota-tacoma/ Rough country 30” light bar w/DRLs https://www.roughcountry.com/30-inch-led-light-bar-70930blkdrl.html Rigid fogs https://www.rigidindustries.com/d-series-pro-spot-surface-mount-black-2-lights-202213.html Voswitch 8-button switch panel https://m.voswitch.com/UV100-Universal-8-Gang-Programmable-Switch-Panel-for-Truck-UTV-Side-by-Side-Boat-p1291994.html Gatorfx tri-fold tonneau https://gatorcovers.com/p/gator-fx-tonneau-cover/v/toyota/tacoma/2020/ Anytime backup and front cam https://www.anytimebackupcamera.com/products/2020-kit 3TPAM powered dash mount https://expeditionessentials.com/collections/frontpage/products/toyota-tacoma-3rd-gen-usb-powered-accessory-mount Fieryred 13k synthetic winch https://fieryred.com/collections/winch/products/12v-13000lbs-synthetic-rope-winch-kit Meso Customs stealth pro 2-button shift knob https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/stealth-pro-shift-knob?variant=21433407438961 Meso/Morimoto collab Ultimate Tail Lights https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/ultimate-tacoma-tail-lights-full-led AJT key fob https://www.ajtdesign-llc.com/online-store/V1-Fob-Case-c69661004 Victory 4x4 center console molle panels https://www.victory4x4.com/product/VTCC.html Desert Does It Seat Jackers https://desertdoesit.com/collections/toyota/products/2005-2019-toyota-tacoma-1-1-4-front-seat-spacer-lifts-front-of-seat + multi mount panel on passenger seat https://desertdoesit.com/collections/toyota/products/front-multi-mount-panel RXT leaf pack https://iconvehicledynamics.com/accessory/15947/icon-accessories-05-up-tacoma-multi-rate-rxt-leaf-pack-w--add-in-leaf/ Redline hood quicklift elite https://www.redlinetuning.com/2016-Toyota-Tacoma-Hood-QuickLIFT-ELITE-p/21-27015-03.htm Hypertech speedometer calibrator https://hypertech-inc.myshopify.com/pages/product-result?rq=yr_2020~mk_toyota~md_tacoma~wa_3-5l-v6-gas Kicker speakers all around https://www.crutchfield.com/p_20646CC674/Kicker-46CSC674.html https://www.crutchfield.com/p_20646CC693/Kicker-46CSC6934.html Kicker Key 500.1 https://www.crutchfield.com/p_20647KEY50/Kicker-47KEY500-1.html Wireless CarPlay adapter https://cplay2air.com/ Duro bumps front and rear https://durobumps.com/product/3rd-gen-toyota-tacoma-front-bump-stops/ https://durobumps.com/product/3rd-gen-tacoma-rear-bump-stops-3-5-2016/ K&N CAI https://www.knfilters.com/63-9039-performance-air-intake-system 285/75/17 Falken wildpeaks a/t3w https://www.discounttire.com/buy-tires/falken-wildpeak-a-t3w/p/26812 KMC Grenade 17x9 -12mm offset wheels https://www.kmcwheels.com/kmc-grenade-off-road AVS bugflector 2 hood shield https://www.autoventshade.com/bugflector-ii/2020/toyota/tacoma AVS low-profile window visors https://www.autoventshade.com/low-profile-color-match-ventvisor/2020/toyota/tacoma Cheap+effective Amazon front&rear dash cam https://www.amazon.com/dp/B08M9JD55C/ref=cm_sw_r_cp_api_i_5K49S7WFCC5XMAPDDY3E Tailgate lock https://www.amazon.com/dp/B07ZL2WCLD/ref=cm_sw_r_cp_api_i_KYY3FYH3ZS06DYZVDAHT Fumoto valve(easier oil changes) https://www.amazon.com/dp/B085RBL4KW/ref=cm_sw_r_cp_api_i_GPBZJTJ0NTAA85R3G2DY?_encoding=UTF8&psc=1 K&N Premium Oil Filter https://www.amazon.com/dp/B0067ED49C/ref=cm_sw_r_cp_api_i_D5DHE5F27G5CW8HHCC31?_encoding=UTF8&psc=1 Raptor-lined fender flares and rocker panels https://www.amazon.com/dp/B07DGVMWS9/ref=cm_sw_r_cp_api_i_KQXFHYDEVNH49SKTA9P4?_encoding=UTF8&psc=1 Supreme Suspensions D-Ring Shackles https://www.amazon.com/dp/B082PDV9KR/ref=cm_sw_r_cp_api_i_EGX04F00SXJ6MBMCR3NW Heritage grill with lights CMC Arizona Toy Pros Needle bearing -> bushing swap Arizona Toy Pros OTT tune with Mild>Medium throttle by Eddie Erosa/AZC Edge/me!
    Hey! I actually recommend the hypertech or the rough country for that issue. Either one will be fine with any tune :)
    Atl-atl[QUOTED] likes this.
  2. Aug 22, 2021 at 3:11 PM
    #42
    theluharlifestyle
    theluharlifestyle Well-Known Member
    Parth
    SoCal
    2019 DCSB TRD OR
    Any benefits from switching from ovtune 2.0 prem to kdmax regular?
    I’m on 2.0 premium, thinking about switching down to regular just due to gas prices for long term. I like the way 2.0 drives, zero complaints other than cruise control shifting.
  3. Aug 22, 2021 at 3:21 PM
    #43
    AZC Edge
    Eddie
    Arizona
    Most pro tuners can help you move over to regular with OV. I do think it always comes down to personal preference with any tune, but if you’re liking how OV drives then there’s no pressure to switch to something like KD or any other custom tunes. The biggest difference you’ll see is the cost of gas between Prem and Reg.
    As for cruise control, there are no tunes that work for the adaptive(radar) cruise control. They will always default to stock mappings for shifting and throttle. However, if you hold down your CC button for like 2-3 seconds, you’ll see it change over to “constant” on the cluster. Constant cruise control does utilize tune maps, but obviously you won’t have the radar controlling your speed.
  4. Aug 22, 2021 at 4:23 PM
    #44
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    This may be a stupid question, so forgive me in advance….Does a tune like this have any affect (positive or negative) on the longevity of the truck?
    I’ve had trucks forever but never run a tune on one and unfortunately I know nothing about them. I checked your guys’ website first but didn’t see an answer so figured I’d post.
  5. Aug 23, 2021 at 3:53 PM
    #45
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    I personally believe it will NOT hurt the longevity of the motor. We monitored with OBD Fusion for over a month while testing on all years-auto and manual transmission before releasing the tune to the public. Since then we have been running it on Thousands of trucks for over 6 months. The numbers (temps, knock values, etc.) we were getting were all better or the same as the stock tune.
    Hopefully this helps you. But since the tune has only been out for 6 months, I can’t honestly guarantee anything. There are people, including myself who have been running various tunes for the past few years and have not seen any negative affects.
  6. Aug 23, 2021 at 4:08 PM
    #46
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Thanks for the info, much appreciated.
  7. Aug 23, 2021 at 8:32 PM
    #47
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    For the first time I checked the voltage readout on my Dometic fridge while driving and it was only getting up to 13.7 so I guess I need to get the alternator tweak done for my AGM batteries. You guys didnt do my tune, it was done at a group event where someone drove in from CA. Can I throw you some cash to get the this done?
    AZC Edge[OP] likes this.
  8. Aug 23, 2021 at 8:46 PM
    #48
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Eddie can take care of you. Contact him.
    @Edge48
    Atl-atl[QUOTED] and AZC Edge[OP] like this.
  9. Aug 24, 2021 at 9:04 AM
    #49
    tclavell
    Troy
    Phoenix, AZ
    G70
    the tune was done by KD Tune. I know because it was at my house. @TWTaco was the man tuning all of us. It was not KDMax, it was the tune prior. I believe KDMAX event in Phoenix was mid-April
    AZC Edge[OP] and TWTaco like this.
  10. Aug 28, 2021 at 7:43 PM
    #50
    AZboy
    AZboy Member
    2021 double cab offroad
    Just had Eddie tune my 21 off-road today. Great guy. Highly recommend. Truck drives how it should now.
    dms91, blaklabl, TailHook and 2 others like this.
  11. Oct 12, 2021 at 5:02 AM
    #51
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Will adding a different air filter/CAI or exhaust require retuning?
  12. Oct 12, 2021 at 9:51 AM
    #52
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Not on all trucks. The ones that we have seen that need it are ones with S&B CAI's because it moves the MAF sensor a good bit. But, we have only had 2018's and 2021's that had problems. WEIRD!
    So the best thing is to let us know if you are having any weird problems after a CAI install.
    The one thing that was seen was "bogging" when trying to accelerate to pass on the highway.
  13. Oct 16, 2021 at 5:00 PM
    #53
    Jammers1971
    Jammers1971 Well-Known Member
    James
    2019 Tacoma TRD Off-Road 4x4
    3.5 lift, 315/75-16, DIY hybrid front bumper, skids, sliders, ditch lights, hood struts, tailgate lock, bed rack, custom exhaust, horn meant for an actual truck, neoprene seat covers
    Eddie tuned my '19 TRD Off-Road 4x4 Thurs afternoon.
    Loving it! Removed bogging acceleration from a stop, gear hunting on freeway, overall much nicer drive!
    Woot!!!
    Thanks Eddie!!
  14. Nov 15, 2021 at 11:16 AM
    #54
    tclavell
    Troy
    Phoenix, AZ
    G70
    @Edge48 - PM sent for KDMAX Pro tune! :burnrubber:
  15. Nov 16, 2021 at 9:02 AM
    #55
    jayh888
    jayh888 New Member
    2021 Tacoma TRD Off-road
    Icon stage 3 lift 285/70/17 BFG KO2
    Where is the best place to get a tune scheduled through you?
  16. Nov 17, 2021 at 5:41 AM
    #56
    tclavell
    Troy
    Phoenix, AZ
    G70
    any sighting of @Edge48?
    Pretty sure you have folks interested in going up to KDMAX Pro:thumbsup:
  17. Nov 17, 2021 at 4:03 PM
    #57
    AZC Edge
    Eddie
    Arizona
    Oh yeah it's been almost none stop the past couple days lol. My rental customers also decided to pick this week to total a couple of my cars and even abandon one at the border so it's been a handful to say the least! But I am planning a lot more small tune meets, like my Mesa one tomorrow, hopefully once a week at least. I hired a new team member so I may be able to take more time away and tune more very soon.
  18. Nov 22, 2021 at 7:49 PM
    #58
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Keep us posted I would like to update to Pro, what do you charge for that? You tuned my truck in August.
  19. Nov 30, 2021 at 8:59 PM
    #59
    Cujof16
    Cujof16 Professional Adventure Fun Hog
    Bryan
    2018 TRD Off-Road White
    Working it...Have a list to purchase...
    Been running the KDMAX pro for about 1000 miles now. kicks ass. Do it worth the money. Lovinit.
    My wife says "this truck doesn't suck anymore..."
    Winning
  20. Dec 19, 2021 at 8:10 AM
    #60
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    What does the basic tune cost?
    Thinking of getting it done after the holidays.
