Overload replacement.
Discussion in 'Suspension' started by SandDiesel, Jan 25, 2013.
  1. Jan 25, 2013 at 7:55 PM
    SandDiesel
    SandDiesel [OP] Member
    San Diego
    2000 PreRunner SR5
    Doetsch coilovers, Camburg uppers, 32 BFG's.
    Just got a 2000 PreRunner and sorting out the suspension. It has Doetsch coilovers and Camburg A-arms up front and just an additional overload leaf in the rear. It rides like it has zero suspension travel. We had the coilovers rebuilt and the correct coil spring installed to fix the front but overloads are the next issue. The spring is 3/4" thick but i don't know if it adds any additional lift. If the front is up 2" what's the best option to lift the rear and improve ride? Replace the whole leaf pack? Swap the overload for a 1", 1.5", or 2" block and keep stock springs? I posted a pick in the new member section btw. Thanks for any advice.
  2. Jan 25, 2013 at 7:56 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser
    Stuff
    New leaf pack
  3. Jan 25, 2013 at 8:47 PM
    SandDiesel
    San Diego
    2000 PreRunner SR5
  4. Jan 26, 2013 at 7:58 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Check out Wheelers/Alcans 5 leaf pack on Wheelers Off Road or OME Dakars or even All Pro Expos. All great replacement leaf packs.
  5. Jan 26, 2013 at 3:32 PM
    SandDiesel
    San Diego
    2000 PreRunner SR5
    Are these the stock leaf spring packs by the way?
  6. Jan 26, 2013 at 3:33 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Bilstein 5100, 31x10.5 Michelin LTX AT2
  7. Jan 26, 2013 at 5:04 PM
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Kailua, HI
    16 DC TRD Offroad 4x4 Loaded.
    Stock to the MF airbox.
    OP you might be good with wheelers 3 leaf progressive AAL.. Your leafs now (look stock) still have some what of an arch left... the 3 leaf would help them out.. if not go with wheelers 5 leaf.
  8. Jan 26, 2013 at 8:25 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Do you have any sort of budget or is it open?
  9. Jan 26, 2013 at 11:51 PM
    SandDiesel
    San Diego
    2000 PreRunner SR5
    battlescars, budget is open. Got some ideas?
  10. Jan 26, 2013 at 11:58 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I am running a deaver 8 pack, J59 and LOVE it.
    It added maybe 1.5 inches of lift and paired with my 10 inch fox rears I cant complain.
  11. Jan 27, 2013 at 5:27 PM
    noSKills858
    Alex
    Escondido, CA
    Well if you're looking to save some money you can always go with a lift block. It will put that rear end higher but the leaf pack will still feel soft and wear out.
    Another option that could save a couple bucks is to go with an add-a-leaf (AAL) which will slow the rate at which the leafs begin to sag.
    Then when you want to spend some money you can buy heavier duty leaf spring packs, such as said J59 from Deaver or a custom pack from Deaver or National.
    Now you can also run the stock leafs that you have now and add a better shock set up which won't really give you a good amount of lift (higher nitrogen pressure) but will help stiffen the rear up or soften it. At the same time the better shocks can be added throughout any of the other leaf setups, but make sure you do your research and get the right length to prevent the shocks from breaking.
  12. Jan 27, 2013 at 8:23 PM
    SandDiesel
    San Diego
    2000 PreRunner SR5
    Looking to make the rear suspension more progressive with a slight lift is where I'm headed I guess. Right now the rear just hops over road imperfections and speed bumps. There is almost no give. We will occasionally have a dirt bike in back but nothing much heavier than that. The front end had the wrong coil springs and preload was maxed out so the ride was horrible. With the coilovers rebuilt and set at 2 inches of lift the front end is much smoother except the 32 BFG's rub now! Just trying to match the ride at rear. Probably going to be hard in a light truck and no weight in the back. It sounds like new leaf packs and maybe Bilstein 5100's might get it there.
  13. Jan 27, 2013 at 8:26 PM
    SandDiesel
    San Diego
    2000 PreRunner SR5
    battlescars, just noticed your in Poway. I'm your neighbor in Ramona. We lived in Poway for two years a little while back.
  14. Jan 28, 2013 at 12:34 PM
    noSKills858
    Alex
    Escondido, CA
    I forgot to mention you can also go with lift shackles and they may be a better option for you paired with a better shock.
    Yep, right down the hill from Ramona Lake actually.. You don't happen to own a house near the lake do ya?
  15. Jan 28, 2013 at 6:21 PM
    SandDiesel
    San Diego
    2000 PreRunner SR5
    I will save for a progressive leaf pack and better shocks to do it right. Think it has stock height Pro Comp shocks and I have been happy with Bilstein's on all my past and present rides. I jacked the front up a tad with a floorjack and will need just a 1" spacer on the coilovers to clear the 32's at full steering lock.
    battlescars, No not by the lake, out back in the "Mistakes" as some refer to this neighborhood. We like it tho.
  16. Jan 28, 2013 at 7:02 PM
    SandDiesel
    San Diego
    2000 PreRunner SR5
  17. Jan 29, 2013 at 9:11 AM
    noSKills858
    Alex
    Escondido, CA
    Yep, All Pro is a good company, I think they are even a site sponsor on TW so you can try to get a discount through them from here.
