overshot my front lift
Discussion in 'Suspension' started by pokeng, Apr 23, 2010.
  1. Apr 23, 2010 at 7:19 AM
    pokeng
    pokeng [OP] Married With Children
    North of Austin/West of Nashville
    2009 DC TRD Off Road 4x4
    Foldacover G4 Elite, Deflapped, TRD exhaust, Webasto Hollandia sunroof, Katzkin leather seats, Dynolock, Sockmonkey decals, oem bed extender, all-weather mats and bed mat
    Well, thought I'd try to be smart and try something different. Had the TSB done a few months back and wanted to put a small lift on the front. I looked at 5100's, but read great things about the EMU ride quality. I went with the 884's without the spacers for my DC because I only wanted about 2" of front lift. 2" should have left me a small rake. I installed it myself a couple weeks ago and got 2 1/4" and 2 1/2", surprisingly. I thought it would settle in back to 2" to get rid of the nose high look. It has somewhat, but not enough for my liking. I really like the ride quality of the EMU now that I've put on a few thousand miles with it (much better than stock), so I will stick with it. Are there any options to raise the back end 1/2"-1"??? I know Toytec has the TSB AAL, but it seems like it would raise it too much. Like I said, I only want a slight rake or level look when finished. Thanks in advance.
  2. Apr 23, 2010 at 7:28 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    I think there are some "Add a Leaf" options that would raise your back about that much. Those are a pretty to pop in.
    Or instead, maybe think about putting an aftermarket front bumper, or even a bull bar up front.. should about line up if you did that.
    EDIT: URL for an add-a-leaf at Wheeler's Offroad for under $80 http://www.wheelersoffroad.com/05uptacoaal.htm
  3. Apr 23, 2010 at 7:43 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    A shim under the leaves would probably raise the back a 1/2".
  4. Apr 23, 2010 at 7:52 AM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    x2
  5. Apr 23, 2010 at 8:04 AM
    pokeng
    I think that's similar to the Toytec AAL for the TSB leafpack, which I'm leary of. Don't want too much rake.
    Any drawbacks using shims? Axle wrap maybe?
  6. Apr 23, 2010 at 8:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    a 1" block would do it, you can get those pretty cheap too.
  7. Apr 23, 2010 at 9:01 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    I think the AAL will be too much and you'll end up with a stink bug truck. I have shims and I have no axle wrap but technically, I suppose they could increase axle wrap due to the fact that you're moving the axle farther from the leaves albeit only a small amount. What they really do is point your pinion joint more directly at your carrier bearing joint in turn relieving stress on both. They will wear slower and have a lower risk of unwanted vibrations. They are about a 1/2" thick in back. Blocks will definitely increase the risk of axle wrap because they are much thicker and move the axle quite a ways from the leaves giving the already existing torque a levered mechanical advantage to twist the leaves.
  8. Apr 23, 2010 at 9:27 AM
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 33x12.50-17General Grabbers on 17x9 Black RBP 93R rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    Shackle flip kit! Adds about 1" rear lift to the truck and gets the leafs and shackle up out of the way of shit!:D
  9. Apr 23, 2010 at 10:34 AM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    You will be fine with the Wheeler's TSB AAL. I don't have a straight-on shot I can give you at the moment (I'm moving and my camera is packed away), but here's a glimpse with 885 springs, stock tires, and OME shocks. I'd say there is a very mild rake from just eyeballing it in the parking lot, I've never gone to measure.
    If you don't have it already, a driveline spacer would be very good.
  10. Apr 23, 2010 at 10:42 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    A 1" block is a simple and effective option, wont lead to too much axle wrap either.
    Hey mike, we need to go 'wheel browns camp again, maybe this time you'll miss that tree stump. :laugh: :p
  11. Apr 23, 2010 at 10:44 AM
    Chickenmunga
    Hillsboro, Oregon
    It did not respect my authoritay
  12. Apr 23, 2010 at 10:48 AM
    RelentlessFab
    Eric
  13. Apr 23, 2010 at 3:06 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    1" block, shouldn't have any axle wrap since you got the tsb springs. I ran a 1" block with the non tsb springs and i only noticed very minor axle wrap. Most people wouldn't notice but i could just barely tell when i would take off hard in 1st and 2nd gear.
  14. Apr 23, 2010 at 3:23 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    the ATO shackle flip kit adds 1/2", a 1" block, or get someone to custome make a set of 1/2" blocks. the shims are to change to angle of the DS to the rear diff and if they do add any lift, it's minor.
  15. Apr 28, 2010 at 1:59 PM
    MyMistress
    MyMistress Well-Known Member
    TN
    10 TRD Sport 4X
    Leveled front, TSB rear, TSB Transmission, Always on fog lights, Socked windshield / bedsides, Trimmed mud flaps, Weather Techs, 4 Extra d-rings, Map Light Mod, Avid Light Bar, OEM Bed Mat, Locked Back Window, Secret Stash Area,
    So should he do 1/2 block and shims? I guess with the 1.5" total lift (1" TSB and .5 Block) it would'nt hurt...?
  16. Apr 28, 2010 at 7:29 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You went up 2 1/2" in a DC with 884's ? Hmm , might change my thoughts on going with 885's as I only want to go up 2 1/2" .
    OZ
  17. Apr 28, 2010 at 11:28 PM
    Chickenmunga
    Hillsboro, Oregon
    From my understanding, the 884 won't lift any higher than 885 or 886. The difference is in how much resistance the coil has. Worse case, if you have a heavy front end and only use 884, you would nose dive when you hit the brakes. This would mean you need to step up to a heavier resistance.
  18. Apr 28, 2010 at 11:58 PM
    OZ-T
    Peter North
    British Columbia
    ^^ Gotcha , thanks . So if I was considering an ARB bumper , I should probably still go with the 885's ?
    OZ
  19. Apr 29, 2010 at 8:14 AM
    pokeng
    As I understood it, the 884's have the same spring rate as the 885's, but are 10 mm shorter. The 886's have a stiffer spring rate for heavy aftermarket front bumpers. I heard most everyone was getting 2.5" of lift with the 885's w/o the spacer (to achieve the full 3"). With that logic, the 884's shoulda hit around 2", but every truck is different.
  20. Apr 29, 2010 at 8:17 AM
    Chickenmunga
    Hillsboro, Oregon
    From Toytec:
    883 --- Front Coil Springs Used alone as leveling coils (approx. 1 1/2") for 07-09 FJ Cruiser, 05-09 Tacoma, & 03-09 4-Runner.
    The coils below are for 07-09 FJ Cruiser, 05-09 Tacoma, & 03-09 4-Runner.
    ---884--- 2" lift standard coils - add top plate spacers for full 3" lift
    ---885--- Medium 2" lift coils for 110 lbs additional front weight
    ----886--- Heavy 2" lift coils for 200+ front weight -- No top plate spacer needed--
