Oversize Spare tire OK?
Discussion in '1st Gen. Tacomas (1995-2004)' started by thatSchusterguy, Jan 22, 2012.
  1. Jan 22, 2012 at 7:57 AM
    thatSchusterguy
    thatSchusterguy [OP] Common Sense Ninja
    Cincinnati, OH
    96 X-Cab
    OME/881 Downey Shackles Bilstein 5125's Demello HD sliders Marlin 1200# Clutch
    Curb checked a wall on my way into work today and totally destroyed my Mickey Thompson classic II :'(
    My question is can I safely use the 32" spare tire on the front if my others are 31's? I won't be using 4wd so no worries there, just need to double check that it will not eat anything up. The truck is a 96 with add hubs.
    I know its been discussed before but I'm on my phone (that I'm not supposed to have at work) so help a brotha out!
  2. Jan 22, 2012 at 8:08 AM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    I am gonna say no. Get the right size spare. I wouldn't even gamble with it cause a 100.00 tire could cost thousands to fix. I had a jeep that had different size tires in the front and it fucked up alot of stuff. Play it safe and get the right size.
  3. Jan 22, 2012 at 8:33 AM
    thatSchusterguy
    Cincinnati, OH
    96 X-Cab
    Ok I'm only a mile or so from a tire shop ill probably head over there after work and have em switch the tire over...I'm lucky it just destroyed the wheel and not the rubber!
  4. Jan 22, 2012 at 9:38 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The question is... Why do you have a 32" spare when the rest of your tires are 31's?
    Or did you mean that the other way around?
  5. Jan 22, 2012 at 12:01 PM
    thatSchusterguy
    Cincinnati, OH
    96 X-Cab
    No, the previous owner had 32" km1's on it and put 31s on before he sold it to me.
    If I could find 3 km1's I would just mount those but they appear to be made of 100% unobtanium these days.
  6. Jan 22, 2012 at 3:42 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    It would be fine as a spare to get you to a service station, but not okay to be used full time. Many spares in the trunks of cars are different sized.
  7. Jan 22, 2012 at 4:10 PM
    thatSchusterguy
    Cincinnati, OH
    96 X-Cab
    I got the tires switched out, too bad the damage was worse than I thought...
