Oversize tires + increased MPG?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Five lugger, Oct 12, 2011.
  1. Oct 12, 2011 at 4:55 PM
    Five lugger
    Five lugger [OP] New Member
    Nu Joysee
    7113 03R3
    My 2 wheel drive Taco is on order, expected for the end of November. For appearance, ground clearance (another inch or two would be perfect, compared to my Frontier) AND a hopeful increase in MPG, I am thinking of a Readylift 69-5510 lift kit, 16" or 17" wheels and tires with an OD of about 30" with the hopeful benefits of a larger diameter, 10% lower RPMs, speedometer off (current truck was off 10% from new, in 1999 and still is), and acceleration compromise are OK, flatland interstate highway almost exclusively. Four wheel drive is just a bigger expense initially and at the fuel pump than I want. Any thoughts or suggestions. Thank you.
  2. Oct 12, 2011 at 5:46 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm not overly familiar with the 5-luggers and how they're geared but that worked for my V6. I went with a 1" taller tire and increased my MPG's. No noticable decline in acceleration. There are a lot of things to consider though, if you go from a light, H/T tire to a heavy A/T tire that's taller, then you might off set any gains. Also, a lift kit can hurt your fuel economy even without changing the tires.
  3. Oct 12, 2011 at 6:27 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    A lift is going to increase drag, bigger tires= more weight and drag. You will Decrease your MPG's garanteed. Why get a lift/bigger tires if you dont plan on getting 4x4? Your reasoning is flawed man.
  4. Oct 12, 2011 at 6:34 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Best Answer (read correct).
    Frank
  5. Oct 12, 2011 at 6:39 PM
    wingspar
    wingspar Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    And, your speedometer will probably be incorrect, which will give you false MPG’s.
  6. Oct 12, 2011 at 6:47 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    True. There are ratio calculators which can work this out for you. When I had 33" on my last truck; when I was going 100 KPH, I was really going 120 KPH. So my odometer was not reading 20 KM for every 100 I did.
    Frank
