oversized tires and speedo calibration / mpg's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoJuan, Dec 16, 2016.
  1. Dec 16, 2016 at 6:24 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    My largest drop in mpgs was due to the TRD exhaust rather than tires. ;)
    Im a little more aggressive with the skinny pedal now. The novelty will wear off soon, as long as my son stops egging me on! Lo L
    bluezzy likes this.
  2. Dec 17, 2016 at 1:04 AM
    TacoJuan
    TacoJuan [OP] Well-Known Member
    Hanover, PA
    2015 Black Tacoma TRD OR
    I've read about these. Was it hard to install?
  3. Dec 17, 2016 at 1:04 AM
    TacoJuan
    Hanover, PA
    Isn't the TRD exhaust supposed to help increase mpg?
    bluezzy likes this.
  4. Dec 17, 2016 at 2:15 AM
    perpetualenigma3
    perpetualenigma3 Well-Known Member
    Mr.
    Im here and there. Mostly there than here.
    2016 QuickSand Taco TRD OffRoad
    A new bolt here, a new bolt there, a new bolt everywhere.
    Based on this my speedo is off anywhere between 5-10mph slower than my actual speed. Looks like I will be buying the Hypertech after all
    TacoJuan[OP] likes this.
  5. Dec 17, 2016 at 2:21 AM
    TacoJuan
    Hanover, PA
    Have you confirmed it with a gps? I tested it out last night and my truck is almost dead accurate now. That would be the best way to confirm how far off your truck is. However if you do purchase the hypertech, let us know how the install goes and how well it works
  6. Dec 17, 2016 at 2:28 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    16lbs X 4
  7. Dec 17, 2016 at 3:08 AM
    perpetualenigma3
    Mr.
    Yes, I checked it this morning on my way to work. Doing 65mph my gps states I am doing 74-75mph. It dropped to 73mph and jumped up to 76mph while going over several over passes. I had the cruise control on, so I can assume it was due to that.
  8. Dec 17, 2016 at 6:26 AM
    badger
    badger Well-Known Member
    07 SR5
    TacoJuan[QUOTED][OP] likes this.
  9. Dec 17, 2016 at 4:38 PM
    TacoJuan
    Hanover, PA
    It's 16lbs total. 4lbs each
  10. Dec 17, 2016 at 4:44 PM
    TacoJuan
    Hanover, PA
    Wow, that is a decent difference. What size tires are you running
  11. Dec 18, 2016 at 12:20 AM
    perpetualenigma3
    Mr.
    35s which are closer to 36s with the aggressive thread
  12. Dec 18, 2016 at 12:28 AM
    TacoJuan
    Hanover, PA
    Ah ok, that would make sense. Lol. I'm sure it looks sick though
  13. Dec 18, 2016 at 7:23 AM
    perpetualenigma3
    Mr.
    There's pics on my profile and on my build thread if you'd like to see it
  14. Dec 18, 2016 at 11:34 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Careful with that one. The calculation using tire sizes is fine. The calculation using GPS speed and indicated speedometer speed is flawed. Most speedometers seem to be purposefully conservatively calibrated from the factory. Almost every car on the road today has a factory speedo that reads two or three MPH faster than they are actually traveling at highway speeds.
  15. Dec 18, 2016 at 11:43 AM
    #35
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    To add to steelhd's post : with oem tires, speedometer is off 2-3 mph, odometer is likely spot-on. Change tire size, and odometer is likely off, and speedometer may now be less or more error. Clear as mud?
    steelhd likes this.
  16. Dec 18, 2016 at 12:30 PM
    #36
    TacoJuan
    Hanover, PA
    Crystal as mud
  17. Dec 18, 2016 at 8:12 PM
    #37
    badger
    07 SR5
    This is true of my tacoma. When I was calibrating my Dakota unit, I found that I could calibrate either the speedo or the odometer, but the two could NOT be calibrated together. I opted to have a perfect odometer, since I have a Scangauge and GPS.
  18. Dec 19, 2016 at 5:05 PM
    #38
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    Did same as Badger on my Scangauge - zero odometer error.
