Oversized tires with broken axel!! Help!!
Discussion in 'Suspension' started by traumaninja, May 30, 2014.
  1. May 30, 2014 at 5:37 AM
    traumaninja
    traumaninja [OP] Member
    Beau
    Columbus
    2012 tacoma
    I recently lifted my 2012 taco sport 4x4. I lifted her 6" and am running a toyo open country 285/75r17 with fuel hostage rims. I just got it back from a local 4x4 shop (3 days ago) and took it to get an oil change. The lube technician asked me to come into the bay and take a look at a problem with the right front axel. I looked and saw there was grease spattered all the back the frame and all over the new fabrications done by the guys at the 4x4 shop. What would have caused this? I have not done any off-roading. I have driven the truck really easy to try and get use to the lift and new tires. Do I need beefier axels?? Is this something the 4x4 shop may have done?? Should they be responsible? I feel if this was a problem before the lift was put on it would have been brought to my attention by the shop. Any suggestions? Sorry if this is in the wrong forum. Any help would be appreciated!! More details on the truck..
    2012 toyota tacoma sport 4x4
    rough country lift 6" with bilstein shocks
    toyo open country m/t tires 285/75r17
  2. May 30, 2014 at 6:05 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The front axles turn all the time 4X4 or not. Maybe some one with a 6" lift and better CV boots can help you out.
  3. May 30, 2014 at 6:24 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Is this lift a drop bracket?
  4. May 30, 2014 at 6:43 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    3 days after the lift install on a 2012 truck? Take it back to the 4x4 shop.
    CV boots don't usually fail that fast. It's likely they nicked the CV boot while doing the install. They can fix it. It's not that hard.
  5. May 30, 2014 at 6:44 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Don't wait. Do it today. The more time passes - the less leverage you've got when negotiating with the shop over when it happened and what caused it. If you can't take it in today - at least call them today.
  6. May 30, 2014 at 6:54 AM
    abcangelo
    abcangelo Well-Known Member
    Angelo
    Lakewood, CA
    14 TRD Sport 4X4
  7. May 30, 2014 at 9:41 AM
    traumaninja
    Beau
    Columbus
    2012 tacoma
    I quit driving it. I'm afraid the axel will lock up. I have a rental car. Is it ok to drive? I do think the boot just has a hole in it
  8. May 30, 2014 at 9:42 AM
    traumaninja
    Beau
    Columbus
    2012 tacoma
    The off-road shop said to call them Monday because they are busy but will look at it
