Oversteer?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rdsaal, Sep 16, 2020.
  1. Sep 16, 2020 at 3:28 AM
    rdsaal
    rdsaal [OP] Well-Known Member
    2018 Black Tacoma SR5
    I don't even know if oversteer is the right term. I run a 2018 SR5 Long Bed. All stock but with a little bigger tires. At highway speeds, when I'm in a long bend in the highway and hit a bump (Illinois has a few), the truck feels like it slides to the outside of the corner and the steering wheel moves just a hair in the direction of the curve.
    Does that even make sense? Basically it feels like the truck is coming off the ground just a bit. It's a little freaky.
    seniorredwood likes this.
  2. Sep 16, 2020 at 3:46 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    That's not what I understand oversteer to be.
    https://youtu.be/CsVg2DE0ef8
    Dirk Diggler likes this.
  3. Sep 16, 2020 at 4:43 AM
    Jake91
    Jake91 Well-Known Member
    Jake
    Detroit
    Mine did this too, dclb with some all terrains on. It wasn’t that bad, since there was so much rubber sidewall for the size of the rim, I figured that’s where the play was.
  4. Sep 16, 2020 at 4:59 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Check tire pressures (could be over filled) and shocks for wear.
    splitbolt likes this.
  5. Sep 16, 2020 at 5:00 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Sounds like bumpsteer exacerbated by suspension compression.
    Aftermarket wheels with high positive scrub don't help.
    It's fine on straight road with bumps?
  6. Sep 16, 2020 at 5:15 AM
    rdsaal
    Straight seems to be no problem. And I'm not sure I understood any of the other words in your post!
  7. Sep 16, 2020 at 5:31 AM
    rdsaal
    So I just watched a YouTube video on scrub radius. Kinda makes sense. Sounds like it's not an immediate problem but could add to wear and tear on the suspension over time.
  8. Sep 16, 2020 at 5:33 AM
    splitbolt
    NW Arkansas
    Bumpsteer is the steering changing when the suspension cycles. Since one side is in compression, that force has no where to go except through the steering.
    I see you looked up scrub...
    What are the specs on your wheels?
  9. Sep 16, 2020 at 5:56 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I would say shocks and empty bed .
  10. Sep 16, 2020 at 7:08 AM
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    The problem is that the suspension did absorb the bump correctly. Odds are you where light in the back, no weight, so instead of the tires, Springs, shocks absorbing the bump, you bounce over it which upset the direction of the vehicle. If your truck had been load with 600-1000 lbs, I think this would of been different.
    When I was driving in HSDE with my S2000, my rear shocks where set at full soft, the set up was done by a guy who worked on race suspension. The car handle great and I never felt the back end get lose.
    We have all seen the video(s) of guys running through the desert and their suspension is just absorbing everything or driving on wash board roads and the back end is just bouncing all over the place, same principal here Our trucks are designed for a happy medium, so you can either carry some weight or get a better suspension set up.
  11. Sep 16, 2020 at 7:27 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    My stock OR had quite a bit of bump steer on faster Corners. I've since switched to fox suspension and it seems a lot better.
  12. Sep 16, 2020 at 8:31 AM
    rdsaal
    This is all making sense now.
