overwhelmed by lift options
Discussion in 'Suspension' started by hirshy30, Aug 29, 2009.
  1. Aug 29, 2009 at 3:13 PM
    hirshy30
    hirshy30 [OP] Well-Known Member
    MATT
    scottsdale, arizona
    2007 4x4
    urd cai flowmaster 50 series dual bhlm floor mats t-rex chrome mesh grille 3" Revtek lift kit 33" Nitto Terra Grapplers 20" BMF S.O.T.A.
  2. Aug 29, 2009 at 3:18 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    keep it stock and be happy in the long run:D
  3. Aug 29, 2009 at 3:20 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Between the two, I'd go Fabtech.
  4. Aug 29, 2009 at 3:21 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    X2!
    My cousin had the 6" Fabtech kit on his truck that he loves!
  5. Aug 29, 2009 at 3:31 PM
    hirshy30
    MATT
    scottsdale, arizona
    2007 4x4
    ok ya thanks for ur opinion! but what if u werent to go between the 2. any others u would suggest?
  6. Aug 29, 2009 at 3:40 PM
    BigBawlzTaco
    BigBawlzTaco Wanna know how I got these scars?
    Forsyth,Georgia
    Chevy Avalanche
    Straight piped.
    I remember when i first joined this sight i ALWAYS wanted the 6 inch. But i was glad i got the 3 inch. but for your position, i would say get the fabtech. all my buddies that have it say they love it.
  7. Aug 29, 2009 at 3:41 PM
    hirshy30
    MATT
    scottsdale, arizona
    2007 4x4
    why are u glad u got a 3inch? and which one did u get?
  8. Aug 29, 2009 at 7:39 PM
    hirshy30
    MATT
    scottsdale, arizona
    2007 4x4
    is it bad to get the fabtech basic system vs. the fabtech performance system?
    bump
  9. Aug 30, 2009 at 11:50 AM
    hirshy30
    MATT
    scottsdale, arizona
    2007 4x4
  10. Aug 30, 2009 at 3:27 PM
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
  11. Aug 30, 2009 at 4:01 PM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    ProComp FTW!! I've had Fagtech components and almost got killed because of them.
  12. Aug 30, 2009 at 4:34 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Well ill tell you one thing procrap or fagtech both suck because they are drop bracket lift which only lift your truck you wont be gaining any offroading benefits with them. you will actually loose travel and will not allow your truck to have the stering geometry that it needs for offroading. personally go with a 3in lift put some 33's and you will be much happier in the long run.
  13. Aug 30, 2009 at 4:48 PM
    hirshy30
    MATT
    scottsdale, arizona
    2007 4x4
    how does it not gain offroading benefits if the entire car is higher
  14. Aug 30, 2009 at 4:50 PM
    hirshy30
    MATT
    scottsdale, arizona
    2007 4x4
  15. Aug 30, 2009 at 6:42 PM
    hirshy30
    MATT
    scottsdale, arizona
    2007 4x4
  16. Aug 30, 2009 at 6:47 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    with the 6 inch lift it takes a big cradle and you bolt the front diff. into it.. it hangs up on everything and the only way you make the diff. higher is bigger tires.. its not best for offroading. your best bet is to get a good set of coil overs and maybe UCA's with a small diff drop and a alcan leaf pack in the back.. they custom make them for your specific needs and they will give better flex while still retaining your use of the bed of your truck and different back shocks.
  17. Aug 30, 2009 at 7:04 PM
    Inked Tacoma
    Inked Tacoma GOT INK?????
    J$
    Central Coast Cal
    08 Prerunner TRD Rugged Trail
    ICON Coil-overs/2.5 V.S. Series Remote Resi Shocks Camburg Spindls'sBall-Joint UCA ( Removed Swaybar) AllPro 3 inch Lift Springs & Flip Kit, KMS XD Enduro 16x8 258/75 Mickey Thompson BAJA ATZ TRD Cat-Back Tint 30% side/Limo in back.
    Take a look at Camberg lift spindels they are 4 inch. and you can add coil overs to get more out of like another 2 inch and do custom leaf pack in the back. I had a 6 inch fabtech with custom king coils in the front on my 99 and i liked it all lot. just got tyerd of getting in and out of it that big...
  18. Aug 31, 2009 at 5:25 AM
    imsikotic
    Randy
    Temecula, Ca
    Spindles no worky for 4WD.
  19. Aug 31, 2009 at 9:49 PM
    Inked Tacoma
    J$
    Central Coast Cal
    Did not see that part good catch......
  20. Sep 1, 2009 at 3:20 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    ah grass hoppa, so much to learn. drop bracket 6 in lifts are just that, lift kits. not performance suspensions. the basic kits are just really really big spacers and you pay a crap load for it. if you plan on using the truck offroad w/ the 4WD and actually offroading then stay away from any 6 inch lift kit. once you put one on. your stuck w/ it.
