OVT vF Map Edit - Air Load Control (ALC)
Discussion in 'Performance and Tuning' started by tonered, Sep 17, 2020.
  1. Nov 19, 2020 at 3:49 PM
    #101
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    Did you just apply the gear 1 settings or did you apply them to 1 through 6?
    I've never tried anything with the stock file. Only used for comparisons actually
  2. Nov 19, 2020 at 3:59 PM
    #102
    18tacotues
    18tacotues Active Member
    North Carolina
    2018 White TRD OR 6mt
    I applied 1-6 and reverse. Leaving 2-6 out you could feel the switch and the almost feel the confusion of the computer
    tonered[OP] likes this.
  3. Nov 19, 2020 at 4:02 PM
    #103
    92ehatch
    Kinley
    Hendersonville NC
    Hmm, i haven't tried reverse yet
    What's that like?
  4. Nov 19, 2020 at 4:23 PM
    #104
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    That doesn't apply to the 2.0 tunes since @OVTune mapped everything to PTTT1G.
    uploadadventure likes this.
  5. Nov 19, 2020 at 4:39 PM
    #105
    18tacotues
    North Carolina
    Much like base 1st changes, removed the bog from reverse
  6. Nov 20, 2020 at 12:21 AM
    #106
    92ehatch
    Kinley
    Hendersonville NC
    Even reverse?
  7. Nov 20, 2020 at 5:23 AM
    #107
    tonered
    tony
    Lynnwood, WA
    Good question.
  8. Nov 20, 2020 at 6:50 AM
    #108
    18tacotues
    North Carolina
    Can't input on what the 2.0 settings do yet. But changing the reverse map made a big difference from factory
  9. Nov 20, 2020 at 12:00 PM
    #109
    wingsformyway
    wingsformyway Well-Known Member
    Alex
    Vancouver Island, BC, CA
    2021 Tacoma TRD Sport DCSB 6MT Cement Grey
    Blackout badges & tailgate inserts; interior blackout (vinyl)
    I might try applying some of the changes to reverse as well. I don't mind how tall it is but then I can't say I have towed or plan to in the near future. I can imagine what everyone says about it in that instance is true.
    I just like how I can get in and out of car park stalls without using the accelerator at all, minor inclines included. That aside, I do wonder if reverse can be toned down some with vF to accomplish similar results to the 4Lo mod I've read about
  10. Nov 23, 2020 at 6:08 PM
    #110
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    Another fairly basic question for you folks that have been tweaking tunes... I just got 2.0 from Mat for 04B90 (2020), but I havent really noticed anyone edit 04B90 specifically in VF. Can the same changes shown in this thread for other ECU types be applied to all ECU's with similar results?
  11. Nov 23, 2020 at 7:02 PM
    #111
    wingsformyway
    Alex
    I would say yes, emphasizing your use of 'similar.' I applied many of the tweaks the guys did on my stock 2021 and noticed a difference immediately. I can only imagine these tweaks on top of Mat's tune files (I will find out one day, whenever he gets around to compiling the pack for 04C30)
  12. Nov 23, 2020 at 10:25 PM
    #112
    tonered
    tony
    Lynnwood, WA
    For the 3D and 4D maps, compare your starting values to what is shown. If they match up, then the edits are good to go.
  13. Nov 24, 2020 at 12:24 AM
    #113
    92ehatch
    Kinley
    Hendersonville NC
    If you guys could, open those maps and post a screen shot of the values.
    Would be interesting to see what toyota did with those values in the newer models.
  14. Nov 24, 2020 at 5:24 AM
    #114
    tonered
    tony
    Lynnwood, WA
    In the 1st posts of the other threads linked, I posted the unedited values.
  15. Nov 24, 2020 at 6:49 AM
    #115
    92ehatch
    Kinley
    Hendersonville NC
    For the 20 and 21 models?
  16. Nov 24, 2020 at 6:59 AM
    #116
    tonered
    tony
    Lynnwood, WA
    I only have 04B14 unlocked. I'm happy to post up others if differences are found.
  17. Nov 24, 2020 at 9:48 AM
    #117
    wingsformyway
    Alex
    Which maps exactly? I'll be happy to screencap from the stock 04C30 and post for you to see
  18. Nov 24, 2020 at 1:00 PM
    #118
    CdnSldr
    Canada Eh!
    What exactly do you wanna see?
  19. Nov 24, 2020 at 1:31 PM
    #119
    CdnSldr
    Canada Eh!
    @92ehatch @tonered Here is stock control air for 04B90
    This is OVT 2.0SFOB 91 for 04B90. Looks like Mats version of this map is identical
    C41n and tonered[OP] like this.
  20. Nov 24, 2020 at 1:33 PM
    #120
    OVTune
    OVTune Well-Known Member
    OVTune
    Yep we don't modify those tables on the tune pack tunes.
    But we do recommend modifying them if you have vF Tuner and want to customize.
